POV-Ray : Newsgroups : povray.binaries.images : Ocean Server Time
27 May 2026 18:19:53 EDT (-0400)
  Ocean (Message 2 to 11 of 71)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Ocean
Date: 31 Mar 2016 15:12:02
Message: <56fd7682$1@news.povray.org>
On 3/31/2016 7:35 PM, Jaime Vives Piqueres wrote:
> I could not resist
> the temptation. ;)
They remind me of my time before the mast. :-)
They are really quite good. :-D
Regards
Subject: Re: Ocean
Date: 31 Mar 2016 15:13:12
Message: <56fd76c8$1@news.povray.org>
Am 31.03.2016 um 20:35 schrieb Jaime Vives Piqueres:
> Thanks to LanuHum for the inspiration... I read his post with the words
> "We can't" and "POV-Ray" on the same sentence, and I could not resist
> the temptation. ;)
> It's done with a sum of several f_ridged_mf() on a function
> height_field, media for the water and CIE_Skylight.inc for the sky. It
> could be saved as a mesh using HF_Square, but after some tests I decided
> to stick to the "live" height_field version, as it parses much faster.
> P.S.: The foam is still on the making...
I am freakin' impressed.
Subject: Re: Ocean
Date: 31 Mar 2016 17:00:03
Message: <56fd8fd3$1@news.povray.org>
   If that's a compliment from a true seaman, then I must have nailed it!
   But well, I must admit I've myself observed the sea a lot, both from
the coast and offshore: I used to go fishing with my father a lot during
summer when I was young... I think he had a Taylor 50, IIRC.
jaime
Subject: Re: Ocean
Date: 31 Mar 2016 17:12:00
Message: <56fd92a0$1@news.povray.org>
   Thanks!
   It was relatively easy once I found a simple example of f_ridged_mf()
that I could understand (thanks to an old post from JGR). I just added
it four times to the function at decreasing scales with decreasing
weights. I used it in a similar vein as a normal too. The resolution of
the function HF is 8192x8192, and it just takes under 3 min. to parse.
   The color for the media was also easy: SeaGreen from colors.inc seemed
perfect at first try for both the scattering and the absorption.
jaime
Subject: Re: Ocean
Date: 31 Mar 2016 17:49:24
Message: <56fd9b64@news.povray.org>
It is a compliment but not from a true seaman. I spent 16 years on
offshore oil rigs though. Two of them on semi submersibles. I spent many
an hour "wave watching". A glorious pastime almost as good as watching
the gas flare off before it was legislated against.
Hmm! just remembered. I was a lifeboat coxswain for a few years. Does
that count?
There is something fascinating about watching the sea. Ever the same
always different. From a helicopter, you can't tell how high you are,
fractal it is.
If you can render white caps or foam crests I will be mightily impressed.
Regards
Subject: Re: Ocean
Date: 31 Mar 2016 18:06:29
Message: <56fd9f65$1@news.povray.org>
El 31/03/16 a las 23:49, Stephen escribió:
> I spent 16 years on offshore oil rigs though.
   Well, then you must know how the sea looks almost as good as a true
seaman. :)
   Yes, just last weekend I was doing that. It was a beach with stones
instead sand, and looking at the pebbles was almost as fascinating.
> impressed.
   I'm on it, but it's not easy to get it convincing enough...
jaime
Subject: Re: Ocean
Date: 31 Mar 2016 19:27:49
Message: <56fdb275$1@news.povray.org>
> seaman. :)
Maybe better. I had a better view a hundred feet or so above the waves.
We used to watch the supply boats disappear in the troughs. A fine view
they got. Up and down, up and down. ;)
Oh yes. :-)
Are you on the Mediterranean or the Atlantic coast?
>> impressed.
That I believe. I spent weeks trying to get a good result using Tek's
isosurface, not very well. :(
http://www.tc-rtc.co.uk/portfolio/Stephen/366/index.html
Regards
Subject: Re: Ocean
Date: 31 Mar 2016 19:30:46
Message: <56fdb326$1@news.povray.org>
Very nice Jaime. I like the distance better than the foreground. I think
foam will help. Maybe in the Caribbean the water is that clean, but not
off New England. :)
Am 2016-03-31 17:49, also sprach Stephen:
I worked on this tub http://www.mysticwhalercruises.com/
One job I hated was "Balaska! Polish the bell!".
Summer sun on the open water, I'd be stripped down to my cut-offs and
bandana. I found out later the purpose was to draw the white pegs [1]
out of their cabins below and they'd come hang out on deck and *not*
watch me sweat. ;)
[1] On the cruise cabin assignment board in the land office, cabins were
assigned by gender. White pegs were single women. We loved cruises with
several white pegs...
dik
Subject: Re: Ocean
Date: 1 Apr 2016 02:52:35
Message: <56fe1ab3@news.povray.org>
> the temptation. ;)
You have hit it square on, Jaime!  Congrats indeed.
Subject: Re: Ocean
Date: 1 Apr 2016 03:13:11
Message: <56fe1f87@news.povray.org>
   Mediterranean (Valencia).
   Nice idea, but yes, the foam got a bit messy... ;)
jaime
