POV-Ray : Newsgroups : povray.binaries.images : Ocean Server Time
27 May 2026 14:05:11 EDT (-0400)
  Ocean (Message 32 to 41 of 71)
Subject: Re: Ocean
Date: 2 Apr 2016 16:15:00
Message: <web.5700274442d9a4ac7a3e03fe0@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
> I recognise the island. It the one mentioned in Shakespeare’s play, “The
> Tempest”.
> “…’twixt the green sea and the azured vault...’ ;)
It what is written? It is a Devanagari?
> How to animate it?
It is necessary to think. :)
Subject: Re: Ocean
Date: 2 Apr 2016 18:03:15
Message: <570041a3$1@news.povray.org>
“The
>> Tempest”.
No that is corruption. I am posting with thunderbird using Unicode. It
should be plain English text.
Twixt the green sea and the azured vault
Twixt is old English for between.
>> How to animate it?
Yes, me too.
I found these. The insides are shown. Look at the pictures.
http://www.smsnoveltiques.com/referencemotionlamps.asp
https://www.realorrepro.com/article/Reproductions-in-motion
Regards
Subject: Re: Ocean
Date: 3 Apr 2016 02:54:56
Message: <5700be40@news.povray.org>
On 2-4-2016 21:32, Stephen wrote:
> On 4/2/2016 2:56 PM, LanuHum wrote:
>> Long ago in shop I photographed a pattern? (pictures,images?)
>> reproduction.
>> I don't see it realistic, but, I would like to simulate it for animation.
>> For me it is very beautiful!
> Tempest”.
> It is strikingly vibrant and unearthly.
> How to animate it?
> The only thing I can think of, is to find out how animated motion lamps
> work. They had a cylindrical outer and inner part and the inner cylinder
> rotated from the heat of the light. The outer cylinder had transparent
> areas that showed the motion. A quick google did not describe the
> technique.
> Examples:
> https://youtu.be/TT3trX6oSjk
> You get a short glimpse of the moving part here.
> https://www.youtube.com/watch?v=nzUSWjt3PWU
I may be missing something here, but is animation not very easy? just
rotate the inner cylinder. Essentially, the whole structure consists of
two moving semitransparent, superposed, image_maps.
Subject: Re: Ocean
Date: 3 Apr 2016 04:18:10
Message: <5700d1c2$1@news.povray.org>
Probably not. But it is mumble, mumble years since I have seen one and
was not sure how the effect was created. I thought that the glass
cylinders might have been moulded to give local lenses on the inside.
Will the illusion work with computer graphics using planer images?
What sort of masking is needed for the images and what frame rate to
use? These questions I will need to find an answer to.
I think that this might distract me from Elite Dangerous, for a while. :-)
Regards
Subject: Re: Ocean
Date: 3 Apr 2016 06:35:00
Message: <web.5700f0e042d9a4ac7a3e03fe0@news.povray.org>
Yes! Desires differ from opportunities...
Subject: Re: Ocean
Date: 3 Apr 2016 07:20:41
Message: <5700fc89$1@news.povray.org>
Hmm... that is an interesting approach I had not thought about. Variable
thickness of the inner cylinder might certainly be an interesting effect.
Good. It will keep you from grave mischief in the digital world. I may
want to explore a bit about superposition of images and such, without
the animation part. I think that ior and photons should be involved too
in the end.
Subject: Re: Ocean
Date: 3 Apr 2016 08:11:06
Message: <5701085a$1@news.povray.org>
Am 02.04.2016 um 22:10 schrieb LanuHum:
>> Tempest”.
To quote from Stephen's post (the message header, to be precise):
Subject: Re: Ocean
Newsgroups: povray.binaries.images
References: <56ffb693$1@news.povray.org>
 <web.56ffcf8542d9a4ac7a3e03fe0@news.povray.org>
Date: Sat, 2 Apr 2016 20:32:12 +0100
User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:38.0) Gecko/20100101
 Thunderbird/38.5.1
MIME-Version: 1.0
In-Reply-To: <web.56ffcf8542d9a4ac7a3e03fe0@news.povray.org>
Content-Type: text/plain; charset=utf-8; format=flowed
Note the "charset=utf-8".
The web interface to the newsgroups apparently fails to handle character
sets; newsreaders typically display the content properly.
Subject: Re: Ocean
Date: 4 Apr 2016 08:59:00
Message: <57026514$1@news.povray.org>
> in the end.
Proof of concept.
It needs more work on the inner cylinder* and the masking.
It is short and cyclic. Probably better to download it and watch it looping.
https://youtu.be/21Tb8_HIDp8
* Not that there are cylinders, it is planer.
Regards
Subject: Re: Ocean
Date: 4 Apr 2016 11:55:01
Message: <web.57028e3e42d9a4ac7a3e03fe0@news.povray.org>
> Proof of concept.
> Regards
>      Stephen
This toy can be made so:
#declare Light_waves = texture {pigment {
    agate
    color_map{[0 rgbt<1,1,1,0.9>]
              [1 rgbt<0,0,0,0.9>]}
    scale <1,10,1>
    translate -z * ANIMATION
#declare All = texture {
    texture {Sea}
    texture {Light_waves}
My idea more serious:
1. Create curves.
2. Insert shape keys
3. Use LanuHum,s exporter.
Good?
Download 'idea.jpg' (27 KB)
Preview of image 'idea.jpg'
Subject: Re: Ocean
Date: 4 Apr 2016 12:25:50
Message: <5702958e$1@news.povray.org>
>      agate
>      scale <1,10,1>
>      texture {Sea}
> 1. Create curves.
> Good?
Yes good but first one better. ;)
Regards
