POV-Ray : Newsgroups : povray.binaries.images : Spinner colony (again) Server Time
2 Jul 2025 06:33:53 EDT (-0400)
  Spinner colony (again) (Message 31 to 40 of 59)
Subject: Re: Spinner colony (again)
Date: 13 Feb 2015 20:59:18
Message: <54deabf6@news.povray.org>
Le 15-02-13 15:43, Mike Horvath a écrit :
> On 2/13/2015 3:20 AM, Thomas de Groot wrote:
>> On 13-2-2015 0:07, Mike Horvath wrote:
>>> On 2/12/2015 3:28 AM, Thomas de Groot wrote:
>>>> I have been wondering about those six circular windows. While rotating
>>>> do they not create a kind of blinking effect?
>>> The effect is probably similar to the one experienced by farmers living
>>> near and under wind power turbines. It is probably annoying. I could
>>> replace the holes in the outer shell with a single cylindrical groove to
>>> remove the effect, but it wouldn't make structural sense.
>> If structural sense is the only thing that matters (and not a view to
>> the outside) why not provide smaller holes set on different circular
>> paths between inner and outer shells, so that they do not coincide?
> I'm not sure I understand. Having holes of any kind would still produce
> blinking I think.
The blinking effect can be reduced if the two openings set don't have
the same number of openings.
Try 6 on the outer shell and 7 for the inner shell.
Date: 14 Feb 2015 03:21:08
Message: <54df0574@news.povray.org>
> blinking I think.
Words... difficult...
I made a little simplified image to show what I mean.
Download 'test.png' (67 KB)
Preview of image 'test.png'
Date: 14 Feb 2015 22:07:15
Message: <54e00d63@news.povray.org>
I've been playing around with different scales for the habitat. I prefer
the larger scale (left in the image). But I know there's no way I can
render it with the quality levels turned up higher. I tried a couple
days ago but after 2.5 hours it was still stuck in that stage between
parsing and actually rendering. I can't spare my computer for the week
or however long it would require to render the scene.
Download 'gh_spinner_montage_e.png' (563 KB)
Preview of image 'gh_spinner_montage_e.png'
Date: 15 Feb 2015 07:48:40
Message: <54e095a8$1@news.povray.org>
Am 15.02.2015 um 04:07 schrieb Mike Horvath:
Sounds like you might be hitting the physical memory limits of your
computer, and entering the abyss of swap hell. In that case I'd wager
even a week to be a very optimistic estimate.
Date: 16 Feb 2015 09:10:13
Message: <54e1fa45@news.povray.org>
On 12/02/2015 23:09, Mike Horvath wrote:
> I just tried that but didn't notice much of a difference. Maybe because
> I am using parallel lights and camera?
I think that the fault is on my part. (Sorry for the delay in replying.)
I don't write my own code I use a modeller and there was a cut and paste
problem in my last post.
The attached image shows a coloured reflection.
The bands are (R to L) Cu reflection, no colour in reflection and brick
pattern with the mortar having a coloured reflection.
#declare SMcA_BlackCu =
     color rgbft <0.122,0.122,0.122,0.000,0.000>
   finish {
     ambient     rgb <0.100,0.100,0.100>
     brilliance  1.000
     crand       0.000
     diffuse     0.600
     metallic    1.000
     phong       0.000
     phong_size  40.000
     specular    0.000
     roughness   0.050
     reflection {
       rgb <0.481,0.301,0.133>, rgb <0.722,0.451,0.200>
       fresnel   0
       falloff   0.000
       exponent  1.000
       metallic  0.000
Regards
Download 'wax03_0000.png' (545 KB)
Preview of image 'wax03_0000.png'
Date: 16 Feb 2015 19:02:49
Message: <54e28529$1@news.povray.org>
On 2/16/2015 9:10 AM, Stephen wrote:
> finish {
>      brilliance  1.000
>      crand       0.000
>      diffuse     0.600
>      metallic    1.000
>      phong       0.000
>      phong_size  40.000
>      specular    0.000
>      roughness   0.050
>      reflection {
>        fresnel   0
>        falloff   0.000
>        exponent  1.000
>        metallic  0.000
That worked! Thanks.
Date: 18 Feb 2015 01:17:29
Message: <54e42e79@news.povray.org>
I have curved the solar panels and agridomes. They look a lot more sleek
now.
I am also still working on a solution for the viewport flickering. I've
at least reduced it somewhat by making the spindles in the outer shell
thinner. I don't like how this looks, but maybe adding a few more curves
here and there will make it look better.
Lastly, I'm still trying to figure out how to reflect sunlight onto the
agridomes. I'm considering a paraboloid directly "above" them (from the
standpoint of someone standing inside the agridome), but space is tight.
Download 'gh_scene_spinner_cutaway_16.png' (310 KB)
Preview of image 'gh_scene_spinner_cutaway_16.png'
Date: 18 Feb 2015 01:32:37
Message: <54e43205$1@news.povray.org>
I was keeping an eye on my physical memory and I don't remember it going
past 4GB (I have 8GB total). My swap file is also on an SSD and I don't
remember much activity (big blinking red light on PC case) there either.
Date: 18 Feb 2015 01:33:07
Message: <54e43223$1@news.povray.org>
>> blinking I think.
I'm sorry but that picture still doesn't make sense to me.
Date: 18 Feb 2015 01:33:55
Message: <54e43253$1@news.povray.org>
>> blinking I think.
> Alain
That's an idea, and a pretty simple one too. Thanks.
