If you've seen the sample illustration for SphereSweep in the Object
Collection, you have noticed that the cockpit is empty. I plan to
rectify this, so long as The Google has not (yet) unveiled its
autonomous airplane. The white rim at the top of the hat presents
another opportunity to show off how the module works with trace().
Of course, a photorealistic human being would be its own Object
Collection module.
All rights reserved for this illustration, but the SDL for the completed
figurine will eventually find its way into the GNU-LGPL. When that will
be depends on how soon I grok the math behind B-splines.
Download 'design_pilot.jpg' (48 KB)
Preview of image 'design_pilot.jpg'
> Collection module.
Regards
> Collection module.
I'm studying your patch.
> Collection module.
thank you.
I'm glad someone finally got around to this.
On 08/10/2015 04:52 PM, Cousin Ricky wrote:
> [...] the SDL for the completed
Progress on the B-spline front. The gray curves are POV-Ray native
sphere_sweeps. The colored circles were positioned using a rather
profligate algorithm, but I have to understand the math a bit more than
I do now before I can optimize it.
Download 'b-spline_tryout.png' (19 KB)
Preview of image 'b-spline_tryout.png'
If it can help you, for all spline types, despite the visual effect,
there is no influence of one coordinate axis on any other axis.
Also, stick to one kind of spline when learning, you will be able to
generalize later, but mastery of one type (instead of a small bit of
many types) is the path that is probably the best.
So I noticed, and it has already helped. In SphereSweep 1.0, the code
was simplified by treating the radius as merely a 4th dimension tacked
onto the spline position.
I've already had a decent grasp of Bézier splines for several years now,
but have not included them in SphereSweep because they are not supported
by the sphere_sweep primitive. As my original rationale for writing
this module was to circumvent the flaws in the sphere_sweep primitive, I
decided to prioritize B-splines.
However, with interest in Bézier splines awakened in the past couple of
weeks, they are definitely on the table for a future version. I already
have a sketchy idea of how to make them 1st-derivative continuous with
little pain to the user.
Natural spline and quadratic spline sphere_sweeps aren't natively
supported either, but since they /are/ supported by the experimental
spline feature, they were trivial for me to include from day one.
As the experimental spline feature already supports linear and cubic
splines, and as my brain is not as agile as it was when I was 11, I feel
no pull to try to understand these. (Except than the linear spline is
intuitively obvious.)
