POV-Ray : Newsgroups : povray.binaries.images : My LOTW project (145K) Server Time
13 Mar 2026 00:34:23 EDT (-0400)
  My LOTW project (145K) (Message 20 to 29 of 49)
Subject: Re: My LOTW project (145K)
Date: 29 Apr 2004 13:36:12
Message: <40913d0c@news.povray.org>
Mick Hazelgrove wrote:
> How did you get the foam along the waters edge?
   Casually, I'm just tweaking this texture. Now I simlified it a bit,
removing the intersection. The same terrain itself translated a bit is
enough. There is the relevant part:
  #declare terrain_coast=object{terrain translate Foam_Level*y}
  #declare m_water=
  material{
   texture{
    pigment_pattern{object{terrain_coast rgb 0, rgb 1}}
    texture_map{
      [0 t_water]
      [1 t_foam]
    scale 100 warp{turbulence .3 lambda 3} scale 1/100
    scale 1000 warp{turbulence .3 lambda 3} scale 1/1000
   The translation amount depends on your scene scale and how much foam
you want, and the same can be applied to the warps scale.
   The technique is simple, but I also expent many hours thinking on
that "foam challenge" along the years. Now I figured it casually while
looking at a foam tutorial by Patrick Merminod for a totally different
package: Vue d'Espirit.
Jaime
Date: 29 Apr 2004 13:48:39
Message: <40913ff7@news.povray.org>
Hash: SHA1
	You really shouldn't post photgraphs like that and pretend you did it
in POV, it's not fair ;)
	Very nice picture.
		Jerome
*      Jerome M. Berger      *
* mailto:jbe### [at] ifrancecom *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAkT/2qIYJdJhyixIRAvf9AJ4uAW+9VfsOjc4pd8vbQ8kCUBtsFACfX37v
Ta8DDG8ipSiTQNUpAnQhIsQ=
=9LJi
-----END PGP SIGNATURE-----
Date: 29 Apr 2004 13:55:02
Message: <c6rf9j$95k$1@chho.imagico.de>
Jaime Vives Piqueres wrote:
>   Well, they are prety pathetic right now, although the placement idea
> with eval_pigment() and crackle pigments looks promissing (I've attached
> a more close view).
Neat, but must take quite long to parse...
Of course no serious farmer would create such perfect crackle fields.  I
assume developing an algorithm to automatically generate realistic
divisions would be quite tricky though.
Last updated 21 Mar. 2004 _____./\/^>_*_<^\/\.______
Date: 29 Apr 2004 15:35:00
Message: <web.409158b5ca34d7b9a0c272b50@news.povray.org>
> Hi all:
> I've started my own "Landscape of the week" project, following the idea
>    and general concepts of the LOTW project by Christoph Hormann. I'm
> really amazed of what he achieved with isosurfaces, so I tried too...
DAMN NICE!
I think I'm experiencing iso-envy...
RG
Date: 29 Apr 2004 16:40:54
Message: <40916804.6040900@hotmail.com>
> Hi all:
Jamie, I was caught off-guard by your image. Suddenly there was this
photo-realistic image of a landscape before me... My mind thought, "it
must be Christoph!" right before I saw your name.
Very, very good work! Inspiration has been a trickle for me lately. With
images like this, however, I might just overcome this creativity barrier
I'm standing in front of.
> Well, I hope to not abandon also this project, as I do with 99% of my
> proyects lately. I've a sort of sinusoidal inspiration these days...
> Regards,
> Jaime
You really should continue with this idea! You can cover some ground
Christoph hasn't yet. In fact, you've already advanced on a few things.
I'd like to see fluted columns of eroded stone and limestone cave
entrances eventually. Maybe those are some landscape elements I'll try
to depict :)
-Samuel Benge
Date: 29 Apr 2004 17:13:55
Message: <40917013$1@news.povray.org>
OK, ok, I'll learn how isosurfaces work, already. :-)
Date: 29 Apr 2004 17:20:26
Message: <4091719a$1@news.povray.org>
Zeger Knaepen wrote:
>>   Ouch! I'm using only 1 interval!!! Let's hope there is a
>>workaround... these clouds are already slow.
> there is: merge the container-objects
> hmm, at least, I think that should work :)
   Nope, this is a strange fog problem. It doesn't shows if I replace
the standard ground fog with a planar emission media... weird. But well,
I found the workaround, and it's not much slower than fog. Thanks anyhow!
Jaime
Date: 29 Apr 2004 17:20:31
Message: <4091719f@news.povray.org>
Clever
and useful :-)
Date: 29 Apr 2004 17:47:27
Message: <409177ef@news.povray.org>
stephen parkinson wrote:
> first thought, where is it? second - photo, third - has the Loch Ness
> monster moved residence :-)
   You mean the foam in the middle of the lake? This is a side effect of
the foam technique... nothing misterious, I hope: I've enough with the
artifacts! :)
> some silly questions
> what is the range of x,y,z in the pic for the iso-surfaces?
   The container is box{<-200,0,-200>,<200,8,200>}, although the peaks
rarely reach the "ceil". I tried to keep the scene scale somewhat like
1=1km.
> do you do the iso as <-1,-1,-1> to <1,1,1> and scale ?
   No, I never scale isosurfaces! I've the superstitious believe that
scaling them increases render times...
> how do you do the houses, csg - yes- but what size typically as a
> standalone object for devel, and then scale by some factor, to fit in,
> process of emphirical adjustment until it looks right?
   They are just a bunch of boxes. I scale them randomly to have sizes
between 5 and 15 metters of side (in the scene scale).
> please post source or some tantalising snippets to aid understanding ?
   Wait, I'm still cleaning and commenting it. And the web page for the
LOTW project must be done too...
Jaime
Date: 29 Apr 2004 17:58:53
Message: <40917a9d@news.povray.org>
Samuel Benge wrote:
> My mind thought, "it must be Christoph!" right before I saw your name.
   That was the idea.. :)
> to depict :)
   Oh, yes... me too, but my patience with max_gradient is limited. The
worst part is: I know that almost everything is posible with
isosurfaces, but who has the patience needed for all the tests?
Jaime
