![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 25.01.2016 um 22:56 schrieb Mike Horvath:
> On 1/25/2016 4:48 PM, clipka wrote:
>> Am 25.01.2016 um 22:46 schrieb Mike Horvath:
>>> On 1/25/2016 4:37 PM, clipka wrote:
>>>> Think of it this way: If you reduce the density of a gas, you reduce
>>>> the
>>>> probability that any given light ray hits a gas molecule and is
>>>> diverted
>>>> from its original direction to a new one: Light en route to the camera
>>>> from the background has less chance of being diverted /away/ from the
>>>> camera, while light en route to anywhere in the scene from a light
>>>> source has less chance of being diverted /towards/ the camera.
>>> I still don't understand why lowering the density of the gas darkens the
>>> scene more than not having any media at all.
>> Are you absolutely sure it does, and you're not seeing the effect from
>> any other difference?
> I've attached two renders. One is with no media at all. The other is
> with the media, but the scattering color set to rgb 0.
This is seriously odd, entirely unexpected, and to my present knowledge
as a developer only explicable by a bug.
As I cannot reproduce the behaviour here with a simple scene, I would
kindly ask you to post some minimalistic version of your scene as an
attachment in povray.binary.scene-files so I can have a closer look at it.
Also, please let me know exactly which version of POV-Ray you are using.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 1/25/2016 4:46 PM, clipka wrote:
> I must consequently assume that the "too dark" effect you observe is
> instead due to a lack of light /scattered to/ the camera, but to get
> more of this light you need a /higher/ density rather than a lower one.
I found the problem. It had to do with the gas container object having
the same radius as the outer metal shell. When I increased the radius so
that the surfaces were not touching, the darkness went away and the
scene rendered normally.
Sorry for the trouble.
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 25.01.2016 um 23:15 schrieb Mike Horvath:
Still a bit odd, but I guess the coincident surface problem can cause
any number of side effects.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It would be cool if, instead of messing with the sizes of objects, you
could flag one or another object as dominant. I.e. when they touch, the
dominant object's textures take precedence.
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
