POV-Ray : Newsgroups : povray.binaries.images : Glowing Tube - 1 attachment Server Time
30 Apr 2024 19:38:52 EDT (-0400)
  Glowing Tube - 1 attachment (Message 1 to 10 of 14)
Subject: Glowing Tube - 1 attachment
Date: 21 May 2003 22:30:25
Message: <Xns93832EE059E8Btorolavkhotmailcom@204.213.191.226>
I guess you all must be tired of this shape now...
I'm trying to make a similar effect to the glow effect that Ryan Bliss
has used in some of his images. Here's such an image:
http://www.digitalblasphemy.com/dbgallery/6/fluorescence6.shtml
Every triangle in the mesh2 for my tube shape is textured individually.
(Maybe media are needed to get closer to Ryan's fluorescence effect.)
While my image was rendering, I read some old posts on the POV-Ray
server about glowing. I found that Christoph Hormann once posted a nice
"glowing tree" image and that he mentioned that he used a "aoi pattern"
for the texture. Here's that thread:
http://news.povray.org/povray.binaries.images/30297/
I couldn't remember this pattern from the documentation, so I went
googling - and found that it is a feature in MLPov; the "angle of
incidence" pattern.
Maybe a similar effect can be achieved with this pattern. But I wonder
if it will work for surfaces positioned "behind" a semitransparent
surface (like in my tube shape).
Tor Olav
Download 'B-Splines03_09_13_20.jpg' (42 KB)
Preview of image 'B-Splines03_09_13_20.jpg'
Subject: Re: Glowing Tube - 1 attachment
Date: 22 May 2003 02:14:11
Message: <jdqocvc40cvh7cb8dm3eu204tbel9m7hei@4ax.com>
On 21 May 2003 22:30:25 -0400, Tor Olav Kristensen <tor_olav_kCURLYAhotmail.com>
You..., you..., you damned math artists ;-)
ABX
Date: 22 May 2003 08:47:14
Message: <3eccc6d2$1@news.povray.org>
de news:
Actually aoi-like images can be done with the slope pattern in regular 3.5:
#include "functions.inc"
#declare cam_location=-z*5;
#declare cam_lookat=<0,0,0>;
camera {location  cam_location look_at cam_lookat}
isosurface{
    function{f_sphere(x,y,z,1)-f_noise3d(x*2,y*2,z*2)*1}
    contained_by{sphere{0,2}}
    max_gradient 3.141
            slope {cam_lookat-cam_location,0.6}
            color_map{[0 rgb z*2][1 rgbft 0]}
        finish {ambient 1}
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 22 May 2003 09:06:42
Message: <3ECCCB62.CF5C99D5@gmx.de>
> incidence" pattern.
It will but i did not use transparency for my trees.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 22 May 2003 09:32:32
Message: <3eccd170$1@news.povray.org>
Only with an orthographic camera (or a camera with a very small angle).
Rune
rune|vision:  http://runevision.com (updated Oct 19)
POV-Ray Ring: http://webring.povray.co.uk
Date: 22 May 2003 10:12:25
Message: <3eccdac9@news.povray.org>
3eccd170$1@news.povray.org...
The code I posted with the message does produce something which looks a lot
like an aoi pattern with a regular camera and can be used as such in
practice, even if it's not technically one for some reason (which is why I
said "aoi-like").
G.
- Posters
Date: 22 May 2003 11:24:47
Message: <3eccebbf@news.povray.org>
3eccdac9@news.povray.org...
is not"some reason" because slope vector is constant while aoi vector has
its origin at cam_pos?
Is not there a possibility to get a variable slope vector based on a
f(x,y,z) function?
Well I know I'm only asking questions because I have no answer :-)
 Marc
Date: 22 May 2003 12:40:38
Message: <3eccfd86$1@news.povray.org>
This is a beautiful effect. Can someone tell me how the slope feature is
working to create this? (I'll take the answer in Newusers if necessary).
Also, slope doesn't seem to work with image_maps... Are there other
limitations to its use with various types of pigments or would that be the
main one?
Thanks very much,
Dennis
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:3eccc6d2$1@news.povray.org...
message
> de news:
3.5:
> isosurface{
>     max_gradient 3.141
>     texture {
>         pigment {
>         finish {ambient 1}
> G.
> - POV-Ray and Poser computer images
> - Posters
Date: 22 May 2003 14:19:58
Message: <3ecd14ce$1@news.povray.org>
3eccfd86$1@news.povray.org...
Note: I didn't invent this technique, Kari Kivisalo did.
Slope at a given point uses the angle between the direction value and the
normal on the surface at that point In this case the direction value is the
camera_location->look_at vector. Points looking at the camera get a black
texture and points looking perpendicular at the camera (the ones on the
surface edge) get a blue one.
In fact the code I posted should be rewritten as follows to be more
consistent with the docs :
    texture {pigment {slope {cam_lookat-cam_location,0,0.6}
            color_map{[0 rgb 0][1 rgb z*2]}}
            finish {ambient 1}
It's not a "true" aoi effect because a real one should use (I suppose) the
normal/camera->surface_point angle, not the normal/camera->look_at angle,
but the approximation works for artistic purpose. I could be mistaken
though.
Hmm, slope works fine with image_maps. I guess that your problem is trying
to use a map_type 0 map on a very concave/convex object... map_type 0 image
maps only works well on relatively flat objects (such as terrains), whatever
the pattern. On other objects, the map needs to be a non-planar uv_map
(map_type 1 on a sphere etc., or uv_mapping) to get proper results.
In fact my most common use for the technique is to create for poser models
skin maps (uv) finishes having higher diffuse values at shallow angles.
> Are there other
> main one?
The main limitation is that it doesn't work with turbulence. A workaround
for this consists in putting slight variations of the slope map within a
pigment map controlled by a pigment pattern :
pigment{pigment_pattern{agate...}pigment_map{[0 slope...][0.5 slope...][1
slope...]}}
Slope isn't a easy pattern to figure out though.
G.
- Posters
Date: 22 May 2003 19:13:13
Message: <3ecd5989$1@news.povray.org>
Great explanation. Thanks very much. I will try my image map again.
Best,
Dennis
news:3ecd14ce$1@news.povray.org...
the
>             finish {ambient 1}
> though.
whatever
> > Are there other
the
> > main one?
> slope...]}}
> G.
> - Posters
