POV-Ray : Newsgroups : povray.binaries.images : Spinner colony (again) Server Time
27 May 2026 19:37:30 EDT (-0400)
  Spinner colony (again) (Message 10 to 19 of 59)
<<< Previous 9 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Spinner colony (again)
Date: 11 Feb 2015 00:06:23
Message: <54dae34f@news.povray.org>
Le 15-02-10 13:11, Mike Horvath a écrit :
> On 2/9/2015 7:06 PM, Alain wrote:
>> I see two solutions:
>> 1 - Place the domes closer to the station's body, maybe in a circle
>> around it and push the pannels outward beyong the domes.
> This is interesting. This would induce "gravity", but the exposure to
> the sun would not be as good since the domes would all face inwards.
I did not mention turning the domes around, just move them around in a
circle pattern keeping the orientation the same.
By the way, you do need at least some gravity for the agridomes. Plants
don't grow correctly without some gravity.
If there is no gravity, you'll probably be limites to unicellular algae,
and the agridomes would be changed into agritanks...
>> 2 - Keep the current geometry, but rotate the domes or pannels 90°
>> arount the main axis of the station.
>> Alain
> Not sure if I understand. You mean at right angles with respect to each
> other? I think Le_Forgeron has a better idea in this case.
Just keep the solar pannels as they are, and place the domes on an arm
going up and down relative to the present image.
> Except that I think both of you misunderstand. The *entire* station does
> not rotate around the central axis. Just the inner shell (currently
> colored blue) rotates. The outer shell remains fixed. I don't have a
> good explanation why I chose to do it this way.
I clearly remember that.
> Anyway, I've attached my latest design. The panels and domes are no
> longer blocking each other. But I think it is ugly. :(
> What do you think?
A third solution made possible by the stationary outer shell:
Have one or more "agri-arm" holding the agridomes or agritanks.
Have one or more "energy arm" holding the solar pannels.
Those two kinds of arms can be set in any non-obstructing pattern.
Date: 11 Feb 2015 00:28:36
Message: <54dae884@news.povray.org>
Here's my latest version. Is it better? I think I am heading in the
right direction. I still have to connect the outer solar panel ring to
the ship. Right now it's just floating.
Download 'gh_scene_spinner_cutaway_08.png' (255 KB)
Preview of image 'gh_scene_spinner_cutaway_08.png'
Date: 11 Feb 2015 00:50:41
Message: <54daedb1$1@news.povray.org>
On 2/10/2015 10:56 PM, green wrote:
> certain features of your design need attention drawn to i think.
>    having a non-rotating nacelle over the rotating pseudo-gee habitat can provide
> for shielding.  figure up to two meters of concrete/regolith/plastic.  with the
> shielding separate from the hab, you do not have to invest in the angular
> momentum.  however, your design is a 'long tom'; rotating cylinders on such a
> long axis are inherently unstable and will seek to precess to a rotation around
> a more stable principle axis, with disastrous results.  the instability can be
> overcome i think by carefully orchestrated counterweights moving radially from
> the axis of rotation, but clearance with your nacelle might be a problem.  most
> designs that deal with the stability problem just make the cylinder shorter,
> more like 'square', diameter=length.  'kalpana one' is such a design; it is near
> the size of yours.
I added a new outer ring for the solar panels and agridomes. They rotate
in the opposite direction as the habitat. But they have very little mass.
>    if you intend to have near-earth-strength artificial illumination, then
> consider the basic efficiency of photon-in (to the solar cell) vs photon-out
> (from the lighting).  ten percent is ridiculously high i suspect; but that would
> mean having ten times the surface area of your hab in solar cell area, just for
> lighting alone.  usually this problem is solved with natural sunlight and
> mirrors.  a good example is the o'neill-type cylinders in alexis gilliland's
> 'rosinante' trilogy (available for kindle).  instead of giant whirling plane
> mirrors (at ten or twenty gees at the tips) gilliland embeds the habs in vast
> conical arrays of small mirrors, each steerable.  as a bonus, since the mirrors
> are stationary, they can be heavy, and are dichroric mirrors reflecting only
> visible light, no heat or u.v.   also, since the novels are set in the asteroid
> belt, much larger surface areas are needed than can be provided by the mirrors
> of the classic o'neill cylinder.
The ship has a regular reactor in addition to the solar panels. It's in
the center of the big sphere that's kind of hard to see now. It's
surrounded by water and fuels maybe. Maybe cargo.
>    you can hypothesize food plants that thrive in zero gee but that is a big leap
> of faith.  the classic o'neill cylinder had a ring of 'small' 'farm modules' to
> feed the cylinder (the gilliland habs were in the business of agriculture).  the
> o'neill farms were rotating structures about the size of your spinner.  even
> stipulating zero gee crops, i am wondering, why the domes instead of flat
> coverings (tho they do look cool).  radiation protection is another concern; i
> have forgotten if o'neill's 'high frontier' addressed it.  in a 'current state
> of the art' pragmatic cop-out, it might be necessary to move agriculture into
> the main hab, send everybody 'underground'.  coolness counts, tho, and every
> design feature, or bug, can be rationalized away.
