POV-Ray : Newsgroups : povray.binaries.images : Scattering media help Server Time
27 May 2026 12:30:18 EDT (-0400)
  Scattering media help (Message 1 to 10 of 24)
Subject: Scattering media help
Date: 25 Jan 2016 03:41:51
Message: <56a5dfcf@news.povray.org>
I'm trying to add some haze as seen in the attached image I rendered a
long time ago. Unfortunately, I lost the code I used at the time, and my
current code is not working at all. Can anyone please assist? Here is my
current non working code, thanks.
#local atmos_material = material
	// check TexQual here?
	texture {pigment {gamma_color_adjust(1) transmit 1}}
	interior
		media
			scattering
				4, color rgb <0.2,0.4,1.0>/10000	// crappy approximaion of TerraPOV
value
				extinction	1
			samples	1,1
			density
				cylindrical
				poly_wave	0.25
				color_map
					[0	srgb 1.0]
					[1	srgb 0.0]
	scale	city_radius
	rotate	x * 90
Download 'gh_scene_spinner_interior_06.png' (477 KB)
Preview of image 'gh_scene_spinner_interior_06.png'
Subject: Re: Scattering media help
Date: 25 Jan 2016 04:30:06
Message: <web.56a5e94e53fb38f933c457550@news.povray.org>
Here's a 'complete' scene including your scattering media (with a camera and a
light-- having a LIGHT is important for seeing this media type) plus a HOLLOW
container object for the media to be enclosed in. (A simple sphere here.) At
least you'll see *something* now! ;-)
Note a few changes: I changed the material's pigment color to plain srgbt 1, for
simplicity. I eliminated the '10000' divisor in your media color, as that would
have made the media way too dark to see (or not enough 'density'). I also
commented-out the scale and rotation at the end of the material statement;
that's probably best done in the OBJECT instead. (But note that scaling an
object with media also scales the media density, which you may not want.
Here's a kind of rule-of-thumb: If you scale up the size of the final object,
say scale 10, then you should probably scale the media itself to 1/10, to
compensate. *Then* experiment with further scaling if you want.)
#version 3.7
global_settings{assumed_gamma 1.0}
  perspective
  location  <0, 0, -5>
  look_at   <0, 0,  0>
  // angle 67
light_source {
  0*x  // light's position (translated below)
  color rgb <1,1,1>
  translate <-20, 40, -20>
     material
       pigment {srgbt 1}}
       interior
         media
          scattering
         4, color rgb <0.2,0.4,1.0>// crappy approximaion of TerraPOV value
          extinction 1
          samples 1,1
          density
               cylindrical
               poly_wave 0.25
              color_map
                 [0 srgb 1.0]
                 [1 srgb 0.0]
 //scale 10
 //rotate x * 90
sphere{0,1
 hollow // IMPORTANT!
 material{atmos_material}
Date: 25 Jan 2016 04:50:06
Message: <web.56a5ee9e53fb38f933c457550@news.povray.org>
Forgot to mention that your 'samples' values of 1,1 in the media are *really*
low. Increase them to, say, 50,50 for much better quality (but a slower render.)
Date: 25 Jan 2016 07:34:36
Message: <56a6165c$1@news.povray.org>
Hardly slower, and only use 1 (one) parameter as defaults are: intervals
1 and method 3.
You can easily use samples 100 without noticeable slowing down.
Date: 25 Jan 2016 09:05:01
Message: <web.56a62b6553fb38f9ad6fa18f0@news.povray.org>
Did you make sure that the object containing the media has "hollow on"?
Date: 25 Jan 2016 14:38:41
Message: <56a679c1@news.povray.org>
>      interior
>          media
>              scattering
>                  extinction    1
>              samples    1,1
Ok ONLY if using sampling method 1 or 2.
For the default method 3, use only a single value NO SMALLER than 3. In
your case, the default of 10 should be correct.
NEVER set intervals but rely on the default value of 1. Larger values
dramaticaly slow you down and can introduce artefacts.
>              density
>                  cylindrical
>                  poly_wave    0.25
>                  color_map
>                      [0    srgb 1.0]
>                      [1    srgb 0.0]
>      scale    city_radius
>      rotate    x * 90
Make absolutely sure that you set any container object to hollow.
Also, if enclosed into another object that is not the container, that
object to need to be set as hollow.
If you use a world sphere, that MUST be set as hollow.
Date: 25 Jan 2016 15:06:17
Message: <56a68039$1@news.povray.org>
I should have clarified. I can *see* the media, it is either the right
color but too dense if I set the scattering to <0.2,0.4,1.0>, or it is
properly dense but too dark. There seems to be no way to set the density
independently of the color.
I can't scale the container object because the container object is
already the correct size to begin with. Scaling it any further would
make it the wrong size.
Mike
Date: 25 Jan 2016 15:07:47
Message: <56a68093$1@news.povray.org>
Here is the code for the container object:
#local atmos_object = difference
	merge
		cylinder {+z*(city_length/2), -z*(city_length/2), city_radius}
		Spheroid(+z*(city_length/2),
<inner_shell_radius3,inner_shell_radius3,inner_shell_bulge>)
		Spheroid(-z*(city_length/2),
		hollow
	hollow
	material {atmos_material}
Date: 25 Jan 2016 15:30:01
Message: <web.56a6839753fb38f933c457550@news.povray.org>
> Hardly slower...
Interesting. On my old single-core Windows machine, samples of 50 is definitely
slower than samples of 1-- which I'm used to seeing anyway, in POV-Ray versions
3.61 and v3.62. As I understand, v3.7 was basically designed for multi-core
machines, not my old 'clunker.' (In fact, I've noticed that all of my older 3.62
scenes render a bit slower in v3.7, across the board.)
*Someday*, I'll upgrade to a multi-core machine, and join the 20th century
(oops, I mean the 21st century.)  ;-)
Date: 25 Jan 2016 15:47:00
Message: <56a689c4$1@news.povray.org>
Am 25.01.2016 um 21:06 schrieb Mike Horvath:
>> camera and a
>> HOLLOW
>> here.) At
The question to be examined here is this:
Is the media not to your liking because it differs from the original
image, or because you think it looks wrong?
Your original image may have been generated by a version of POV-Ray that
got the maths wrong, for instance because it didn't use proper gamma
handling or because of certain bugs that have been eliminated by now.
If you use "assumed_gamma 1" in the global settings, and "extinction 1"
in the scattering media declaration, then the results will be physically
accurate under the given lighting conditions and for a medium that is
purely scattering. There is no additional tweakable -- nor is there any
physical justification for one -- that you could use to mess with the
brightness.
Unless the medium is supposed to be partially absorbing (in which case
you could model this by setting the "extinction" parameter to a value
>1, or explicitly adding an absorbing component to the media statement)
or glowing (which you could model by setting the "extinction" parameter
to a value <1, or explicitly adding an emitting component).
So if you want realism, you should stick to the current settings. If on
the other hand you want a certain effect and screw realism, you are free
to mess with the "extinction" parameter to brighten up the haze.
