![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This is a follow up to an image I submitted to an early TC-RTC in 2007.
It got a little bit of criticism because I reused some models from a
previous animation. So I made a rude version then started this one. The
same scene after hours when the characters were relaxing. Using
red/cyan glasses is much more convenient than making it for shutter
glasses.
BTW It was Gail Shaw who started this train of thought.
Here is the original:
http://www.tc-rtc.co.uk/portfolio/Stephen/86/index.html
There are a couple of obvious faults but comments welcome.
This version is made with two parallel cameras (Thanks StephenS). I
still don't understand why using toed in cameras is not better. But
heigh hoe it's not.
Regards
Download 'a_grpnew01as_.png' (1507 KB)
Preview of image 'a_grpnew01as_.png'
![a_grpnew01as_.png](/povray.binaries.images/attachment/%3C575b274e%40news.povray.org%3E/a_grpnew01as_.png?ttop=443824&toff=1050&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I remember that scene now and this one is a somewhat unexpected follow
up on it. It made me grin: going from high drama to cosy chatting. But
what do you expect? Theatre.
Now, how about King Lear, hm?
About faults: here too there is that trouble with the focussing of the
foreground like in StephenS's scene.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> I still don't understand why using toed in cameras is not better.
Try http://paulbourke.net/stereographics/stereorender/
I re-found this recently.
Stephen S
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Shalt thou play the king to my fool on yon Blasted Heath?
I think that is a different cause.
I suspect it is caused by using a reflective texture for the skin and
the materials and normals on the floor. When I create a stereo image for
my shutter glasses. The image is crystal clear and I can see the colours
of the halo around the priestess properly.
As for being cosy. The poses are taken from this.
https://www.thinglink.com/scene/659847343616557056
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Excellent! find. It helps a lot. I might remember it now.
Now I need a non symmetric camera frustum. But we have one.
The good Dr John posted a macro for a true architectural field camera.
That might do the trick.
http://news.povray.org/povray.text.scene-files/thread/%3Cweb.3e0c736a1f1273cdb29393de0%40news.povray.org%3E/
If not Friedrich Lohmüller has a trick or two.
Thanks Stephen
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 11.06.2016 um 17:33 schrieb Stephen:
Now that you mention it:
You certainly have gotten _something_ wrong in your image. Stuff should
be offset horizontally only, but virtually everything in your scene is
also offset vertically. That certainly makes for very tedious viewing.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'll check that. I'm not familiar with the software and was trying the
adjustments. Just pressing buttons and seeing what happened.
I don't think it is a good subject and tried a simple animation with an
old BBC logo. The shutter glass version is crystal clear but the
anaglyph has ghosting.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am still grateful for the fieldcam. It has helped me in lots of ways.
I had not realised though that it was exactly the camera needed for 3D.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am afraid I am already the fool.
Maybe, but I suspect it has to do with what Clipka mentions and maybe
with non-symmetry.
<shudder> I would not care to join them </shudder>. I have a problem
with man-built heights; curiously enough, none at all with natural heights.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
For animations and scenes with left/right border elements, yes.
This is why I usually post only frame centered objects with white space
close to the borders.
Stephen S
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
