POV-Ray : Newsgroups : povray.binaries.images : The lemon is ready Server Time
13 Jun 2024 16:51:46 EDT (-0400)
  The lemon is ready (Message 25 to 34 of 34)
Subject: Re: The lemon is ready
Date: 26 May 2016 12:12:39
Message: <57472077@news.povray.org>
On 05/26/2016 10:15 AM, Le_Forgeron wrote:
> Le 26/05/2016 à 15:24, William F Pokorny a écrit :
> On LemonLeft, parsing occurs up to the inner radius, then the message is
> written and the object so far get replaced with a sphere.
> Then parsing continue and find sturm, which is not supported by a sphere.
> Notice that the same issue would occurs with current ovus (when the top
> radius is more than twice the bottom radius).
> For lemon, I could replace with another object which would support
> sturm, but is it really needed ? or even wanted ?
> (My first approach was to stop with an error instead of a warning, was
> it better ?)
Suppose if someone is doing an animation or sequence of images, it might
be convenient to transition into a sphere then continue to shrink that
sphere.
If so, we are not really doing that today as we seem to be at a 0.5
radius and then jump to a radius of 0.499999/2 where we'd need to not
have a discontinuity in result for inner radius moving from 0.5 to
0.499999.
Changing from the current discontinuous behavior and moving to say a
polynomial (See attached image) :
// #declare LemonLeft  = lemon {
//    <-1.2,-0.5,0>, 0.0, <-1.2,0.5,0>, 0.0, 0.499999
    #declare LemonLeft  = polynomial { 2,
      xyz(2,0,0):1,
      xyz(0,2,0):1,
      xyz(0,0,2):1,
      xyz(1,0,0):-2*-1.2,
      xyz(0,0,0):pow(-1.2,2)-pow(0.49999,2)
      sturm
allows sturm - but then not open... I suspect if we want this smooth
transition into a sphere we might be stuck filtering whatever keywords
the lemon supports but our substitute object does not.
If we are going to jump to the 0.499999/2 radius on substitution as we
do today, I vote we go back to an error message.
Bill P.
Download 'lemonissue2.jpg' (103 KB)
Preview of image 'lemonissue2.jpg'
Date: 29 May 2016 13:33:01
Message: <574b27cd$1@news.povray.org>
>> it better ?)
> Suppose if someone is doing an animation or sequence of images, it might be
convenient to transition into a sphere then continue to shrink that sphere.
> If so, we are not really doing that today as we seem to be at a 0.5 radius and then
jump to a radius of 0.499999/2 where we'd need to not have a discontinuity in result
for inner radius moving from 0.5 to 0.499999.
Thanks you for your input, on that point as well as the noisy surface when radius is
exactly the minimal one.
It should be corrected with the new (and hopefully last) change on the lemon.
> If we are going to jump to the 0.499999/2 radius on substitution as we do today, I
If the vertices are identical, an error message is issued (same as for cylinder/cone)
If the third radius is too small, it is adjusted to the smallest value and a warning
is written, thus allowing sturm and open without problem. So, no more discontinuity,
but no shrinking either.
and for extra benefit, when the third radius is the minimal one, a sphere is used
instead of the torus part, removing the problem of noise on the surface due to
coincident surface.
Date: 30 May 2016 10:42:27
Message: <574c5153$1@news.povray.org>
cylinder/cone)
coincident surface.
Unfortunately, I am still seeing noise at the 0.5 radius with the
following code giving us the three rows in the attached image.
//----- Top set
// #declare LemonLeft  = polynomial { 2,
//   xyz(2,0,0):1,
//   xyz(0,2,0):1,
//   xyz(0,0,2):1,
//   xyz(1,0,0):-2*-1.2,
//   xyz(0,0,0):pow(-1.2,2)-pow(0.50000,2)
//   sturm
// #declare LemonCenter  = polynomial { 2,
//   xyz(2,0,0):1,
//   xyz(0,2,0):1,
//   xyz(0,0,2):1,
//   xyz(0,0,0):-pow(0.50000,2)
//   sturm
//----- Middle set
// #declare LemonCenter = lemon {
//    <0,-0.5,0>, 0.0, <0,0.5,0>, 0.0, 0.50
//----- Bottom set
       <-1.2,-0.5,0>, 0.0, <-1.2,0.5,0>, 0.0, 0.499999 sturm
       <0,-0.5,0>, 0.0, <0,0.5,0>, 0.0, 0.50 sturm
//----- All sets
#declare LemonRight  = lemon {
    <1.2,-0.5,0>, 0.0, <1.2,0.5,0>, 0.0, 0.500001 sturm
Bill P.
Download 'hg_495:52beb76993f0.jpg' (208 KB)
Preview of image 'hg_495:52beb76993f0.jpg'
Date: 30 May 2016 11:57:31
Message: <574c62eb@news.povray.org>
is exactly the minimal one.
cylinder/cone)
warning is written, thus allowing sturm and open without problem. So, no more
discontinuity, but no shrinking either.
coincident surface.
> Unfortunately, I am still seeing noise at the 0.5 radius with the following code
I agree there is still something on the surface, when used with a metallic reflection.
But the coincidence surface seems to not be the cause.
If anyone has a clue, feel welcome to share.
Download 'lo.png' (191 KB) Download 'lo.pov.txt' (2 KB)
Preview of image 'lo.png'
Date: 30 May 2016 12:21:32
Message: <574c688c$1@news.povray.org>
reflection.
seems it is tied to the computation when the sphere is used... Puzzling.
Date: 30 May 2016 12:46:08
Message: <574c6e50$1@news.povray.org>
reflection.
Interesting. Do you think it might be worth porting the lemon into the
current gitgub master branch for a test?
I'm not completely up on the differences compared to the Hg-povray
branch...
Bill P.
Date: 30 May 2016 13:37:58
Message: <574c7a76$1@news.povray.org>
reflection.
> Interesting. Do you think it might be worth porting the lemon into the current
> I'm not completely up on the differences compared to the Hg-povray branch...
> Bill P.
I should understand first why I have such noisy sphere. The master branch has changed
a lot of vector operations (for a better C++ like syntax), but the operations would be
the same. Hg-povray branch is "late", more based on stable 3.7 release.
Date: 30 May 2016 14:13:42
Message: <574c82d6$1@news.povray.org>
reflection.
>> Bill P.
changed a lot of vector operations (for a better C++ like syntax), but the operations
would be the same. Hg-povray branch is "late", more based on stable 3.7 release.
And you are lucky, I found why it was noisy... it needed a test. Committed & pushed,
should be available now.
Hopefully it's the last bug of it :-)
Date: 30 May 2016 14:58:34
Message: <574c8d5a$1@news.povray.org>
>>> Bill P.
Yes indeed! Looks great even without sturm. :-)
Bill P.
Date: 3 Jun 2016 14:08:54
Message: <5751c7b6$1@news.povray.org>
Am 26.05.2016 um 16:15 schrieb Le_Forgeron:
That should never happen. The syntax of an object MUST NOT change
depending on how it is represented internally.
You'll have to stick with an ovus-/lemon-specific parsing code, and just
silently ignore "sturm" if you replace the object.
Maybe a smarter way to approach this would be to first completely
construct an ovus/lemon, and in a "post-processing" step replace it with
a fitting sphere.
