POV-Ray : Newsgroups : povray.binaries.images : unexplained Server Time
27 May 2026 19:06:27 EDT (-0400)
  unexplained (Message 29 to 38 of 58)
Subject: Re: unexplained
Date: 18 Aug 2014 09:43:01
Message: <53f202e5$1@news.povray.org>
On 08/18/2014 08:18 AM, clipka wrote:
> Am 17.08.2014 10:47, schrieb James Holsenback:
>>> If I understand you correctly, you're saying that with issue #29 fixes
>>> in place commit 7502593 works while cf1c3fb doesn't. Is that right?
>> ac564f7 was the last time I was able to compile and run OTOTest file
>> correctly ... cf1c3fb wouldn't even compile. jumped to af80da4 (the last
>> issue #29) commit and it compiled fine but OTOTest file problem showed
>> up again
> Please note that the Git version history isn't linear: It has different
> branches that split and merge; and while ac564f7 is the last commit
> before cf1c3fb, it was done on a different branch, and so the immediate
> predecessor of cf1c3fb is the earlier commit 7502593. (Likewise, the
> later commit 914fff1 is a direct successor of ac564f7 but not of
> cf1c3fb, and is therefore likely to both compile and run OTOTest file.)
> The following commits are still suspects for having broken OTOTest (in
> reverse chronological order):
>      cf1c3fb
>      7502593
>      2a2d1a8
>      2a41f04
> 7502593 is comparatively unlikely to be the culprit, as it just merges
> bugfix cc24c62, which was also merged into the other branch leading to
> ac564f7 and apparently didn't do any damage there.
> 2a2d1a8 is about as hot a candidate as cf1c3fb - probably even more so,
> as it is all about vectors and therefore relative position of items,
> while cf1c3fb is about blend maps (colour maps, pigment maps, normal
> maps etc.), which do not have any intrinsic relative positional
> component to them.
> 2a41f04 is a hot candidate for having caused GitHub issue #29, but
> shouldn't have brought about any functional changes, so I suspect it
> will run fine with the issue #29 fixes applied.
OK ... this goes to some of my confusion. I'd suspected as much. Thanks
for the sanity check!
When I downloaded source(s) I used the "clone" url, so I was pulling a
snapshot of the entire branch (not just individual changes) at that
commit, then doing separate builds for each. Give me some time to
further narrow it down.
Appreciate your indulgence.
Date: 18 Aug 2014 10:13:50
Message: <53f20a1e@news.povray.org>
Am 12.08.2014 19:08, schrieb James Holsenback:
>>> The Sam's test scene (OTOTest.pov) renders fine here with the latest
>>> POV-Ray and UberPOV stuff (Windows versions).
>> here's what I'm doing:
>> #declare Floor =
>> union {
>>      object {
>>          OTO( <-2.5,-2.5,0>, <2.5,2.5,1>, 0.075, texture { BaseTexture
>> scale 1 } )
>>      box { <-2.5,-2.5,0.075>, <2.5,2.5,0.075> pigment { srgb 1 } finish
>> {diffuse 0.6 specular 0.15 roughness 1e-5} }
>>      rotate x*90
>>      rotate y*0
>> kind of funny that it works with some versions (perforce/git 3.7 stable)
>> but not other git repos ... 32 vs 64 bit? compiler?? configure changes???
> found OTOTest.pov file laying around in some obscure corner ... here's
> results
I've got some good news: While I'm still unable to reproduce the error,
I /am/ now able to exactly reproduce the output you're seeing (see
attached image), by changing the OTO_FMask function
     #local OTO_FMask = function{ pattern{ pigment_pattern{
         checker 0, 1 warp{planar} } } }
to something that never returns 1; so it would seem that the error
scrambles one of the statements in this function definition.
Can you please dig further in this direction to figure out exactly what
part of this is broken? (I guess this will lead us much faster to the
root cause than knowing exactly which commit introduced it.)
Download 'ototest.png' (275 KB)
Preview of image 'ototest.png'
Date: 18 Aug 2014 10:22:50
Message: <53f20c3a$1@news.povray.org>
>>> #declare Floor =
>>> union {
>>>      object {
>>> scale 1 } )
>>>      rotate x*90
>>>      rotate y*0
>>> changes???
>> results
yes that IS good news ...
OK
Date: 18 Aug 2014 16:38:45
Message: <53f26455@news.povray.org>
>>> #declare Floor =
>>> union {
>>>      object {
>>> scale 1 } )
>>>      rotate x*90
>>>      rotate y*0
>>> changes???
>> results
Well had some time after all ... I played with the OTO_FMask function,
but hey there's not much to change right? I started looking at the
numbers being passed to OTO_Get_Mask, on line 133 of the attached
include I added a debug. Everything looked legitimate, so I dropped down
a couple of lines and added debugs for the corner finding test. Those
sets of vectors looked like legitimate formed vectors as well, but the
wall is incomplete. Didn't notice that notice that the vectors were ALL
falling into the 1st test until I changed condition to false on line
136. Now the vectors pass through BOTH of the test and the wall in complete.
Download 'us-ascii' (5 KB)
Date: 18 Aug 2014 20:41:44
Message: <53f29d48$1@news.povray.org>
Am 18.08.2014 22:38, schrieb James Holsenback:
> 136.
