![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 1/25/2016 3:46 PM, clipka wrote:
> Am 25.01.2016 um 21:06 schrieb Mike Horvath:
>> On 1/25/2016 4:28 AM, Kenneth wrote:
>>> Here's a 'complete' scene including your scattering media (with a
>>> camera and a
>>> light-- having a LIGHT is important for seeing this media type) plus a
>>> HOLLOW
>>> container object for the media to be enclosed in. (A simple sphere
>>> here.) At
>>> least you'll see *something* now! ;-)
>> I should have clarified. I can *see* the media, it is either the right
>> color but too dense if I set the scattering to <0.2,0.4,1.0>, or it is
>> properly dense but too dark. There seems to be no way to set the density
>> independently of the color.
> The question to be examined here is this:
> Is the media not to your liking because it differs from the original
> image, or because you think it looks wrong?
Because it differs from the original image. Can I lower the density
without changing the color?
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Mike
Can I use a density statement? How do I make a density function that
simply lowers the density to 1/10 everywhere?
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 25.01.2016 um 22:00 schrieb Mike Horvath:
>>>> camera and a
>>>> HOLLOW
>>>> here.) At
I thought I had given a clear enough answer, but here it is again in a
nutshell:
Yes, you /can/ do that by reducing the "extinction" parameter. /But/
tampering with the setting will void your warranty (read: break physical
realism).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Kenneth" <kdw### [at] gmail com> wrote:
> *Someday*, I'll upgrade to a multi-core machine, and join the 20th century
> (oops, I mean the 21st century.) ;-)
When you do, you'll wonder how you got along without one.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> nutshell:
> realism).
I've lowered extinction to 1/100000000 and it has zero effect. Here is
the code I am using now.
Mike
#declare atmos_material = material
texture {pigment {color rgbt 1}}
interior
media
scattering
4, rgb <0.2,0.4,1.0>/10000
extinction 1/100000000
samples 10
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 25.01.2016 um 22:15 schrieb Mike Horvath:
>> Mike
Of course you can use a density statement -- you're already doing that.
To lower the density to 1/10 everywhere, all you need to do is divide
all the values in the color_map by 10 (but use rgb instead of srgb instead).
/But/ by lowering the density you not only make the background more
visible again -- you also reduce the scattering effect.
Think of it this way: If you reduce the density of a gas, you reduce the
probability that any given light ray hits a gas molecule and is diverted
from its original direction to a new one: Light en route to the camera
from the background has less chance of being diverted /away/ from the
camera, while light en route to anywhere in the scene from a light
source has less chance of being diverted /towards/ the camera.
I might also add that dividing the scattering media colour by 10 has
exactly the same effect as dividing the density values by 10.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I still don't understand why lowering the density of the gas darkens the
scene more than not having any media at all.
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 25.01.2016 um 22:35 schrieb Mike Horvath:
>> nutshell:
>> realism).
Then I must confess I have no idea what you are talking about when you
say you want to "lower the density without changing the colour" because
it is "too dark" when "properly dense".
If extinction doesn't have any noticeable effect, it means that the "too
dark" effect you observe is not due to a lack of light from the
background getting through to the camera.
I must consequently assume that the "too dark" effect you observe is
instead due to a lack of light /scattered to/ the camera, but to get
more of this light you need a /higher/ density rather than a lower one.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 25.01.2016 um 22:46 schrieb Mike Horvath:
Are you absolutely sure it does, and you're not seeing the effect from
any other difference?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I've attached two renders. One is with no media at all. The other is
with the media, but the scattering color set to rgb 0.
Mike
Download 'gh_scene_spinner_cutaway_e_no_media.png' (91 KB)
Download 'gh_scene_spinner_cutaway_e_zero_density.png' (77 KB)
Preview of image 'gh_scene_spinner_cutaway_e_no_media.png'
![gh_scene_spinner_cutaway_e_no_media.png](/povray.binaries.images/attachment/%3C56a69a08%40news.povray.org%3E/gh_scene_spinner_cutaway_e_no_media.png?ttop=413793&toff=150&preview=1)
Preview of image 'gh_scene_spinner_cutaway_e_zero_density.png'
![gh_scene_spinner_cutaway_e_zero_density.png](/povray.binaries.images/attachment/%3C56a69a08%40news.povray.org%3E/gh_scene_spinner_cutaway_e_zero_density.png?ttop=413793&toff=150&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
