POV-Ray : Newsgroups : povray.binaries.images : Challange.. Server Time
20 Mar 2026 14:22:36 EDT (-0400)
  Challange.. (Message 1 to 8 of 8)
Subject: Challange..
Date: 2 Nov 2005 14:23:20
Message: <43691228@news.povray.org>
This is kind of a challange..
The following image was modelled in MAX and
rendered with VRay.. it's not a master piece, I know,
but the challange is to reproduce it in POV-Ray.
That's the first part.
The second part is that I'd like to see a Tutorial of it.
Both of them are equally important.
When you finished, post the results here. ok?
If anybody is up to it, i.e.
Cheers,
Stefan
Download 'pov_clay.jpg' (183 KB)
Preview of image 'pov_clay.jpg'
Subject: Re: Challange..
Date: 3 Nov 2005 01:06:02
Message: <4369a8ca$1@news.povray.org>
That's pretty difficult. A good starting point would be the IsoCSG library:
http://www.imagico.de/pov/ic/
Though I'm far too busy (lazy) to attempt to recreate your image :)
Tek
http://evilsuperbrain.com
"Stefan Persson [azynkron]" <azy### [at] hotmailcom> wrote in message
news:43691228@news.povray.org...
> Cheers,
> Stefan
Date: 3 Nov 2005 05:37:38
Message: <4369e872$1@news.povray.org>
The only solution without using a modeler I can think of
is isosurfaces. And that would be pure math crunching, which
takes relative long compared to CA spline shaping.
Maybe I'll give it a try but not today.
Sebastian
Date: 3 Nov 2005 08:50:01
Message: <web.436a154abe30d582d71e0@news.povray.org>
> Sebastian
What about blobbed spheres filling a given csg form? Do a looped
random_inside (I think that's what it's called, I don't have time to look
it up now) of blob elements. It ought to give you something like that
texture. As far as getting the slightly goofy shapes, a hand-made mesh
might be pull-offable. Or maybe a macro that places mesh points around a
spline, for the text... hmmm. I'd be happy to try it, BUT it's November -
so I have a novel to write first. Maybe at christmastime.
-s
5TF!
Date: 3 Nov 2005 12:42:47
Message: <436a4c17$1@news.povray.org>
"Sebastian H." <van### [at] gmxde> wrote in message
news:4369e872$1@news.povray.org...
> Sebastian
Is "Without using a modeller" a rule to the challenge? I doubt MAX did it
without a modeller.
Date: 3 Nov 2005 18:20:00
Message: <web.436a9a22be30d58cd64761e0@news.povray.org>
> texture.
What is wrong with, after making the general shapes in an isosurface, just
applying a spotted shell? I don't think a "random_inside of blob elements"
is necessary, plus it would make the bumps too uneven.
Date: 4 Nov 2005 09:01:35
Message: <436b69bf@news.povray.org>
>>Sebastian
> without a modeller.
Since PoV-Ray is just a renderer which must be scripted I guessed so.
Otherwise the contest would not make that much sence as I could model
the scene in max again and export it to PoV.
Date: 4 Nov 2005 09:04:03
Message: <436b6a53$1@news.povray.org>
>>Sebastian
Could work. But the bumps can easily be added to an isosurface therefore
this was my first idea.
