POV-Ray : Newsgroups : povray.binaries.images : Silentium. A last (?) final Server Time
25 Jun 2026 18:55:44 EDT (-0400)
  Silentium. A last (?) final (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Silentium. A last (?) final
Date: 23 Sep 2014 10:44:59
Message: <5421876b@news.povray.org>
On 23-9-2014 16:20, Thomas de Groot wrote:
> Oh gosh, yes, it is a shadow vanishing trick indeed!
> I attach the material file of the building. Note that a few elements
> have been subjected to a proximity pattern. I shall test if /those/
> render differently; if so, you will get them too but I think that will
> not be necessary.
Well, I can now say definitively that the culprits are the elements that
have gone through the proximity pattern mill. However, the strange thing
is that the shadow of the window sill on the first floor also vanishes
although no element with a proximity pattern is present there.
So the problem might be slightly different from what you were fearing.
Info:
- I used Edouard Poor's Proximity Pattern macro.
- You may have them one way or another, but I attach Edouard's files, as
I use them, to be sure.
- The arcs, columns, and the fountain are processed.
- I attach de .df3 and .prox files of these elements.
I think you have everything necessary to test. If not, yell.
Download 'arcs.df3.dat' (82 KB) Download 'windows-1252' (1 KB) Download 'columns.df3.dat' (83 KB) Download 'windows-1252' (1 KB) Download 'fountain.df3.dat' (79 KB) Download 'windows-1252' (1 KB) Download 'windows-1252' (15 KB) Download 'windows-1252' (13 KB)
Date: 23 Sep 2014 10:47:35
Message: <54218807$1@news.povray.org>
On 23-9-2014 16:46, FractRacer wrote:
> Well done, you have made some very good jobs actually. I want also to
> thank and congratulate you for your reeds_in_the_winds files, very
> useful and realistic.
Thank you indeed. The pleasure is mine :-)
As far as the reeds are concerned, I guess there are possibilities for
improvement. This is about what I can do, others may come up with some
smart solutions.
Date: 23 Sep 2014 13:54:46
Message: <5421b3e6$1@news.povray.org>
Am 23.09.2014 16:44, schrieb Thomas de Groot:
>> not be necessary.
Can you help me with identifying those textures?
Well, what /was/ I "fearing" then? ;-)
I have no doubt that the Prox Pattern macros are perfectly fine. I
presume that they just happen to make use of a language construct that's
broken, which may also be used in (and therefore affect) other materials.
Say, do the vanished non-proxed objects perchance also make use of a
texture_map?
Date: 24 Sep 2014 03:57:24
Message: <54227964$1@news.povray.org>
Yes of course.
Good point indeed :-)
> texture_map?
I need to plunge into this and see how the textures are built and are
affected. I'll be back.
Date: 24 Sep 2014 08:36:34
Message: <5422bad2$1@news.povray.org>
> texture_map?
Right. This is what I found:
- The proximity pattern textures have the following build-up with
pigment_pattern and a texture_map:
     pigment_pattern {
       average
       pigment_map {
         #if( proximity_pattern_strength != 0 )
           [ proximity_pattern_strength*3 df3_pattern scale 1/texture_scale]
         #if( slope_pattern_strength != 0 )
           [ slope_pattern_strength*0.6 slope { y altitude <0,1,0> }
color_map { [0 rgb 1] [1 rgb 0] } scale 140 * 1/texture_scale ]
         #if( noise_pattern_strength != 0 )
           [ noise_pattern_strength *0.4 bozo color_map { [0 rgb 0] [1
rgb 1] } scale 4 * noise_scale ]
           [ noise_pattern_strength *0.3 bozo color_map { [0 rgb 0] [1
rgb 1] } scale 1 * noise_scale]
           [ noise_pattern_strength *0.2 bozo color_map { [0 rgb 0] [1
rgb 1] } scale 0.33 * noise_scale ]
           [ noise_pattern_strength *0.1 bozo color_map { [0 rgb 0] [1
rgb 1] } scale 0.1 * noise_scale ]
     texture_map { map }
     scale texture_scale
- Consequently, in my image, the fountain, the columns, the arcs, and
the combined ridges, window sills, window arcs, are missing (part of)
their shadows.
- As far as I can tell, all other elements have rendered correctly.
Date: 24 Sep 2014 10:41:46
Message: <5422d82a$1@news.povray.org>
On 23-9-2014 10:22, Stephen wrote:
> I like this one very much.
I do too. Especially the subtle graininess left by the stochastic
antialiasing is something I appreciate.
Date: 24 Sep 2014 10:49:37
Message: <5422da01@news.povray.org>
A pointillist version ;-)
I added a tiny transparency to the image_maps involved in the proximity
patterns and that proved to be a good workaround. Thanks Christoph.
Tomorrow I shall render a better final version.
Download 'silentium.png' (1064 KB)
Preview of image 'silentium.png'
Date: 24 Sep 2014 11:02:00
Message: <5422dce8$1@news.povray.org>
> Thomas
This I really like.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 24 Sep 2014 11:34:35
Message: <5422e48b$1@news.povray.org>
>> Thomas
> This I really like.
The graininess adds to the atmosphere.
@Clipka would it be feasible to add a feature to UberPov so that it
takes a snapshot at different stages to see the progress of the render?
It is just a thought as an animation of the building of the picture
might be interesting to see.
Regards
Date: 24 Sep 2014 11:49:08
Message: <5422e7f4$1@news.povray.org>
Am 24.09.2014 17:34, schrieb Stephen:
Such a feature is on my to-do list (has always been, actually), but I'm
waiting for some other changes to happen in POV-Ray proper that will
make it a whole lot easier.
