POV-Ray : Newsgroups : povray.binaries.images : parchment Server Time
20 Jun 2026 04:25:04 EDT (-0400)
  parchment (Message 1 to 7 of 7)
Subject: parchment
Date: 10 Jul 2004 16:04:28
Message: <40f04bcc@news.povray.org>
Hello,
Is there a way to do this in Povray? With curling edges?
Thanks...
Wijnand Nijs
Download 'parchment.gif' (51 KB)
Preview of image 'parchment.gif'
Subject: Re: parchment
Date: 10 Jul 2004 17:57:59
Message: <40f06667@news.povray.org>
The best way would probably be to make an object (height field or maybe
bicubic patch or even a mesh) with regular edges, and then use an image to
texture_map it; have it transition between two textures, one transparent
(for the areas of paper which are ripped off around the edges) and one with
a paper texture.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 11 Jul 2004 10:25:11
Message: <40f14dc7$1@news.povray.org>
I'd say
 a mesh with normals that matches the stains: I
did something quite similar for my dominos. It's
supposed to be like dried paint.
For the edge, I'd do as Slime suggested.
Best,
    S.
Steven Pigeon, Ph. D.
ste### [at] stevenpigeoncom
ste### [at] videotronca
"Wijnand Nijs" <w.j### [at] alf4alldemonnl> wrote in message
news:40f04bcc@news.povray.org...
> Hello,
> Thanks...
> Wijnand Nijs
Download 'Dominos_04.jpg' (19 KB)
Preview of image 'Dominos_04.jpg'
Date: 12 Jul 2004 00:54:29
Message: <40f21985$1@news.povray.org>
> a paper texture.
Well, call me a masochist, but it should be able to be done somewhat
easily (conceptually, at least) with an isosurface.  And the texture
could be done as POV-texture, too, but would take some planning...;)
I'll avoid saying what I'm working on at the moment lest you think I'm
excessively bizarre (it can wait 'til I'm done, if I ever figure it
out...)
Tim Cook
Version: 3.12
Date: 12 Jul 2004 06:45:43
Message: <40f26bd7@news.povray.org>
Wijnand Nijs wrote:
> Hello,
> Thanks...
> Wijnand Nijs
Hello,
Height field, mesh or isosurface? Because I always wanted to start to do
something with isosurfaces, I started with the advice of Tom Cook.
Pov-help and the isosurface tutorial was a great help, but I have still
some problems. How to make the image transparent for the areas of paper
which are ripped off around the edges (advice of Slime)?
The source is:
#declare F = function {z+f_noise3d(x*5, y*5, 0)*0.3}
isosurface {
   function { abs(F(x,y,z))-0.05 }
     max_gradient 2
       image_map {gif "parchment.gif"}
       translate <0.5,0.5,0.5>
       scale 2
Some parameters must be tuned, first the big problems.
Thanks in advance...
Wijnand Nijs
Download 'thick.jpg' (59 KB)
Preview of image 'thick.jpg'
Date: 12 Jul 2004 06:59:12
Message: <40f26f00@news.povray.org>
Actually, I was thinking more of having the edges be part of the
isosurface, eliminating need for a transparency mask...I'm sure
some creatively applied noise to the perimeter would do the trick?
But if you want a transparency mask, example code would be
#declare Tex0    =texture{pigment{image_map{gif "parchment.gif"}}}
#declare Tex1    =texture{pigment{rgbt 1}}
#declare ParchTex=texture{image_pattern{gif "ParchmentMask.gif"}
texture_map{[0 Tex0][1 Tex1]}}
Tim Cook
Version: 3.12
Date: 12 Jul 2004 07:58:54
Message: <40f27cfe@news.povray.org>
Timothy Cook wrote:
>> still some problems. How to make the image transparent for the areas
>> of paper which are ripped off around the edges (advice of Slime)?
Hai Tim,
Nice not? The edges as part of the isosurface is for the future. Thank
for the help, also to the others.
Greetings...
Wijnand Nijs
Download 'thick-2.jpg' (56 KB)
Preview of image 'thick-2.jpg'
