POV-Ray : Newsgroups : povray.binaries.images : Transparant shadow? Server Time
27 Mar 2026 21:45:41 EDT (-0400)
  Transparant shadow? (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Transparant shadow?
Date: 11 Nov 2009 16:01:16
Message: <4afb261c@news.povray.org>
clipka escreveu:
> Jaime Vives Piqueres schrieb:
>>> clipka schrieb:
>>> ... and no, much to my surprise POV-Ray 3.6.2 ain't doin' it right
>>> either.
>>> How come it has taken so long for this one to surface? You'd think it
>>> was
>>> some trivial everyday case. And how the **** come I've done renders with
>>> ample such partially-transparent objects casting /proper/ shadows?
>>   I don't know... but this happened sometimes to me with certain PNG
>> files,
>> and not with others. For example, all the trasnparent PNG files I export
>> from Chief Architect seem to behave this way, but the ones from TORCS
>> I used
>> on my last post here and other scenes, work perfectly... except if I use
>> filtering media or fog, of course.
> I guess I got it.
> The following construct works properly:
>     texture { uv_mapping pigment { image_map { ... } }
> This one doesn't:
>     texture { pigment { uv_mapping image_map { ... } }
> Note the placement of the uv_mapping statement.
That's not a bug, that's a feature! ;)
yes, I've met it before and yes, I thought it was a feature... :P
a game sig: http://tinyurl.com/d3rxz9
Date: 11 Nov 2009 17:13:59
Message: <4afb3727@news.povray.org>
Not bloody likely.
Date: 12 Nov 2009 04:19:06
Message: <4afbd30a$1@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> schreef in bericht
news:4afb0def@news.povray.org...
>   Didn't test it, but looking at my own scenes now, I can confirm this
> finding: the ones I exported from Chief Architect where exported with
> Poseray, which puts the uv_mapping inside the pigment, indeed... you're
> fast, man!
Note that the latest version of Poseray puts the uv-mapping code *wrongly*.
Older versions did put it in the *right* place. I guess that is why I had
not noticed this really before.
Date: 12 Nov 2009 04:25:33
Message: <4afbd48d$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4afb0536$1@news.povray.org...
> I guess I got it.
> This one doesn't:
> I'll file an error report if nobody has done yet.
Yes, this works correctly, Christoph. Thanks!
I shall post a also a comment in povray.tools.poser for the difference in
Poseray.
Date: 12 Nov 2009 04:44:43
Message: <4afbd90b@news.povray.org>
"Stephen" <mca### [at] aolDOTcom> schreef in bericht
news:4afb0b35@news.povray.org...
> Stephen wrote:
LOL indeed!!
> Since it is a bug why not use a transparency map in the meantime?
It was because I did not use a transparency map that I discovered the
problem, but also that Poseray had changed the place of the uv_mapping code
in the latest version which led ultimately to the discovery.
Date: 12 Nov 2009 07:31:09
Message: <4afc000d$1@news.povray.org>
>> Stephen wrote:
> LOL indeed!!
Well it gave me something to do last night :)
Best Regards,
Date: 12 Nov 2009 07:39:37
Message: <4afc0209@news.povray.org>
news:4afc000d$1@news.povray.org...
Excellent! As they say here "Ledigheid is des duivels oorkussen" which my
dictionary translates as "Idleness is the parent of vice" or "The devil
always finds work for idle hands", but somehow I prefer the literal
translation "idleness is the devil's pillow". :-)
Date: 12 Nov 2009 08:37:32
Message: <4afc0f9c$1@news.povray.org>
Hijacking thread somewhat, and not sure if it's the latest version of
Poseray or not, but it exports Poser objects incorrectly (it might be a
setting I have ticked) and requires editing of the .inc file to
work...namely:
section
//This encapsulates the material into the mesh so that Moray can use the
original materials
#declare Victoria_4_hip_hip_2_hip__2_SkinHip_=...
(and so forth)
followed by:
//Model assembly from the meshes
#declare Victoria_4_hip_=
union {
object{Victoria_4_hip_hip_2_hip__2_SkinHip_uv_mapping}
object{Victoria_4_hip_rThigh_2_rThigh__2_SkinHip_uv_mapping}
object{Victoria_4_hip_rThigh_2_rThigh__3_SkinLeg_uv_mapping}
object{Victoria_4_hip_lThigh_2_lThigh__2_SkinHip_uv_mapping}
object{Victoria_4_hip_lThigh_2_lThigh__3_SkinLeg_uv_mapping}
split_union off
the problem is the fact that it does not declare any objects that end
with "_uv_mapping", making POV stall.  you have to manually remove the
"_uv_mapping" from each item in this part.  it doesn't take very long,
but it is a nuisance that shouldn't be necessary.
Tim Cook
http://empyrean.freesitespace.net
Date: 12 Nov 2009 08:44:59
Message: <4afc115b$1@news.povray.org>
Great! I must learn how to pronounce that for when our Dutch colleagues
complain that I am working them too hard, :)
Best Regards,
Date: 12 Nov 2009 10:58:50
Message: <4afc30ba$1@news.povray.org>
[snip]
> Tim Cook
Not being funny Tim but FlyerX is good at responding to emails and this
is getting quite a long thread. He might miss what you wrote. Or you
could start a new thread.
Best Regards,
