POV-Ray : Newsgroups : povray.binaries.images : unexplained Server Time
27 May 2026 17:38:15 EDT (-0400)
  unexplained (Message 39 to 48 of 58)
Subject: Re: unexplained
Date: 20 Aug 2014 09:26:02
Message: <53f4a1ea$1@news.povray.org>
On 08/20/2014 09:16 AM, clipka wrote:
> Am 20.08.2014 14:29, schrieb James Holsenback:
>> I added some debug in OTO_Get_Mask like this:
>> #macro OTO_Get_Mask(Cell)
>>      #local CX = Cell.x;
>>    #local CY = Cell.y;
>>    #local Result = OTO_FMask(CX,CY,0);
>>    #debug concat ("OTO_Get_Mask <",vstr(3,Cell,",",2,4),">
>> Result:",str(Result,2,4),"\n")
>>    OTO_FMask(CX,CY,0)
>>   #end
>> and it produced the following output:
>> OTO_Get_Mask <-8.0000,-5.0000,0.0000> Result:1.0000
>> else: <-8.08857,-4.96521,0.00000>, <-6.81513, -3.69069, 0.00000>
>> OTO_Get_Mask <-7.0000,-5.0000,0.0000> Result:0.0000
>> else: <-6.96521,-4.79876,0.00000>, <-6.19790, -3.81513, 0.00000>
>> OTO_Get_Mask <-6.0000,-5.0000,0.0000> Result:1.0000
>> else: <-5.79876,-4.73380,0.00000>, <-4.90749, -4.19790, 0.00000>
>> OTO_Get_Mask <-5.0000,-5.0000,0.0000> Result:0.0000
>> else: <-4.73380,-4.96589,0.00000>, <-4.33468, -3.90749, 0.00000>
>> OTO_Get_Mask <-4.0000,-5.0000,0.0000> Result:1.0000
>> else: <-3.96589,-5.17163,0.00000>, <-3.41528, -4.33468, 0.00000>
> Can you repeat this with a much higher precision for the result? 20
> digits should be enough. I wouldn't be surprised if this was some kind
> of precision issue in the function{pattern{pigment_pattern}} construct,
> as it would perfectly explain why it doesn't compare equal to 1.0. (I
> consider it unlikely that the comparison with 1.0 itself got broken
> somehow, and I think there /is/ a bit of code in the pigment_pattern
> that might be subject to rounding errors.)
OTO_Get_Mask
<-8.00000000000000000000,-5.00000000000000000000,0.0000000000000000
0000> Result:0.99999997764825820923
Hmmm ... OK I think this shows problem the above is output from inside
the OTO_Get_Mask function ... I now see why reversing the logic (and my
"on a lark" test) in corner test works
Date: 20 Aug 2014 09:28:11
Message: <53f4a26b$1@news.povray.org>
Am 20.08.2014 15:16, schrieb James Holsenback:
> I'm confused now ... aren't
> #if(OTO_Get_Mask(Vec)=1)
> and
> #if(OTO_Get_Mask(Vec))
> functionally the same?
No,
and
   #if(OTO_Get_Mask(Vec) != 0)
are.
Date: 20 Aug 2014 09:40:11
Message: <53f4a53b$1@news.povray.org>
Am 20.08.2014 15:26, schrieb James Holsenback:
> OTO_Get_Mask
Bingo!
Okay, you obviously have already figured a way around this problem by
way of modifying OTOc.inc, and I think I now have enough information to
go hunting for the root cause in the codebase.
I might come back to you for testing of some code modifications, if
that's ok for you.
Date: 20 Aug 2014 10:00:43
Message: <53f4aa0b$1@news.povray.org>
> that's ok for you.
ok fine
Date: 20 Aug 2014 16:00:43
Message: <53f4fe6b$1@news.povray.org>
This is /true/ if and only if the result *is* 1 (one)
> and
This is /false/ if and only if the result *is* 0 (zero)
So, not at all *unless* the result can only be zero or one.
Date: 28 Aug 2014 13:41:55
Message: <53ff69e3@news.povray.org>
>> OTO_Get_Mask
> Bingo!
> that's ok for you.
curious if you've had any time to follow up
Date: 28 Aug 2014 14:08:50
Message: <53ff7032$1@news.povray.org>
Am 28.08.2014 19:41, schrieb James Holsenback:
>>> OTO_Get_Mask
>> Bingo!
>> that's ok for you.
Not yet, sorry.
Date: 6 Jan 2015 17:43:00
Message: <54ac64f4$1@news.povray.org>
Am 28.08.2014 um 19:41 schrieb James Holsenback:
>>> OTO_Get_Mask
>> Bingo!
>> that's ok for you.
Now that I've returned from outer space, I have at last; can you please
try the following patch:
At the beginning of source/base/colour.h, around line 95, replace the
following lines:
const float kRedIntensity   = 0.297;
const float kGreenIntensity = 0.589;
const float kBlueIntensity  = 0.114;
with this:
const PreciseColourChannel kRedIntensity   = 0.297;
const PreciseColourChannel kGreenIntensity = 0.589;
const PreciseColourChannel kBlueIntensity  = 0.114;
I /think/ it should fix the issue. The culprit would then have been
change 0ea2da4.
Date: 13 Jan 2015 14:02:09
Message: <54b56bb1$1@news.povray.org>
>>>> OTO_Get_Mask
>>> Bingo!
>>> that's ok for you.
Well my job (10hrs a day 7 days a week) is a black hole ...
> following lines:
> with this:
> change 0ea2da4.
I will do my best, but can't promise any sort of time frame
Date: 14 Jan 2015 03:26:37
Message: <54b6283d$1@news.povray.org>
No kidding? Slavery has been prohibited as far as I know... :-\
