![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: cubic interpolation for image_maps (2 jpegs - 63kb)
Date: 6 Mar 2007 21:10:26
Message: <45ee1f12@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello everyone. I think there was a patch for this somewhere once... but
anyway.
Based on Tek's (very clever) blended cells pattern, I have made a small
macro which provides cubic interpolation between an image_map's pixels.
It's easy to use, as long as you can provide the exact width and height
for the input image. You can specify the amount of blurring to perform.
It could be useful for light probes, height_fields, or anything else you
could think of. The files are available now at p.b.scene-files. A basic
example file is included.
Hope it's useful to someone :)
~Sam
Download 'cubic_image_map2.jpg' (35 KB)
Download 'cubic_image_map1.jpg' (27 KB)
Preview of image 'cubic_image_map2.jpg'
![cubic_image_map2.jpg](/povray.binaries.images/attachment/%3C45ee1f12%40news.povray.org%3E/cubic_image_map2.jpg?ttop=430067&toff=3400&preview=1)
Preview of image 'cubic_image_map1.jpg'
![cubic_image_map1.jpg](/povray.binaries.images/attachment/%3C45ee1f12%40news.povray.org%3E/cubic_image_map1.jpg?ttop=430067&toff=3400&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: cubic interpolation for image_maps (2 jpegs - 63kb)
Date: 6 Mar 2007 21:13:01
Message: <45ee1fad@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Oh, I should have mentioned that the first example in each of the
attached images uses the macro. The rest are already available in the
current version of POV.
~Sam
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 7 Mar 2007 05:05:28
Message: <45ee8e68@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Funny, I did something similar a while ago, when I was trying to mimic
Terragen's rendering of height fields. Although obviously, our methods
differ. I was calling mine cubic interpolation back then but I'm not so
sure now... I'll have to re-check the source file to find out exactly
what it is doing ;-)
Anyway, here are the results I got. I'm not uploading the source because
it is not really readable as is, but if someone is interested I can
clean it up...
Regards
Vincent
Download 'interpolations.jpg' (231 KB)
Preview of image 'interpolations.jpg'
![interpolations.jpg](/povray.binaries.images/attachment/%3C45ee8e68%40news.povray.org%3E/interpolations.jpg?ttop=430067&toff=3400&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 7 Mar 2007 12:38:47
Message: <45eef8a7$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> clean it up...
> Regards
An easy-to-use macro of your technique would be useful, if it
renders/parses quickly. It is an improvement over linear interpolation,
that much is evident.
I was hoping that Tek's blended cells technique would work well for
height_fields, but as it turns out, those extra "Steps" don't look so
good... maybe if other things were done to the pigment it would be good.
Oh well :) I figured I should post it anyway.
~Sam
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 7 Mar 2007 14:35:03
Message: <esn40c$b2d$1@chho.imagico.de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> anyway.
Are you sure this actually does bicubic interpolation? The sample image
looks somewhat strange. Compare:
http://earth.imagico.de/img/hf_flat.jpg
http://earth.imagico.de/img/iso_cubic.jpg
BTW MegaPOV offers bicubic interpolation for image maps internally.
Views of the Earth: http://earth.imagico.de/
Images, include files, tutorials: http://www.imagico.de/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I don't think that's the effect you were looking for. I have taken a look at
your code, and if I understand correctly, you are making interpolation pixel
per pixel, but with cubic interpolation you need 4 pixels, so if you are
repeating it on the next pixel, you are overlapping the previous
interplation. I've never tried it, but I think you should skip to the next
block of 4*4 pixels (or maybe 3*3, considering continuity/differentiability
of the block's edges).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 7 Mar 2007 16:15:12
Message: <45ef2b60@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No, as a matter of fact, I am not sure. I figured since the cells are
blended with cubic_map, that meant it was using cubic interpolation. I
am not a great mathematician, by any means. I am more of a "math hacker".
> The sample image
Indeed. I was displeased with it.
> Compare:
> Christoph
This explains things... I am using MegaPOV v1.1! There was no
interpolate 3 with this version. Thanks for the heads-up, Christoph!
~Sam
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 7 Mar 2007 16:21:25
Message: <45ef2cd5@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hmm, you may be right. Christoph pointed me toward a new version of
MegaPOV which does what I want. If that works, then I won't improve my code.
~Sam
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 7 Mar 2007 23:41:48
Message: <45ef940c@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Samuel Benge" <stb### [at] hotmail com> wrote in message
news:45eef8a7$1@news.povray.org...
IMO the problem is it's only blending to the adjacent cell, and it always
uses pov's cubic curve rather than trying to maintain a smooth gradient. If
I'm understanding correctly Vincent's technique was actually doing cubic
interpolation, rather than just using cubic_wave (which isn't equivalent)...
Of course I'm saying all this without checking anyone's source code, but
since it's based on my blended cells I would expect it to create curved
steps where there should be a smooth gradient, which would cause the problem
you're seeing.
Wow I explained that really badly!
Tek
http://evilsuperbrain.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Mar 2007 04:34:46
Message: <45efd8b6$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> If I'm understanding correctly Vincent's technique was actually doing
> cubic interpolation, rather than just using cubic_wave (which isn't
> equivalent)...
Well I don't know if it was cubic interpolation proper, but looking at
my code it seems that I was attempting to keep a continuous slope at
each vertex, and likely along the sides of the cells as well. Indeed
there is a cubic polynomial (degree 3 in x and 3 in y, in fact) looming
in there, but no cubic_wave...
For now my code is horribly mangled, because it is doing some other
things such as blending with another pattern, etc. and I never tried to
extract the interpolation from there. I'll try to single out and clean
up this part, then post it.
I'm not too sure about the efficiency of my technique either, I
implemented everything with functions, and thus it spends a lot of time
re-computing things that could have been stored... I don't remember
exactly why I did it like that. It seems I have another non-working
version where I tried to use arrays... There could have been something
about being unable to read an array from inside a function, I believe.
Vincent
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
