POV-Ray : Newsgroups : povray.binaries.images : More Faked Volumetrics (35k jpeg) Server Time
15 Jul 2026 08:05:05 EDT (-0400)
  More Faked Volumetrics (35k jpeg) (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: More Faked Volumetrics Update (31k total, 2 jpegs)
Date: 8 Apr 2004 15:51:48
Message: <4075ad54@news.povray.org>
> I attached two more images. The first one has the surface normal in
> place and uses aa. The second uses no surface normal, but still has aa.
> The render times are diplayed in the lower right corner of each image.
Number two looks better (IMHO) and renders faster. Looks like a winner to
me.
Nice technique, BTW.
Regards!
Subject: Re: More Faked Volumetrics (35k jpeg)
Date: 8 Apr 2004 17:03:19
Message: <4075be17@news.povray.org>
Uzytkownik "Samuel Benge" <stb### [at] hotmailcom> napisal w wiadomosci
news:407### [at] hotmailcom...
> Hello everyone! Here's an idea I've been thinking of for quite a while.
> I'm pretty sure somebody has done something like this before... it might
> have been a grass texture, though.
> What you see is actually a flat plane layered with over eighty
> semitransparent textures. Each additional texture is scaled slightly
> larger than the last, and uses a slightly altered color_map (actually a
> pigment_map, but it doesn't really need to be one anymore). The texture
> is then translated to the camera's X & Z coordinates to achieve a more
> proper illusion.
> I can't really see a practical application for this trick. Even though
> this image rendered in a little over five minutes, it can get very slow
> when antialiasing is applied :(  Also, POV-Ray tends to throw an error
> if the number of texture layers goes over 100.
It may come handy at rendering backdrops to aerial scenery (e.g. a flying
aeroplane).
> I still have yet to try it with radiosity. There's no reason why it
> shouldn't work.
> The code has been placed (a little too hastily) to
> povray.binaries.scene-images.
> Questions and comments are always welcome-
> -Samuel Benge
Respectfully
Matt
Date: 8 Apr 2004 18:55:30
Message: <4075d862$1@news.povray.org>
<snip:technical />
BRILLIANT idea! It may cause some challenges for the renderer if objects
  are within those planes. Have you found any trouble with, say, a
sphere in the middle of the clouds?
Respectfully,
Dan P
http://<broken link>
Date: 8 Apr 2004 21:18:24
Message: <4075f9e0$1@news.povray.org>
Samuel Benge nous apporta ses lumieres ainsi en ce 2004/04/08 15:33... :
>> though this image rendered in a little over five minutes, it can get
>> very slow when antialiasing is applied :(
> Update:
> I just tried it again with antialising, and the render time didn't
> really go up that much. Evidently, the last time I tried aa the
> texture had a lot of noise in it. Also, removing the surface normal
> considerably decreases render time.
> aa. The render times are diplayed in the lower right corner of each
> image.
> -Samuel Benge
Second one looks beter for a flyby over some clouds, the first should be
beter for a snowy field. For me anyway.
Date: 8 Apr 2004 21:31:58
Message: <cjameshuff-6BB5D0.21324408042004@news.povray.org>
In article <4075d862$1@news.povray.org>,
Well, since it's on a 2D surface, it'd look a bit odd...
BTW, I vaguely recall some very good sky_sphere pigments done using this
technique. One advantage there is that you don't have any intersection
or finish/normal calculations, so it renders faster. The layered pigment
feature of sky_spheres seems to be overlooked far too much.
http://tag.povray.org/
Date: 8 Apr 2004 21:40:47
Message: <4075ff1f@news.povray.org>
I misunderstood what he did; I thought he used many planes with seperate
transparent image_maps. I should have looked at the source; my bad.
Respectfully,
Dan P
Date: 8 Apr 2004 21:47:58
Message: <4076007F.7080109@hotmail.com>
Looks like something I'll have to try. Thanks.
-Samuel Benge
Date: 9 Apr 2004 10:51:49
Message: <4076b885$1@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote in message
> -Samuel Benge
*drool* Practical applications are overrated and can alwasy come later :)
this alone is cool.
Date: 9 Apr 2004 12:06:35
Message: <4076ca0b@news.povray.org>
Note that this only works when looking at the origin. Try looking at a spot
300 units to the right/left. The scaling scews the volumetric effect
outwards. That aside, neat thing.
"Tim Nikias v2.0"
Date: 9 Apr 2004 18:26:47
Message: <40772327@news.povray.org>
> objects
Why not a plane? (Or both, scnr)
Dave
Dave "tPassive" Vogt| ruby -e "n=gets.to_i;a=(2..n).to_a;a.each{
Linux  user  #225040| |x|puts x;(x*2).step(n,x){|j|a.delete j}}"
____________________|_____________________________             |
PGP Key: http://frozenbrain.com/public_key.asc    \____________/
