POV-Ray : Newsgroups : povray.binaries.images : Colony ship Server Time
5 Jul 2024 16:08:30 EDT (-0400)
  Colony ship (Message 31 to 40 of 92)
Subject: Re: Colony ship
Date: 25 Jan 2016 07:38:28
Message: <56a61744$1@news.povray.org>
On 25-1-2016 10:02, Sven Littkowski wrote:
> How did you make the trees? I could use that technology for some of my
> scenes, too. :-)
Looks like POV-Tree...
Date: 25 Jan 2016 07:44:08
Message: <56a61898$1@news.povray.org>
> scenes, too. :-)
Looks like POV-Tree:
http://web.archive.org/web/20071101052625/propro.ru/go/Wshop/povtree/download.html
Date: 25 Jan 2016 09:05:01
Message: <web.56a62b09ed6e77c8ad6fa18f0@news.povray.org>
Mike Horvath <mik### [at] gmailcom> wrote:
> On 1/19/2016 11:08 AM, clipka wrote:
> > Am 19.01.2016 um 02:48 schrieb Mike Horvath:
> >> Here's my latest (incomplete) render. However, I don't understand why
> >> the planet in the background is so bright compared to the last render.
> >> Can anyone explain this? Is it the area light causing this or the
> >> reflections? I'm using the same area light as in the last render and I
> >> don't understand why the planet appears to be extra lit. Thanks.
> > Did you make sure that the light properly falls off with distance?
> What values would you recommend? It is a linear area light.
Presuming the area light is supposed to simulate a structure somewhat akin to a
long cylinder, I would set fade_distance to the radius of that structure; to get
the proper behaviour along the length of the area light, I would suggest using
area_illumination.
For realism, fade_power should always be 2. Note that you may have to
significantly increase the light source's brightness.
Date: 25 Jan 2016 14:26:40
Message: <56a676f0$1@news.povray.org>
Le 16-01-25 04:01, Sven Littkowski a écrit :
> Nice inside landscaping. Shouldn't all building be of the same shape, in
> regards to ensure all over the cylinder is the same mass distribution?
> Otherwise, mass unbalance might cause problems while spinning. I don't
> mean the shape of buildings from back to front, but beside each other.
You just need the building to be similar across the axis. Side by side,
it don't mather.
Also, you can have a small building containing huigh mass cargo, and
large ones used by peoples that have about the same overall mass.
Finaly, there is probably a network of balast "underground" to help
balancing the whole thing.
Date: 25 Jan 2016 14:50:51
Message: <56a67c9b$1@news.povray.org>
I think the scene would look less interesting if the buildings are the
same. Anyway, if I were to make changes, I would go in the *other*
direction. I.e. make the scene look even *more* organic.
Mike
Date: 25 Jan 2016 14:52:28
Message: <56a67cfc$1@news.povray.org>
> area_illumination.
I experimented with fade_distance by setting it to the radius of the
lamp object, but it makes the scene too dark.
Good tip, thanks.
Mike
Date: 25 Jan 2016 14:57:19
Message: <56a67e1f$1@news.povray.org>
> scenes, too. :-)
It may be TomTree.
http://tkgate.sourcearchive.com/documentation/2.0~b8/TOMTREE_8inc-source.html
I don't recall for sure.
Mike
Date: 25 Jan 2016 15:25:00
Message: <web.56a6837ded6e77c8566b73360@news.povray.org>
> > area_illumination.
Multiply the light source's color by (1 + pow (D / R, 2)) / 2, where R is the
fade_distance, and D is the radius of the colony interior.
Date: 25 Jan 2016 17:10:51
Message: <56a69d6b$1@news.povray.org>
Question: Should the density of the gas in the habitat area be
significantly lower around the central axis than toward the outer edges
of the cylinder? Or is it safe to ignore such a gradient?
Mike
Date: 25 Jan 2016 17:18:04
Message: <56a69f1c$1@news.povray.org>
>>> area_illumination.
That worked, thank you!
Mike
