POV-Ray : Newsgroups : povray.binaries.images : NURBS Server Time
8 Jun 2026 04:33:34 EDT (-0400)
  NURBS (Message 6 to 15 of 55)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: NURBS
Date: 24 Jul 2016 03:08:21
Message: <57946965$1@news.povray.org>
Le 24/07/2016 08:17, clipka a écrit :
> Am 24.07.2016 um 07:55 schrieb Le_Forgeron:
>> Le 24/07/2016 04:13, clipka a écrit :
>>> What's been bothering me about POV-Ray's Bezier patches is that we don't
>>> have some kind of bezier mesh to support non-union CSG. Do you think you
>>> can throw together a nurbs mesh primitive?
>> what do you want ? or what is the need ?
>> It's a 2D finite surface, involving it in CSG does not seem to make sense (to me).
>> (it is rarely closed, until you glue many nurbs together)
> ... and that's exactly what I'd love to see. Just like you glue many
> triangles together in a mesh.
So, do you want a "container" for multiple nurbs with additional "inside" property so
it can be used in further CSG operation ?
(assuming such container would assert that the collection of nurbs defines one or more
closed surfaces with non-zero enclosed volume(s))
Using the same approach as for mesh (inside_vector), it might be possible.
I just anticipate a high cpu cost.
On the same line, while we are at it, such container could also handle bicubic_patch
the same way.
Any suggestion of name for that container ?
Still any interest for nurbs.get_vertex() ? or can I forget it ?
Subject: Re: NURBS
Date: 24 Jul 2016 05:35:01
Message: <web.57948ae06d1ce2047a3e03fe0@news.povray.org>
> @LanuHum:
> Does Blender provide full support for NURBS? If so, then this looks like
> an urgent job for you!
It is very good that made Le Forgeron!
Le Forgeron, thank you!
Hair in Blender - NURBS.
There are also some tools for editing NURBS curves.
If it can be used in CSG - it is very good
:D
Subject: Re: NURBS
Date: 24 Jul 2016 05:45:17
Message: <57948e2d$1@news.povray.org>
Duck & Cover.
As illustrated in the first post, a simple scene with only 4 nurbs of degree 6 & 3, a
box and a cylinder took already 1 minute on 6+6 cores... and there is nothing fancy in
the scene. And I do not believe the box or the cylinder to cost.
The bounding box might helps a bit, but I predict a sky-rocketed render time if you
model any individual hair with nurb, short of modeling only Britney after the barber
shop.
Of course, not a problem if using nurbs for the head of hair, with some mapped
pigments or textures.
Subject: Re: NURBS
Date: 24 Jul 2016 05:50:00
Message: <web.57948efb6d1ce2047a3e03fe0@news.povray.org>
"LanuHum" <Lan### [at] yandexru> wrote:
> clipka <ano### [at] anonymousorg> wrote:
> > @LanuHum:
> :D
Example:
Download 'nurbs.jpg' (65 KB)
Preview of image 'nurbs.jpg'
Subject: Re: NURBS
Date: 24 Jul 2016 06:05:00
Message: <web.579492136d1ce2047a3e03fe0@news.povray.org>
Sorry! This is surface.
Nurbs surface also supported
Download 'nurbs_surface.jpg' (192 KB)
Preview of image 'nurbs_surface.jpg'
Subject: Re: NURBS
Date: 24 Jul 2016 10:08:27
Message: <5794cbdb$1@news.povray.org>
Am 24.07.2016 um 11:31 schrieb LanuHum:
>> @LanuHum:
Are you sure Blender hair uses NURBS /patches/ (which is what LeForgeron
has implemented) and not NURBS /curves/?
Subject: Re: NURBS
Date: 24 Jul 2016 11:10:48
Message: <5794da78$1@news.povray.org>
Am 24.07.2016 um 09:08 schrieb Le_Forgeron:
so it can be used in further CSG operation ?
more closed surfaces with non-zero enclosed volume(s))
You got it :)
Can't be worse than using a simple union of individual patches.
the same way.
"nurbs_mesh"?
Sounds like a useful idea.
Subject: Re: NURBS
Date: 24 Jul 2016 11:50:00
Message: <web.5794e36d6d1ce2047a3e03fe0@news.povray.org>
> >> @LanuHum:
I realized this later, and wrote about it.
Blender has four primitive NURBS.
They can edit: transform vertices and extrude.
You can also create NURBS surfaces from NURBS curves using loft.
Create patches 4 x 4 - uncomfortable modeling.
Download 'nurbs_surface1.jpg' (142 KB)
Preview of image 'nurbs_surface1.jpg'
Subject: Re: NURBS
Date: 24 Jul 2016 12:15:01
Message: <web.5794e8606d1ce2045e7df57c0@news.povray.org>
> "nurbs_mesh"?
If it's a closed 3d shape composed of NURBS mesh(es), then maybe "envelope" to
differentiate and disambiguate from a (simple) open mesh?
Subject: Re: NURBS
Date: 24 Jul 2016 12:32:35
Message: <5794eda3$1@news.povray.org>
Am 24.07.2016 um 18:10 schrieb Bald Eagle:
>> "nurbs_mesh"?
Sounds far too vague and unrelated. Besides, I think it would be smart
to also support non-closed NURBS patch meshes, just like mesh also
supports non-closed triangle meshes.
