POV-Ray : Newsgroups : povray.binaries.images : An artifact when rendering torus(negative major_r) Server Time
16 Jun 2024 00:32:47 EDT (-0400)
  An artifact when rendering torus(negative major_r) (Message 1 to 10 of 19)
Subject: An artifact when rendering torus(negative major_r)
Date: 3 Apr 2015 09:20:01
Message: <web.551e92b74514bfb213709ea20@news.povray.org>
This is the picture
Download 'bugreport_1.png' (22 KB)
Preview of image 'bugreport_1.png'
Subject: Re: An artifact when rendering torus(negative major_r)
Date: 3 Apr 2015 10:10:00
Message: <web.551e9e6c88bb499a13709ea20@news.povray.org>
And here is the scene file:
http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.551e94cd7c9493f713709ea20%40news.povray.org%3E/
Date: 3 Apr 2015 10:20:01
Message: <web.551ea0b388bb499a13709ea20@news.povray.org>
I made two animations about this.
https://www.youtube.com/watch?v=PKpVpUucw3g
The second is the same camera setting, but just this object:
torus{
-0.01247, 0.02357
rotate <-90,0,0>
pigment{rgb<0.34,0.38,0.12>}
https://www.youtube.com/watch?v=8Pj7F41Tfyo
Date: 5 Apr 2015 01:42:40
Message: <5520cb50$1@news.povray.org>
On 04/03/2015 09:16 AM, And wrote:
> This is the picture
I've found tori to be artifact-prone whenever the major radius is less
than the minor radius.  With negative major R, I've gotten bounding
artifacts.  With zero major R, the entire object is one big coincident
surface artifact.  With major R less than half minor r, I get artifacts
with CSG merge, although I have found a workaround for my particular
situation.  I suspect that this last artifact can show up with r > R >
r/2, but I haven't tried to come up with such a scenario.
These problems are probably due to the way the polynomial object works.
  (The torus primitive is nothing more than a garden variety polynomial,
with some optimized bounding.)
Have you tried the sturm keyword?  (I'm really sleepy now, and haven't
yet looked at your code.)
Date: 6 Apr 2015 11:05:01
Message: <web.55229ffd88bb499a123791000@news.povray.org>
> > This is the picture
Ok, thank you. I will test it tomorrow.
Date: 7 Apr 2015 12:20:01
Message: <web.552402f488bb499a123791000@news.povray.org>
intersection{
    torus{
    0.01247, 0.02357
    rotate <-90,0,0>
    inverse
    sphere{
    <0,0,0>,0.02
Download 'poly torus_1.png' (24 KB)
Preview of image 'poly torus_1.png'
Date: 7 Apr 2015 12:30:01
Message: <web.552405c288bb499a123791000@news.povray.org>
#macro Poly_Torus(_major_r, _minor_r)
#local R = _major_r;
#local r = _minor_r;
#local poly_obj =
polynomial{
4,
xyz(4,0,0):1,
xyz(0,4,0):1,
xyz(0,0,4):1,
xyz(2,2,0):2,
xyz(0,2,2):2,
xyz(2,0,2):2,
xyz(2,0,0):-2*R*R - 2*r*r,
xyz(0,2,0):-2*R*R - 2*r*r,
xyz(0,0,2):2*R*R - 2*r*r,
xyz(0,0,0):pow(R*R - r*r,2),
poly_obj
intersection{
    sphere{
    <0,0,0>,0.02
    object{
    Poly_Torus(0.01247, 0.02357)
    inverse
Download 'poly torus_2.png' (26 KB)
Preview of image 'poly torus_2.png'
Date: 8 Apr 2015 13:15:51
Message: <55256247$1@news.povray.org>
On 07/04/2015 17:28, And wrote:
> intersection{
>      sphere{
>      <0,0,0>,0.02
>      object{
>      inverse
I liked the shape and decided to animate it rotating.
http://youtu.be/frVgXyupZX8
I am not too sure about the shading. It is as if the normals flipped
from one half to the other.
The material is a spiral1 pigment with a colour map.
To straighten the spiral I changed your code to:
intersection {
	torus {
		0.012470,0.023570
		sturm
		texture{ Spiral_Texture }
		rotate    <-90.0,0.0,0.0>
	sphere {
		0.0, 0.020000
	scale     <200.0,200.0,200.0>
I'm not sure why putting the texture on the torus straightens it out.
Regards
Date: 9 Apr 2015 02:35:08
Message: <web.55261d3f88bb499a5335aca40@news.povray.org>
> > intersection{
> >      sphere{
> >      <0,0,0>,0.02
> >      object{
> >      inverse
> intersection {
>  torus {
>   0.012470,0.023570
>   sturm
              here lack of inverse
>  sphere {
>   0.0, 0.020000
> Regards
>      Stephen
.. this is what I rendered.
Download 'torus test2 1.png' (168 KB)
Preview of image 'torus test2 1.png'
Date: 9 Apr 2015 02:45:01
Message: <web.55261ed188bb499a5335aca40@news.povray.org>
And the polynomial version:
It is still there, but not so visible.
Download 'torus test2 1 poly.png' (182 KB)
Preview of image 'torus test2 1 poly.png'
