![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 27.07.2017 um 05:24 schrieb Sven Littkowski:
>> At the moment, all seems to point at the pigment definition as the
>> culprit, as that's the only relevant thing we've always changed. You
>> should at least /try/ it with a plain pigment, to either confirm or
>> refute this theory.
>> If you can confirm it, we know that's what we have to examine further;
>> in that case you'll probably want to post the image map at last, so that
>> we can see what might be so special about it.
>> Otherwise we can be sure that it's a red herring, and that we have to
>> dig someplace else.
> Nope. Here's a one-color pigment. :-(
Okay, now this leaves surprisingly few possible explanations. I can only
come up with the following:
- You might be using a rare and buggy version of POV-Ray.
To check this, I recommend you post the exact POV-Ray version number
(and let us know which operating system you're using).
- You might be using a different scene file and/or bump map image file
than those you posted.
- There might be a relevant line break introduced in your post of the
scene file that we've been overlooking.
To check these two, I recommend you temporarily rename your scene and
auxiliary files (image file and bump map), then try to re-create the
scene from your own postings and render it. You'll get parse errors,
make sure to fix only those actually reported.
- You might be using low-quality settings (`+q7` or lower).
To check this, I recommend you post the message output of the render,
and/or run the render with `+giFOO.INI` and post the generated FOO.INI here.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 7/27/2017 8:41 AM, omniverse wrote:
> Stephen <mca### [at] aol com> wrote:
>> On 7/27/2017 7:30 AM, omniverse wrote:
>>> Here we are approaching 60 messages in this thread, must be an answer to the
>>> mystery... thing is, no one else has had the same thing happen yet, except for
>>> finding trouble with low contrast, dark image/bump maps.
>> Do you think that it is possible that there is a mix up with duplicate
>> image files being referenced?
>> Or finding the wrong file in a long Library_Path?
> Not very likely I suppose.
It has happened to me on occasion.
> Just checked using image and bump files located in a parent-sub-sub folder on a
> another partition and was okay with forward slashes and backslashes, even though
> the latter causes P-R to spit out error messages.
> Oh, and this must be message number 60. ;)
A long way off the record.
642 at the last count, in OT.
http://news.povray.org/povray.off-topic/thread/%3C5797bc1b%40news.povray.org%3E/?ttop=416746&toff=50
> Await hearing which POV-Ray version, or if custom compiled. I could have missed
> that info so maybe I will scan over this thread again in the meantime.
Has anyone collect Sven's code? I don't fancy going through the thread
to piece it all together. And I've not been following it closely.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This is the latest, with my amendments. See also the attached images I used.
Download 'balloon bumpmap.png' (201 KB)
Download 'balloon texture.png' (3 KB)
Download 'sl_balloon2.pov.txt' (8 KB)
Preview of image 'balloon bumpmap.png'
![balloon bumpmap.png](/povray.binaries.images/attachment/%3C5979cc37%40news.povray.org%3E/balloon%20bumpmap.png?ttop=421332&toff=100&preview=1)
Preview of image 'balloon texture.png'
![balloon texture.png](/povray.binaries.images/attachment/%3C5979cc37%40news.povray.org%3E/balloon%20texture.png?ttop=421332&toff=100&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"omniverse" <omn### [at] charter net> wrote:
> Sven Littkowski <I### [at] SvenLittkowski name> wrote:
> > On 26.07.2017 12:37, Bald Eagle wrote:
> > > https://www.youtube.com/watch?v=e9Q3orQhEcA
> > > Maybe Sven needs to add some light sources to the scene... :D
> > But I have a light source there. You mean, I should add more light sources?
> ":D" big grin face, so I'm sure Bald Eagle was jesting, at least mostly I'm
> guessing.
The light sources I was suggesting were the lights at the bottom of the balloon
- in the video. Because spaceships only ever visit Earthlings at night in
isolated, unpopulated areas.
And it makes for dramatic lighting.
I think that for clarity and accuracy, it might be advisable to package all of
the files into a ZIP and post it in a binary thread so that everybody has all of
the same pieces to analyze. Unzip to a subdirectory, and then there shouldn't
be any question of what files are being used to generate the render.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> used.
Thanks Thomas.
The results were as expected. The shadows showing.
But is this expected? It is the top of the balloon.
[Drat! I can't put them inline.]
Using Sven's original code. I imported it into Bishop3D correcting the
errors one by one. Using the image maps you supplied. The second image
is directly from Sven's code.
What concerns me is:
image_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher
- Balloon - Type 001 - Moon Runnings - Balloon Texture.png" }
Are those spaces and dashes part of the file name?
Regards
Download 'import02_0000.png' (184 KB)
Download 'import03_00000.png' (137 KB)
Preview of image 'import02_0000.png'
![import02_0000.png](/povray.binaries.images/attachment/%3C5979d9c0%40news.povray.org%3E/import02_0000.png?ttop=421332&toff=100&preview=1)
Preview of image 'import03_00000.png'
![import03_00000.png](/povray.binaries.images/attachment/%3C5979d9c0%40news.povray.org%3E/import03_00000.png?ttop=421332&toff=100&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
How very true. :)
Did I ever tell you about the time I stopped off in Roswell for lunch? I
regretted it, I can tell you.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> used.
> Thanks Thomas.
Well, the bump_map is polar-oriented, so I expect the creases to show up
on the sides too while the top is fairly smooth (according to the map).
A question for Sven, but I think they are.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> used.
>> Thanks Thomas.
Sorry, I meant the cap on the top that was missed in the difference.
Indeed it is. Although they look suspiciously, a bit like file paths to me.
Like everyone else, I see no reason for it not to work on Sven's machine.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> to the
>> except for
Not sure, but I would tend to say NO. I have only that one bump image. :-
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
missed
POV-Ray v3.7.0.msvc10.win64
http://www.avg.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
