POV-Ray : Newsgroups : povray.binaries.images : Dragon Lady Server Time
13 Jul 2025 03:18:41 EDT (-0400)
  Dragon Lady (Message 26 to 35 of 65)
Subject: Re: Dragon Lady
Date: 7 Aug 2016 15:16:28
Message: <57a7890c@news.povray.org>
> Stephen <mca### [at] aolcom> wrote:
>> I use three media in one interior.
> Changed my code - that seems to work for me now.
>> I would post the code but it is messy. I have to overwrite the code
>> Bishop3d exports with the code modified to run direct from Pov.
> Seems messy and time consuming.
>> Both Bishop3d and Moray export a pov file for each frame and it takes
>> PovRay 16 seconds to save the scene.
> "Frame"?  Is that one of the "slices" to make the DF3?
>> Creating the tga files to make the
>> df3's would take Bishop3d about an hour and a half to export 100 frames
>> times 3 for each channel.
> That seems insane.
> There has to be a better way / workflow.
> I had an idea last night -
> I did a quick experiment with the Stanford Dragon mesh:
> defined the object
> used #declare Variable = VRand_In_Obj(object {StanfordDragon}, Stream);
> to get the coordinates of 10,000 spheres, and placed them, made a copy of that
> and overlaid it with a "skin", plus rendered a jade textured mesh beside it - in
> 51 seconds.
> I'm thinking that it may be well worth your while to either ditch media and use
> an alternate scheme, or use POV-Ray to scan through a full-color solid object
> and make a point-cloud right in SDL
> http://paulbourke.net/miscellaneous/povexamples/
> I think there must be a way to export the full RGB data in a single DF3, and
> then maybe overlay the real mesh with a highly-transparent texture.
Sory, it's just not possible. DF3 support 1, 2 or 3 bytes per voxel, but
always in a single channel gray levels.
> Can you make the mesh object filled with a media directly?
> I don't play with these things very often, so I'm just brainstorming.
Date: 7 Aug 2016 15:31:16
Message: <57a78c84$1@news.povray.org>
On 8/7/2016 8:12 PM, Alain wrote:
> In method 1 and 2, confidence, variance and ratio are used to control
> how many samples are to be used in the different intervals depending on
> the density and illumination in the various intervals. With method 3,
> using more that a single interval is highly counterproductive.
> I've done my tests with intervals and the negative impact they have on
> the performance is astounding.
> I demonstrated that samples 100 is way faster than intervals 10 samples
> 1 for greatly better results.
Thanks Alain, I knew I would get it in the neck for posting that code. :)
Except for the intervals/samples thing. The other things you mention are
Bishop3D defaults and there is not a lot that I can do about what is
exported except go through the code afterwards. But I have a relatively
fast machine, so I don't.
I seem to have a blind spot for samples vs intervals. Thomas, amongst
others, is forever mentioning it.
I use media so seldom that I have to relearn it whenever I want to use
it. :(
So it is not ignorance but stupidity on my part. :(
Regards
Date: 7 Aug 2016 16:21:47
Message: <57a7985b$1@news.povray.org>
Good, good.
True but needs must. :) And I need a visual representation of the scene
I am making.
Yes, I use frame_number instead of clock for animations.
> That seems insane.
You are telling me. It is so easy to make a mistake or forget a step.
Very tiresome indeed.
I had forgotten about the Stanford Dragon. It is quite upright at the
front and might be a good object to use. The Stanford Bunny might be a
good model to use as well. If you can imagine a drug smoking violent
Street Gang disguised as bunny.
> defined the object
> 51 seconds.
You are confusing me. You are confusing me with someone who can code. ;)
Basic and PLC (programmable logic controller) are my limits.
I'll have a look at that. Paul is always worth listening to.
Yes you can but in the process of creating a media. PovRay converts the
colour vector into a scalar. That is why I have used different
multipliers in the different colour channels.
> and then maybe overlay the real mesh with a highly-transparent texture.
That is too simple. There must be a catch. :)
If I make sure that the mesh is closed. I don't want my dragon leaking :)
It would negate the problem of a media container inside another media
container being visible.
Keep at it. It is only too easy to pick one direction and stick to it.
