POV-Ray : Newsgroups : povray.binaries.images : hf_tools.inc Server Time
9 Nov 2026 20:47:32 EST (-0500)
  hf_tools.inc (Message 17 to 26 of 26)
<<< Previous 16 Messages Goto Initial 26 Messages
Subject: Re: hf_tools.inc
Date: 15 Dec 2009 20:57:31
Message: <4b283e8b@news.povray.org>
Alain wrote:
> It looks like it can be prety usefull. I'll play with that one.
The edge map is probably the most useful feature :)
Date: 16 Dec 2009 03:20:32
Message: <4b289850$1@news.povray.org>
"stbenge" <UN### [at] hotmailcom> schreef in bericht
news:4b283e59@news.povray.org...
> I really need to make a small functioning example to provide along with a
> bug report.
I may be talking nonsense here, but those same features are often also
created by WM or GeoControl. I don't remember them from Leveller, but it has
been a while since I last used that app. Do you think they have the same
origin? Are they the same kind of bug?
In GeoControl I can correct manually with a brush, but in hf's from WM I
just cut off a thin slice around from it by using an intersection in POV.
Not very elegant as a solution but it works.
Date: 16 Dec 2009 06:20:00
Message: <web.4b28c11df654043d65f302820@news.povray.org>
Where was this years ago??!!  You've created some real magic here. It must be
the coffee--drink lots more, so you can come up with more cool ideas!
I'm really looking forward to trying this out (and looking over your code, to
glean some ideas from 'the Master.')
Ken
Date: 16 Dec 2009 13:14:52
Message: <4b29239c@news.povray.org>
stbenge escreveu:
> Jörg 'Yadgar' Bleimann wrote:
>> High!
> Not yet! Maybe my second cup of coffee will do the trick ;)
bwahaha.  Always wanted to do some fun with that... :D
a game sig: http://tinyurl.com/d3rxz9
Date: 16 Dec 2009 14:15:20
Message: <4b2931c8@news.povray.org>
>> bug report.
I doubt they are the same bug.
Check this out:
height_field{
  png"mountains.png"
It works just fine, always has.
Compare it to this:
height_field{
  function 513, 513{
   pigment{
    image_map{
     png"mountains.png"
     interpolate 2 once
This is when edge artifacts show up. The dimensions are correct. The
problem happens regardless of image_map attributes such as interpolation
and repetition.
I would say it's a height_field issue, but I know it's not. I have
encountered this same problem when using image_maps at other times, like
for my luminous bloom code.
Whatever works :)
Date: 16 Dec 2009 14:17:29
Message: <4b293249@news.povray.org>
Drink more coffee? Okay :)
Whatever you do, have fun!
Date: 17 Dec 2009 03:17:52
Message: <4b29e930$1@news.povray.org>
news:4b2931c8@news.povray.org...
> Check this out:
> height_field{
>  png"mountains.png"
> Compare it to this:
> height_field{
>  function 513, 513{
>   pigment{
>    image_map{
>     png"mountains.png"
>     interpolate 2 once
> and repetition.
Ah, right. I see your point. One way or another I have never noticed this
difference. Strange indeed. Thanks for drawing my attention to it.
Date: 17 Dec 2009 10:40:01
Message: <web.4b2a4f8ff654043d65f302820@news.povray.org>
> Check this out:
> height_field{
>   png"mountains.png"
> Compare it to this:
> height_field{
>   function 513, 513{
>    pigment{
>     image_map{
>      png"mountains.png"
>      interpolate 2 once
Yeah, there are some strange goings-on in HFs made from functions.  I think I've
noticed the edge artifacts you mentioned.  But there's also the odd fact that
the applied pattern (or image_map) ends up being flipped upside down(?) like a
mirror-image, AND that the 'origin point' of the pattern/image is out of place.
The usual origin that we all know and love is at <0,0,0>; with a HF function,
the 'origin' is mysteriously at <0,0,1>, and the applied pattern/image
scales out from there. I've come up with simple workarounds to these particular
situations--but, along with the edge artifacts, it's apparent that HF functions
are not working correctly. I suppose, though, that re-engineering the
problematic code (whatever it is!) would cause lots of backward-compatibility
problems with previously-made scenes.
Ken
Date: 18 Dec 2009 06:10:01
Message: <web.4b2b61d2f654043d65f302820@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote:
> ...But there's also the odd fact that
> place...
BY 'image_map,' what I meant to say was "an image_map used as [or used as part
of] the HF function"--not an image_map *texture* applied to the HF afterward
(which is applied as it should be.) Sorry if that confused anyone.
Ken
Date: 18 Dec 2009 14:35:09
Message: <4b2bd96d@news.povray.org>
>> place...
It didn't confuse me, Kenneth :) It's an annoying problem, but easy
enough to work around. It probably should be fixed, but you're right
when saying that by doing so, many older scenes will be broken.
