POV-Ray : Newsgroups : povray.binaries.images : Egg Server Time
27 May 2026 09:07:39 EDT (-0400)
  Egg (Message 15 to 24 of 44)
Subject: Re: Egg
Date: 28 Apr 2017 07:00:00
Message: <590320b0@news.povray.org>
As a comparison, a render without any subsurface scattering.
Download 'sslt_test_uber_noss.png' (682 KB)
Preview of image 'sslt_test_uber_noss.png'
Subject: Re: Egg
Date: 29 Apr 2017 11:05:47
Message: <5904abcb@news.povray.org>
That definitely makes a huge difference with the dragon.  It looks like
modeling clay, not jade.  But there seems only a slight difference with
the floor, and the egg and cube look the same.
Subject: Re: Egg
Date: 30 Apr 2017 02:43:47
Message: <590587a3$1@news.povray.org>
I think I need to explore more the translucency strength for each
object, increasing or decreasing the value. I am not yet done ;-)
Subject: Re: Egg
Date: 30 Apr 2017 03:48:45
Message: <590596dd@news.povray.org>
In fact, the differences are more subtle. For the cube, compare the
shadows of dragon and egg: their edges show the stone's translucency. In
my next render I hope to show this better.
Subject: Re: Egg
Date: 30 Apr 2017 07:05:46
Message: <5905c50a@news.povray.org>
In this render:
- Dragon: no SSLT
- Floor: no SSLT
- Cube: SSLT with 5*translucency vector (was 2* in earlier example)
- Egg: SSLT with 3*translucency vector (was 2* in earlier example)
The cube is showing markedly more translucency in the shadows cast on
it. I see not much difference in the egg, although if I increase the
translucency exaggeratedly (*100 for instance) the effect becomes distorted.
Question: In the wiki about SSLT it is said: "The effect doesn't scale
with the object". Does this mean that SSLT works in the same way as a
scattering media where the amount of scattering has to be compensated
for the amount of media object's scale? It appears so to me at least
although this is not mentioned in the wiki.
Download 'sslt_test_uber.png' (679 KB)
Preview of image 'sslt_test_uber.png'
Subject: Re: Egg
Date: 30 Apr 2017 12:30:41
Message: <59061131$1@news.povray.org>
> In this render:
> - Dragon: no SSLT
> - Floor: no SSLT
> distorted.
It does work similarly to medias, both emissive, absorbing and scattering.
So, if you scale your scene by 10 and want SSLT to look the same, then
you need to multiply your SSLT vector by 10. Alternately, you can
increase mm_per_unit by the same amount in the global_settings block.
Subject: Re: Egg
Date: 1 May 2017 02:50:29
Message: <5906dab5$1@news.povray.org>
>> In this render:
>> - Dragon: no SSLT
>> - Floor: no SSLT
>> distorted.
OK. Only difference would be that with scattering media (for instance)
you have to /divide/ the scattering vector by the scale of the container
to get the same result, but I get the point indeed.
I am a bit wary about the mm_per_unit and prefer not to touch it too
much, especially if different objects have different scales.
Subject: Re: Egg
Date: 1 May 2017 06:08:34
Message: <59070922$1@news.povray.org>
Yes Clipka has put the fear of god into us. :-)
I suppose it depends what you intend by scaling the models.
Regards
Subject: Re: Egg
Date: 1 May 2017 07:11:32
Message: <590717e4$1@news.povray.org>
Indeed, yes. Take my image as example, the dragon is scaled 0.01, the
egg 0.25, the cube is not scaled, and the floor 0.50. It seems best to
use a standard mm_per_unit and change translucency as needed.
Subject: Re: Egg
Date: 1 May 2017 08:06:14
Message: <590724b6$1@news.povray.org>
My understanding is that the mm_per_unit is the world/scene scale
And to add to the confusion (on my part at least) meshes can have an
internal scale and an external one. By internal scale I mean the scaling
you can change in PoseRay before exporting and external is how you
change it in PovRay.
In Blender when using the physics engine the scale should be 1.0. So to
scale a mesh. You need to edit it and scale it there. Otherwise you get
unexpected results.
So if the dragon is an ornament. I would scale it down in PoseRay. If it
is a statue scale it up in PoseRay. Keep the mm_per_unit as the default.
Having said that. I have not used SSLT since its RC3. :-(
So what do I know?
Regards
