POV-Ray : Newsgroups : povray.binaries.images : Gamma issues again Server Time
2 Jun 2024 11:45:43 EDT (-0400)
  Gamma issues again (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Gamma issues again
Date: 30 Dec 2015 08:40:01
Message: <web.5683ddac61c3ffe833c457550@news.povray.org>
> Am 28.12.2015 um 04:14 schrieb Kenneth:
> Later however, I found the time to revisit the issue, and found that
> good results /can/ be obtained; the key is to split up the colour
> information into brightness (i.e. the weighted sum of the colour
> channels) and chroma (i.e. the relative balance between the colour
> channels), interpolate the brightness non-linearly and the chroma
> linearly, and then re-combine the two properties into the new result colour.
It took me awhile to absorb your explanation (which is excellent, as always.)
Although the subject of gamma in POV-Ray isn't new to me, this new (subtle?)
topic of chromaticity/brightness certainly is. I have to admit that I never
noticed any 'flaws' in color/brightness gradations in my scenes (having 'worked
around' any odd-looking surprises, at least to my own satisfaction.) But your
explanation of the underlying problems-- and your new tools to solve them-- are
real 'eye-openers', if you'll pardon the pun.  ;-) I'm happily amazed that you
(and Warp) continued to think about this topic.
Thanks for your hard work!
Date: 31 Dec 2015 02:48:53
Message: <5684dde5$1@news.povray.org>
Of course! I should have known; I put them at the end of the block which
makes no sense. Thanks!
Date: 4 Jan 2016 05:06:57
Message: <568a4441$1@news.povray.org>
Never realised that this had been implemented - great work!
What chroma values are you using?
Have you heard of MacAdam ellipses?
https://en.wikipedia.org/wiki/MacAdam_ellipse
My idea is that if you convert your chroma values to a colour space with
almost equal-sized MacAdam's ellipses, you can then just do a linear
interpolation in that colour space, and you should get "perfect" hue
blends for any colours.
Date: 4 Jan 2016 07:35:00
Message: <web.568a650b61c3ffe8ad6fa18f0@news.povray.org>
Actually I'm just using the RGB values, normalized to identical brightness, so
it's a particular slice of RGB space if you will. Not sure what official chroma
format that corresponds to.
While this means that I'm doing the interpolation on three values instead of two
(which might seem like doing extra work), on the other hand it avoids the
computations required to convert from RGB to chroma and back, so I guess it
might even be faster this way -- and I think it's more straightforward and
easier to understand, at least for people who don't wrap their head around
colour spaces on a daily basis.
It also has the benefit of being easily adaptable to a spectral colour model,
which I tend to keep in the back of my head when working on POV-Ray's internal
colour maths.
That might be a neat addition, but at present I don't think it's really
necessary. There's plenty of stuff ranking higher on the agenda right now.
Feel free to do some research on this topic though -- while I don't have much
time to invest into this matter, I'm still interested in it.
Date: 4 Jan 2016 11:05:30
Message: <web.568a970f61c3ffe8566b73360@news.povray.org>
Sounds very interesting.  I've been wondering about a perceptually linear color
space, though none that I have seen looks linear to my own eyes--not Munsell,
not CIELAB.  (I am hearing of CIELUV for the first time, though.)
However, it strikes me as overkill for a ray tracer, so I agree with Clipka that
it should be low priority.
Date: 4 Jan 2016 11:30:39
Message: <web.568a9d6d61c3ffe8ad6fa18f0@news.povray.org>
There is no such thing as a perceptually linear color space. None that can be
represented in cartesian space at any rate.
Date: 4 Jan 2016 11:30:55
Message: <568a9e3f$1@news.povray.org>
There is Yu'v' or Yu*v* which is an improved (more perceptually linear)
version of Yuv. FWIW that colour space is commonly used in the
specification of colour coordinates of LCDs. For those it is important
applied to red, green, blue or white.
Indeed, especially as you often just manually add in some additional
control points to get the effect you want. Adding full GPU support is
far more pressing :-)
Date: 5 Jan 2016 23:39:39
Message: <568c9a8b$1@news.povray.org>
I've never really understood the big deal about perceptually uniform
color spaces. Compare to sound compression. There it makes sense. You
save disk space. But the color spaces try to muck things up. Whereas in
music a F remains an F and a C remains a C.
Mike
Date: 6 Jan 2016 04:49:49
Message: <568ce33d$1@news.povray.org>
>> can be
It doesn't have anything to do with compression to save disk space. And
when converting between colour spaces the colour remains physically the
same, just like 1 inch is the same as 25.4 mm, two different ways to
conceptually describe the same physical thing.
The idea of using a perceptually linear colour space is that then the
"distance" between two colours looks the same "difference" to a human no
matter what colours are used. This is not the case with sRGB, for
example the difference between (0,0,0) and (0,128,0) looks much "bigger"
than between (0,128,0) and (0,128,128), even though the distance is 128
in both cases. So using a distance in sRGB space would be quite useless.
In fact, there's a metric called "delta-E" which is used extensively in
many indsutries where colour is important (clothing, painting, make-up,
plastics, food, printing etc) that is exactly the "distance" between two
colours. However it is calculated in a (near) perceptually linear colour
space, and scaled so that a delta-E of 1.0 is "just visible" by most
humans. It is then a very useful number indeed.
Date: 6 Jan 2016 06:18:29
Message: <568cf805$1@news.povray.org>
Am 06.01.2016 um 10:49 schrieb scott:
Actually that colour space is nowhere near perceptually linear --
perceptually equidistant might be a more fitting description.
If you take two arbitrary colours in that colour space, and try to
interpolate them, you'll usually get a nasty surprise.
It's a bit akin to map projections, where a projection that lets you
easily judge areas will be useless to find the shortest route between
two points, let alone identify the point smack halfway between them.