The agridomes are rotating now, so they should have proper fake gee. I
was thinking the dome shape would resist pressurization better. They're
not well shielded though. I haven't modeled the parabolic torus (a
surface, not a solid) yet to collect light and direct it to the domes.
> i fear my ideas seem limiting and stifling whereas i hope they inspire and help.
>   there are a lot of divergent ideas out there, and that is a good thing.
Thanks for your comments! Keep them coming!
Date: 11 Feb 2015 03:46:01
Message: <54db16c9$1@news.povray.org>
Le 10/02/2015 22:25, Mike Horvath a écrit :
> On 2/10/2015 3:50 PM, Le_Forgeron wrote:
>> Also, given the kind of scale for the blue rotating cylinder, you should
>> have a small line of agridomes from the main body to the current group.
> Not sure what you mean without a sketch.
  instead of --%%%--O--%%%--
the part between % and O could have some extra aligned agridomes
Something like --%%%**O**%%%--
Also, some water-tank(s) could be nearby
>> Which also mean that the current section of the support might actually
>> be unrealistic (they are too big in proportion), and the six shaped
>> stars might also enjoy being a mesh of triangular sections.
> Not sure what you mean.
What is the diameter of the rotating body ? compare it to the
triangulated support used to attach the agridomes and to the section of
the six lines which are making a star around the central axis: if you
were able to make such big lines inside, why is the outer support meshed
of thinner diameter ?
>> In Babylon 5, the central axis is a support for a transportation system
>> (kind of metro). Presently here, it does not seems to have a purpose and
>> its length (as a single segment) is unrealistic. Or I get really wrong
>> about the scale of the spinning colony.
> The central axis is actually the light source. It serves no structural
> function.
Make that central light modular (segments would have to be replaced as
they get broken): small linear section as pavement on the cylinder. at
least 6 sections (but more according to the diameter) to cover the round
perimeter. A small variation of hue and saturation of the white "light"
colour along the axis might be interesting.
Just because nobody complains does not mean all parachutes are perfect.
Date: 11 Feb 2015 04:26:30
Message: <54db2046@news.povray.org>
My solution ;-)
And you won't need solar panels you'll need radiators. And they can go
in the shade. :-)
Regards
Download 'wax01_0000.png' (174 KB)
Preview of image 'wax01_0000.png'
Date: 11 Feb 2015 23:37:18
Message: <54dc2dfe@news.povray.org>
Today's render. I wish the ring better approximated a true circle. But I
would have to rewrite "truss.inc" or find a different way to make
circular trusses.
Download 'gh_scene_spinner_cutaway_11.png' (288 KB)
Preview of image 'gh_scene_spinner_cutaway_11.png'
Date: 11 Feb 2015 23:59:27
Message: <54dc332f$1@news.povray.org>
> My solution ;-)
> in the shade. :-)
I've been wondering about waste heat and how to handle it. I suppose I
could say that the external trusses are for piping water and cooling it.
But cylinders are not very efficient at distributing heat.
Also, I was looking at some pictures of the ISS, and their solar panels
have a coppery sheen to them. How do I mimic that? Here's my current
solar panel texture:
#local solar_panel_texture = texture
	#switch (TexQual)
		#case (-1)
			lowqual_pig(Seed)
		#break
		#case (0)
			pigment
				brick gamma_color_adjust(0/4*<1,1,1>), gamma_color_adjust(1/4*<1,1,1>)
				brick_size panel_width/4
				mortar panel_mortar
			translate +y * panel_width/16
			translate +z * panel_width/8
		#break
		#case (1)
		#case (2)
			pigment
				mortar panel_mortar
			finish {Glossy}
		#break
Date: 12 Feb 2015 00:21:54
Message: <54dc3872$1@news.povray.org>
The radius of the habitat is close to 300 meters. The metal rods are 2
meters thick in both cases.
>> function.
Segmenting the light source would create strange shadows on the
interior. Not sure what you mean about the pavement and 6 sections. I
would like to make the light source more yellow, but haven't figured out
how. Here's the LightSys code I use:
#local Lightsys_Scene_Scale	= Meters * 100;			// 1 = 1cm?
#local light_lumens		= 2;					// float
#local light_temp		= Daylight(6100);			// float
#local light_color		= Light_Color(light_temp, light_lumens);
Date: 12 Feb 2015 00:31:22
Message: <54dc3aaa@news.povray.org>
> circular trusses.
Here is the whole exterior of the ship. It's not as sexy.
Download 'gh_scene_spinner_cutaway_13.png' (273 KB)
Preview of image 'gh_scene_spinner_cutaway_13.png'
Date: 12 Feb 2015 03:28:07
Message: <54dc6417$1@news.povray.org>
I have been wondering about those six circular windows. While rotating
do they not create a kind of blinking effect?