I... don't think I understand what you're saying.
Yes, the bug seems to be causing the corner finding test to always go to
the same branch (but it's the else-branch according to my observation).
The mystery to be solved is, why is that?
I don't think the test itself ("#if(OTO_Get_Mask(Vec)=1)") is broken;
that would surely affect too many other scenes. Likewise, I can't see
how anything in the OTO_Get_Mask() macro could go wrong without messing
up plenty of scenes as well.
My suspicion is therefore that the function OTO_FMask returns non-1
values where it should return 1, and I was hoping you could do some
toying around with that very function and compare its operation with (a)
a working binary and (b) your broken version.
Something like:
  #macro OTO_Get_Mask(Cell)
   #local CX = Cell.x;
   #local CY = Cell.y;
   #local Result = OTO_FMask(CX,CY,0);
   #debug concat()
   Result
On a properly working binary and with the original OTOTest.pov scene,
this should output:
<-8.00000,-5.00000,0.00000>: 1.00000000000000000000
<-7.00000,-5.00000,0.00000>: 0.00000000000000000000
<-6.00000,-5.00000,0.00000>: 1.00000000000000000000
<-5.00000,-5.00000,0.00000>: 0.00000000000000000000
<-4.00000,-5.00000,0.00000>: 1.00000000000000000000
<-3.00000,-5.00000,0.00000>: 0.00000000000000000000
<-2.00000,-5.00000,0.00000>: 1.00000000000000000000
<-1.00000,-5.00000,0.00000>: 0.00000000000000000000
<0.00000,-5.00000,0.00000>: 1.00000000000000000000
<1.00000,-5.00000,0.00000>: 0.00000000000000000000
<2.00000,-5.00000,0.00000>: 1.00000000000000000000
<3.00000,-5.00000,0.00000>: 0.00000000000000000000
<4.00000,-5.00000,0.00000>: 1.00000000000000000000
<5.00000,-5.00000,0.00000>: 0.00000000000000000000
<6.00000,-5.00000,0.00000>: 1.00000000000000000000
<7.00000,-5.00000,0.00000>: 0.00000000000000000000
<-8.00000,-4.00000,0.00000>: 0.00000000000000000000
<-7.00000,-4.00000,0.00000>: 1.00000000000000000000
<-6.00000,-4.00000,0.00000>: 0.00000000000000000000
<-5.00000,-4.00000,0.00000>: 1.00000000000000000000
<-4.00000,-4.00000,0.00000>: 0.00000000000000000000
<-3.00000,-4.00000,0.00000>: 1.00000000000000000000
<-2.00000,-4.00000,0.00000>: 0.00000000000000000000
<-1.00000,-4.00000,0.00000>: 1.00000000000000000000
<0.00000,-4.00000,0.00000>: 0.00000000000000000000
<1.00000,-4.00000,0.00000>: 1.00000000000000000000
<2.00000,-4.00000,0.00000>: 0.00000000000000000000
<3.00000,-4.00000,0.00000>: 1.00000000000000000000
<4.00000,-4.00000,0.00000>: 0.00000000000000000000
<5.00000,-4.00000,0.00000>: 1.00000000000000000000
<6.00000,-4.00000,0.00000>: 0.00000000000000000000
<7.00000,-4.00000,0.00000>: 1.00000000000000000000
If your broken build outputs the same, the problem must be in the macro
or the comparison after all, but I doubt that, so I suspect that you'll
get something different instead of "1.00000000000000000000".
In that case, a next step could be to use an all-1 pigment pattern
instead and see what that does:
   #local OTO_FMask = function { pattern { pigment_pattern {
     colour 1.0 } } }
With an ok binary, this should give:
<-7.00000,-5.00000,0.00000>: 1.00000000000000000000
<-5.00000,-5.00000,0.00000>: 1.00000000000000000000
If your results differ there as well (which I suspect), we can rule out
the warp{planar} and the checker pigment; using an entirely different
pattern instead of pigment_pattern might also give some insight, such as:
   #local OTO_FMask = function{ pattern{ gradient x } }
which gives me:
<-8.00000,-5.00000,0.00000>: 0.00007000000000045858
<-7.00000,-5.00000,0.00000>: 0.00006000000000039307
<-6.00000,-5.00000,0.00000>: 0.00005000000000032756
<-5.00000,-5.00000,0.00000>: 0.00004000000000026205
<-4.00000,-5.00000,0.00000>: 0.00003000000000019654
<-3.00000,-5.00000,0.00000>: 0.00002000000000013102
<-2.00000,-5.00000,0.00000>: 0.00001000000000006551
<0.00000,-5.00000,0.00000>: 0.00000000000000000000
<1.00000,-5.00000,0.00000>: 1.00000000000000000000
<2.00000,-5.00000,0.00000>: 0.00000000000000000000
<4.00000,-5.00000,0.00000>: 0.00000000000000000000
<6.00000,-5.00000,0.00000>: 0.00000000000000000000
Or use checker like this, which should give the same as the original
from OTOc.inc albeit with a much simpler statement:
   #local OTO_FMask = function{ pattern{ checker } }
> complete.