Almost all comments are welcome.
Regards
Date: 7 Aug 2016 16:26:25
Message: <57a79971$1@news.povray.org>
>> DF3, and
That is why I filtered the R, G & B values then copied the single colour
to the other colours in an editor. It did not work as well as I hopped.
But some of the detail is there.
Regards
Date: 7 Aug 2016 17:01:19
Message: <57a7a19f$1@news.povray.org>
Just had another thought about that idea.
Poser meshes are not like scanned meshes. They can have internal
structures. For instance eyes are closed meshes part of which is within
the whole body. In the animation below the eyes of the spirit Ariel's
eyes glow. An artefact that did not distract, for once. :)
http://www.tc-rtc.co.uk/image/upload//Stephen/pw-1228515119-Prologue.mpg
Regards
Date: 7 Aug 2016 18:25:41
Message: <57a7b565@news.povray.org>
> it. :(
Here are the default vbalues :
method 3
samples 10
intervals 1 // Don't increase !
The default code from Bishop mostly repeat the actual defaults values.
That effectively make then into "no operation" code.
Even on the fastest machine, using intervals >1 is a serious performance
killer.
Date: 7 Aug 2016 18:55:00
Message: <web.57a7bb41e7e0b8f75e7df57c0@news.povray.org>
So, that's a macro where you give it the object, and a random stream, and it
samples the bounding box until it finds a point that's actually IN the object
itself.  So I just did that with a loop 10,00 times.
And I figured media could be faked with tiny spheres - a real point cloud, but
in the shape of the object
I then took the mesh, and textured it with a see-through texture.
I figured if it was just barely visible, it would have a printed-lampshade
effect with the emissive stuff inside - all the color and detail would be on the
outside "skin", and no color separation would be necessary
Just the regular old POV-ray textured mesh object, for comparison
Teamwork.  ;)
I'm struggling with the crazy camera frustrum thing he has on that page.
Seems like it could rewritten for clarity and completeness.
I will have to think on that.
Yeah - I suck at using filter and transmit, and the result might not be as great
looking as a media.
Try that.
Put a white emissive media in the mesh container, and texture the mesh with a
very highly transparent texture of the original rgb colors
Date: 8 Aug 2016 02:46:32
Message: <57a82ac8$1@news.povray.org>
On 7-8-2016 20:47, Alain wrote:
> If you scale the container with the media, then, that scaling will
> affect any media contained. Emissive media will become brighter,
> absorbing media may become totally opaque.
> If you want the media effect to remain unchanged, then you always need
> to adjust the density of the media by the inverse of the scaling. Scale
> up by 10, reduce the density or base colour by 10.
Ah! Thanks for the reminder. I mostly use scattering media that is why.
Date: 8 Aug 2016 02:51:02
Message: <57a82bd6$1@news.povray.org>
I was away for part of the day, and now I am lost :-)
I have not followed the media discussion in detail and will pick up from
here.
Date: 8 Aug 2016 07:15:00
Message: <web.57a8695be7e0b8f75e7df57c0@news.povray.org>
Given what Stephen resorts to doing, I thought that might be the case.
BUT - I also thought that perhaps if there were a way to recolor the DF3 befor
saving, then the realistic RBG values could be _encoded_ into that false color
in such a way that they could be extracted back out of the gray value.
I need to get going, so I'll just give a quick non-binary example.
Lets say you had a single "gray value that could range from 0-999.
I was thinking that perhaps R could be factors of 100, G of 10, and B of 1.
3x8=24, 0 to 23, pow(2, 23) =
8388608
Simplistic, and it all depends on how the gray value gets calculated so that
things don't get irreversibly "mixed" - but I'll bet the 8-bit guys would puzzle
out a clever cryptographic scheme to encode all of Tetris into that little bit
of storage space  ;)
If it's possible, the range of RGB of course will not be as smooth as the
original, but I believe the trade-off in saving Stephen many painful hours of
scene development would be well worth it.
DISCLAIMER:
This is all just a pipe-dream that I'm having on a Monday morning, before
coffee, without inside knowledge of how Moray or Bishop handle data, or how
DF3's get encoded.
