I remember that scene now and this one is a somewhat unexpected follow
up on it. It made me grin: going from high drama to cosy chatting. But
what do you expect? Theatre.
Now, how about King Lear, hm?
About faults: here too there is that trouble with the focussing of the
foreground like in StephenS's scene.
> I still don't understand why using toed in cameras is not better.
Try http://paulbourke.net/stereographics/stereorender/
I re-found this recently.
Stephen S
Shalt thou play the king to my fool on yon Blasted Heath?
I think that is a different cause.
I suspect it is caused by using a reflective texture for the skin and
the materials and normals on the floor. When I create a stereo image for
my shutter glasses. The image is crystal clear and I can see the colours
of the halo around the priestess properly.
As for being cosy. The poses are taken from this.
https://www.thinglink.com/scene/659847343616557056
Regards
Excellent! find. It helps a lot. I might remember it now.
Now I need a non symmetric camera frustum. But we have one.
The good Dr John posted a macro for a true architectural field camera.
That might do the trick.
http://news.povray.org/povray.text.scene-files/thread/%3Cweb.3e0c736a1f1273cdb29393de0%40news.povray.org%3E/
If not Friedrich Lohmüller has a trick or two.
Thanks Stephen
Regards
Am 11.06.2016 um 17:33 schrieb Stephen:
Now that you mention it:
You certainly have gotten _something_ wrong in your image. Stuff should
be offset horizontally only, but virtually everything in your scene is
also offset vertically. That certainly makes for very tedious viewing.
I'll check that. I'm not familiar with the software and was trying the
adjustments. Just pressing buttons and seeing what happened.
I don't think it is a good subject and tried a simple animation with an
old BBC logo. The shutter glass version is crystal clear but the
anaglyph has ghosting.
Regards
I am still grateful for the fieldcam. It has helped me in lots of ways.
I had not realised though that it was exactly the camera needed for 3D.
I am afraid I am already the fool.
Maybe, but I suspect it has to do with what Clipka mentions and maybe
with non-symmetry.
<shudder> I would not care to join them </shudder>. I have a problem
with man-built heights; curiously enough, none at all with natural heights.
For animations and scenes with left/right border elements, yes.
This is why I usually post only frame centered objects with white space
close to the borders.
Stephen S
Bags I Cornwell.
Not for the gore. My wife is called Regan.
> with non-symmetry.
As for that image, probably.
Starting afresh I made a 240 frame animation as a test. It looks perfect
with the shutter glasses but there is ghosting in the horizontal
direction. When I save it in the Red/Cyan format.
I attach a frame and will follow up with the left and right images.
It is meant to be behind the screen.
Comments welcome.
I just can't stand heights. In nature I won't go near an edge.
When I worked on the rigs. I just had to do it.
Climbing to the top of a crane to work on a sensor. To climbing to the
top of the drilling derrick and watching someone else change an anemometer.
"Lunch atop a skyscraper" is like a toothache. The type you have to
probe. To make sure it is still there.
Regards
Download 'bbc07_rc_0070.jpg' (523 KB)
Preview of image 'bbc07_rc_0070.jpg'