Pardon? You fixed it? How? The OTOc.inc you posted contains no changes
except for the commented-out #debug lines and an additional blank at the
end of the central test condition.
Date: 19 Aug 2014 07:07:48
Message: <53f33004$1@news.povray.org>
>> 136.
> Something like:
>    #local CX = Cell.x;
>    #local CY = Cell.y;
>    #debug concat()
>    Result
>   #end
> this should output:
>      colour 1.0 } } }
> which gives me:
>> complete.
Geez ... I never said I fixed it, and I'm getting rather bored with this
back and forth. There's a problem ... fix it or don't.
Date: 19 Aug 2014 09:14:14
Message: <53f34da6@news.povray.org>
Am 19.08.2014 13:07, schrieb James Holsenback:
I'd really like to fix it, but I need your help to diagnose the problem,
because I really can't reproduce it here, and at present I know of
nobody else who can.
Running the tests I described in my previous post should be a matter of
just a few minutes, and might tell me more about the problem than all
the back and forth so far.
So please help me a bit more with this.
... pretty please?
Date: 20 Aug 2014 08:29:46
Message: <53f494ba$1@news.povray.org>
> ... pretty please?
I added some debug in OTO_Get_Mask like this:
	#local CX = Cell.x;
   #local CY = Cell.y;
   #debug concat ("OTO_Get_Mask <",vstr(3,Cell,",",2,4),">
Result:",str(Result,2,4),"\n")
   OTO_FMask(CX,CY,0)
and it produced the following output:
OTO_Get_Mask <-8.0000,-5.0000,0.0000> Result:1.0000
else: <-8.08857,-4.96521,0.00000>, <-6.81513, -3.69069, 0.00000>
OTO_Get_Mask <-7.0000,-5.0000,0.0000> Result:0.0000
else: <-6.96521,-4.79876,0.00000>, <-6.19790, -3.81513, 0.00000>
OTO_Get_Mask <-6.0000,-5.0000,0.0000> Result:1.0000
else: <-5.79876,-4.73380,0.00000>, <-4.90749, -4.19790, 0.00000>
OTO_Get_Mask <-5.0000,-5.0000,0.0000> Result:0.0000
else: <-4.73380,-4.96589,0.00000>, <-4.33468, -3.90749, 0.00000>
OTO_Get_Mask <-4.0000,-5.0000,0.0000> Result:1.0000
else: <-3.96589,-5.17163,0.00000>, <-3.41528, -4.33468, 0.00000>
the 1st group shows a "Result" of 1 and it improperly falls into the
else clause (yep got that backwards in previous post ... tired, dyslexia
acting up) ... but notice in the 2nd group that even tho "Result" is 0
(inside the OTO_Get_Mask macro) it /still/ falls into the else clause
I also used:
#local OTO_FMask = function{ pattern{ pigment_pattern{ color 1.0 } } }
with these results:
OTO_Get_Mask <-7.0000,-5.0000,0.0000> Result:1.0000
OTO_Get_Mask <-5.0000,-5.0000,0.0000> Result:1.0000
so it would seem that no matter what OTO_Get_Mask returns, it's /always/
falling into the else clause.
when I change the corner test to: #if(OTO_Get_Mask(Vec)=0)
things appear to go through the corner test properly (albeit reverse
logic) and the image renders correctly without the gaps.
if: <-6.81513,-4.96521,0.00000>, <-5.79876, -4.19790, 0.00000>
if: <-4.90749,-4.73380,0.00000>, <-3.96589, -4.33468, 0.00000>
Date: 20 Aug 2014 09:16:24
Message: <53f49fa8$1@news.povray.org>
Am 20.08.2014 14:29, schrieb James Holsenback:
>      #local CX = Cell.x;
>    #local CY = Cell.y;
>    OTO_FMask(CX,CY,0)
>   #end
Can you repeat this with a much higher precision for the result? 20
digits should be enough. I wouldn't be surprised if this was some kind
of precision issue in the function{pattern{pigment_pattern}} construct,
as it would perfectly explain why it doesn't compare equal to 1.0. (I
consider it unlikely that the comparison with 1.0 itself got broken
somehow, and I think there /is/ a bit of code in the pigment_pattern
that might be subject to rounding errors.)
Date: 20 Aug 2014 09:16:31
Message: <53f49faf$1@news.povray.org>
On a lark I also tried:
#if(OTO_Get_Mask(Vec))
and it works!!!
if: <-7.69069,-5.08857,0.00000>, <-6.96521, -3.81513, 0.00000>
if: <-6.19790,-4.79876,0.00000>, <-4.73380, -3.90749, 0.00000>
if: <-4.33468,-4.96589,0.00000>, <-3.17163, -4.41528, 0.00000>
I'm confused now ... aren't
and
functionally the same?
