This is a follow up to an image I submitted to an early TC-RTC in 2007.
It got a little bit of criticism because I reused some models from a
previous animation. So I made a rude version then started this one. The
same scene after hours when the characters were relaxing. Using
red/cyan glasses is much more convenient than making it for shutter
glasses.
BTW It was Gail Shaw who started this train of thought.
Here is the original:
http://www.tc-rtc.co.uk/portfolio/Stephen/86/index.html
There are a couple of obvious faults but comments welcome.
This version is made with two parallel cameras (Thanks StephenS). I
still don't understand why using toed in cameras is not better. But
heigh hoe it's not.
Regards
Download 'a_grpnew01as_.png' (1507 KB)
Preview of image 'a_grpnew01as_.png'
I remember that scene now and this one is a somewhat unexpected follow
up on it. It made me grin: going from high drama to cosy chatting. But
what do you expect? Theatre.
Now, how about King Lear, hm?
About faults: here too there is that trouble with the focussing of the
foreground like in StephenS's scene.
> I still don't understand why using toed in cameras is not better.
Try http://paulbourke.net/stereographics/stereorender/
I re-found this recently.
Stephen S
Shalt thou play the king to my fool on yon Blasted Heath?
I think that is a different cause.
I suspect it is caused by using a reflective texture for the skin and
the materials and normals on the floor. When I create a stereo image for
my shutter glasses. The image is crystal clear and I can see the colours
of the halo around the priestess properly.
As for being cosy. The poses are taken from this.
https://www.thinglink.com/scene/659847343616557056
Regards
Excellent! find. It helps a lot. I might remember it now.
Now I need a non symmetric camera frustum. But we have one.
The good Dr John posted a macro for a true architectural field camera.
That might do the trick.
http://news.povray.org/povray.text.scene-files/thread/%3Cweb.3e0c736a1f1273cdb29393de0%40news.povray.org%3E/
If not Friedrich Lohmüller has a trick or two.
Thanks Stephen
Regards
Am 11.06.2016 um 17:33 schrieb Stephen:
Now that you mention it:
You certainly have gotten _something_ wrong in your image. Stuff should
be offset horizontally only, but virtually everything in your scene is
also offset vertically. That certainly makes for very tedious viewing.
I'll check that. I'm not familiar with the software and was trying the
adjustments. Just pressing buttons and seeing what happened.
I don't think it is a good subject and tried a simple animation with an
old BBC logo. The shutter glass version is crystal clear but the
anaglyph has ghosting.
Regards
I am still grateful for the fieldcam. It has helped me in lots of ways.
I had not realised though that it was exactly the camera needed for 3D.
I am afraid I am already the fool.
Maybe, but I suspect it has to do with what Clipka mentions and maybe
with non-symmetry.
<shudder> I would not care to join them </shudder>. I have a problem
with man-built heights; curiously enough, none at all with natural heights.
For animations and scenes with left/right border elements, yes.
This is why I usually post only frame centered objects with white space
close to the borders.
Stephen S
