POV-Ray : Newsgroups : povray.binaries.images : Media Problems Server Time
19 Nov 2025 08:28:47 EST (-0500)
  Media Problems (Message 1 to 10 of 13)
Subject: Media Problems
Date: 30 Nov 2014 17:22:34
Message: <547b98aa@news.povray.org>
Hello,
I have a problem with interior's media with official Pov, in the image
we can see a all white media when rendered with Pov 3.7, and the good
colors with Uberpov.
Can someone explain this?
Lionel
<b>Do not judge my words, judge my actions.</b>
parce que la protection avast! Antivirus est active.
http://www.avast.com
Download 'comparaison.png' (1186 KB)
Preview of image 'comparaison.png'
Subject: Re: Media Problems
Date: 30 Nov 2014 18:47:29
Message: <547bac91$1@news.povray.org>
On 30/11/2014 22:22, FractRacer wrote:
> Hello,
Your code would help. ;-)
Regards
Date: 1 Dec 2014 03:13:58
Message: <547c2346@news.povray.org>
>> Hello,
[start mumbling in background]
   What happened to Mickey's ear?
[stop mumbling in background]
Date: 1 Dec 2014 22:33:15
Message: <547d32fb$1@news.povray.org>
>> Hello,
Here is the problem !
#version 3.7;
global_settings{
	assumed_gamma 1
	max_trace_level 25
	ambient_light 1
background { rgb <0.000000, 0.000000, 0.000000> }
#declare camera_location = <0, 0, -75>;
camera{
	location camera_location
	up y
	angle 45
	look_at 0
#declare SZ = 1500;
#declare SR = 200;
#declare Sun = sphere{
	<0,0,0>, 1.2
	pigment { rgbt 1 filter 0.0	}
	finish {
		specular albedo 0.2
	hollow
	interior{
		ior 1.8
		media{
		method 3
		emission 2.26
      		scattering{
			1,
			<.1,.5,1>*3.00
			extinction  1.50
		density{
		granite
		turbulence 0.85
		color_map {
		[0.00 rgbf 0]
                     [0.05 rgbf 0]
                     [0.20 rgbf 0.2]
                     [0.30 rgbf 0.6]
                     [0.40 rgbf 0.8]
                     [0.50 rgbf 0.991]
                     [0.60 rgbf 0.8]
                     [0.70 rgbf 0.6]
                     [0.80 rgbf 0.2]
                     [0.95 rgbf 0]
                     [1.00 rgbf 0]
		samples 1,1
		intervals 3
		confidence 0.9
object {
	Sun
	scale <200,200,10>
	translate <0,0,SZ+50>
Lionel
Ce courrier électronique ne contient aucun virus ou logiciel malveillant parce que la
Date: 1 Dec 2014 22:34:38
Message: <547d334e@news.povray.org>
> Thomas
One ear is enough for Mickey. :)
Lionel
Date: 2 Dec 2014 03:25:25
Message: <547d7775$1@news.povray.org>
I think the problem is with your use of intervals and samples. Using
method 3, intervals should always be 1 while only the first parameter of
samples is read by the program. The second one is ignored.
Replace:
           samples 1,1
           intervals 3
by:
           samples 100
           intervals 1
You may need to play with the emission value and the multiplicator for
the scattering value.
Date: 2 Dec 2014 04:02:07
Message: <547d800f$1@news.povray.org>
And there is more: the scaling of the Sun & scattering media. Those
should be coupled. For that do this:
#declare MyScale = <200, 200, 10>;
On the scattering media line do this (example):
         scattering {
           1, <.1,.5,1>*5000/MyScale
           extinction  1.50
And in the object block for the Sun, set: scale MyScale.
In that way you can scale the Sun however you want without changing the
visual aspect of the media. One word of caution: I always am weary of
asymmetrical media scaling. So, I personally prefer to use <200,200,200>
instead of <200,200,10> when I can avoid it.
With all this I have not yet got the Uberpov aspect in official POV, but
I am working on it :-)
Date: 2 Dec 2014 04:18:26
Message: <547d83e2$1@news.povray.org>
Third Important Lesson ;-)
ALWAYS work on a *unit-sized* media sphere!
sphere {<0,0,0>, 1.0
instead of
sphere {<0,0,0>,1.2
because that plays havoc when scaling the object.
(You can also delete the filter statement in pigment by the way)
Date: 2 Dec 2014 07:40:36
Message: <547db344@news.povray.org>
This is what I have got (see image).
Left render with Uberpov; Right render with Pov 3.7.
The only code difference is the emission value: In Uberpov it is 2; in
POV-Ray it is 0.2. Higher values will white out the render. The
difference remains and I think Clipka knows why :-)
This is the media code I used for both renders:
#declare SR = 200;
#declare Sun =
   sphere {
     <0,0,0>, 1
     pigment { rgbt 1}
     hollow
     interior {
       //ior 1.8
       media {
         method 3
         samples 100
         intervals 1
         //confidence 0.9
         emission 0.2	//change to 2 in Uberpov
         scattering {
           1, <0.1, 0.5, 1>*1000/SR
           //extinction  1.50
         density {
           granite
           turbulence 0.85
           color_map {
             [0.00 rgb 0]
             [0.05 rgb 0]
             [0.20 rgb 0.2]
             [0.30 rgb 0.6]
             [0.40 rgb 0.8]
             [0.50 rgb 0.991]
             [0.60 rgb 0.8]
             [0.70 rgb 0.6]
             [0.80 rgb 0.2]
             [0.95 rgb 0]
             [1.00 rgb 0]
object {
     Sun
     scale SR
     translate <0,0,0>
Download 'lionelmediaproblem.jpg' (212 KB)
Preview of image 'lionelmediaproblem.jpg'
Date: 2 Dec 2014 08:26:06
Message: <547dbdee@news.povray.org>
> #declare SR = 200;
> #declare Sun =
>    sphere {
>      <0,0,0>, 1
>      pigment { rgbt 1}
>      hollow
>      interior {
>        //ior 1.8
>        media {
>          method 3
>          samples 100
>          intervals 1
>          //confidence 0.9
>          scattering {
>            //extinction  1.50
>          density {
>            granite
>            turbulence 0.85
>            color_map {
>              [0.00 rgb 0]
>              [0.05 rgb 0]
>              [0.20 rgb 0.2]
>              [0.30 rgb 0.6]
>              [0.40 rgb 0.8]
>              [0.50 rgb 0.991]
>              [0.60 rgb 0.8]
>              [0.70 rgb 0.6]
>              [0.80 rgb 0.2]
>              [0.95 rgb 0]
>              [1.00 rgb 0]
> object {
>      Sun
>      scale SR
>      translate <0,0,0>
> Thomas
A big thanks for you, Thomas, I think I have all tried except the
emission's value. And now I know how handle the render with Povray and
Uberpov.
Lionel
