POV-Ray : Newsgroups : povray.binaries.images : Moon rendering (prototype) Server Time
25 Jun 2026 15:41:49 EDT (-0400)
  Moon rendering (prototype) (Message 20 to 29 of 49)
Subject: Re: Moon rendering (prototype)
Date: 5 Oct 2015 20:10:03
Message: <5613115b$1@news.povray.org>
Am 06.10.2015 um 00:45 schrieb David Given:
> Interestingly the slowest part of the
> process is Povray thinking about the mesh after I've passed it the data.
> Is it generating a bounding box octree? If so, it's working, because the
> rendering is amazingly fast...
That's indeed what happens (except that it's a KD-tree :))
Date: 5 Oct 2015 20:14:30
Message: <56131266$1@news.povray.org>
Am 06.10.2015 um 01:05 schrieb David Given:
> And here's another one (yeah, yeah, I know you're sick of these by now);
No - actually, not at all.
> My procedural noise needs a *lot* of work,
I think the terrain looks gorgeous.
> and there's something very
> odd about the sea texture. As does the surface texture, for that matter.
Waves pattern?
Moiree effect, I'd guess.
Date: 16 Dec 2015 07:01:26
Message: <56715296$1@news.povray.org>
What exactly is causing those anomalies in Earth's gravity that cause
the ocean surface to be lower at some regions and higher at some other
regions (or similar effects on the dust on the moon)?
On 03.10.2015 06:28, Thomas de Groot wrote:
> On 3-10-2015 12:57, Stephen wrote:
>> On 10/3/2015 10:16 AM, clipka wrote:
>>>> This is also true for our own Earth in fact. Local variations of the
>>>> >gravitational field make the oceans' surface vary by several (tens of)
>>>> >meters, sometimes over quite short distances.
>>> I did know/that/  - but tens of meters is still quite a shot from a
>>> kilometre.
>> It certainly is. Mind boggling actually.
> That is indeed true. Tells something about the composition of the Moon's
> interior.
>>> But did you also know that fast-flowing rivers are higher in the middle
>>> than at the banks - sometimes by as much as half a meter?
>> Not the value but I am sure you can see it, on some rivers.
> Ah yes. I don't remember exactly why that is: something to do with the
> drag along the border?
Date: 16 Dec 2015 07:42:13
Message: <56715c25$1@news.povray.org>
That is because the Earth's density is not constant and varies quite a
lot. A mountain (and its roots) is a massive object for instance that
deviates gravity. A pendulum is thus attracted towards the mountain when
you are standing at its base. Very, very slightly of course. Those
differences describe the /geoid/, the "true" shape of the Earth. See for
instance this:
https://www.quora.com/If-you-were-to-measure-gravity-on-the-surface-of-the-ocean-over-the-deepest-place-in-the-world-would-it-be-9-81-ms-s2-Or-would-water-have-less-gravitational-pull-than-a-mass-of-rock
Date: 16 Dec 2015 07:45:49
Message: <56715cfd$1@news.povray.org>
instance this:
or:
https://en.wikipedia.org/wiki/Gravity_of_Earth
Date: 16 Dec 2015 07:55:59
Message: <56715f5f$1@news.povray.org>
...and I just remembered the term mascon:
https://en.wikipedia.org/wiki/Mass_concentration_%28astronomy%29
Date: 16 Dec 2015 09:55:00
Message: <web.56717a40361b309ad6fa18f0@news.povray.org>
Differences in material composition, with differences in density.
Date: 16 Dec 2015 17:59:31
Message: <5671ecd3@news.povray.org>
Thanks to both of you, Thomas and Clipka. Yes, I assumed it is the
amount of matter, like mountains or valley which have the one or another
influence. But I wonder, if also the TYPE OF MATTER has influence, too.
Example: I wonder, if a iron sphere of 10,000 km diameter produces the
same gravity as a styrofoam sphere of 10,000 km diameter. I believe, not
only the amount of matter matters, but the type of matter matters, too.
Am I right?
Date: 16 Dec 2015 20:21:02
Message: <56720dfe$1@news.povray.org>
> Am I right?
As the sphere of iron is probably about 5 times as dense as your
styrofoam, even after it have collapsed from it's own mass a few Km
down, the iron sphere will have a much greater gravity than the styrene
one. It all depends on the average density of the planete, whitch
dictate it's total mass, whitch, with the radius, determine the surface
gravity.
A planet made entirely from water would be about 5 times larger than the
Earth to have about the same surface gravity, and an escape velocity
about 5 times higher.
Date: 17 Dec 2015 07:17:29
Message: <5672a7d9$1@news.povray.org>
Thanks for the answer, Alan. I think, the more an element is located at
the end of the elements table (all known elements), the more gravity it
is producing. I asked those previous questions, because I am working
there on some idea, but can't really speak yet about it.
Great subject, great group of people here. Big thanks to everyone!
