POV-Ray : Newsgroups : povray.binaries.images : rendering mars [51+91k] Server Time
24 Aug 2025 01:05:57 EDT (-0400)
  rendering mars [51+91k] (Message 1 to 4 of 4)
Subject: rendering mars [51+91k]
Date: 18 May 2003 05:31:18
Message: <3EC752E4.FCFDBF5D@gmx.de>
I tried the same technique i used for the earth some time ago, see:
Subject: rendering the earth (71k+68k)
Date: Tue, 01 Apr 2003 22:57:55 +0200
Newsgroups: povray.binaries.images
for rendering the Mars surface.  The topography data is from:
http://wufs.wustl.edu/missions/mgs/mola/megdr.html
and the coloring uses a much lower resolution image.
The first image shows the whole planet, rendered in various tiles like
before.  The second image shows a closeup view of Valles Marineris.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Download 'mars_l.1024.jpg' (51 KB) Download 'mars_spec1.1024.jpg' (91 KB)
Preview of image 'mars_l.1024.jpg'
Preview of image 'mars_spec1.1024.jpg'
Subject: Re: rendering mars [51+91k]
Date: 18 May 2003 08:25:04
Message: <web.3ec77b13d1cc6f933043c8520@news.povray.org>
very nice.
as i understood from your earth renderings, rendering animations of this is
not possible. (becouse of the render time)
dit the color map contain any shadows? or did you position your "sun" at a
position matching the color map?
jaap.
Date: 18 May 2003 13:58:51
Message: <3EC7C9DC.62F6F4CC@gmx.de>
Jaap wrote:
> very nice.
Thanks.
Nothing is impossible.  In fact these render quite fast.  But for an
animation you don't need such high resolution, therefore other techniques
will probably be more efficient.
There was shading in the image used for texturing.  The worst thing was
that it is a composite of different images with varying shading, therefore
it was quite impossible to remove it.  A strong blur helped but of course
you loose a lot of detail this way.
Date: 18 May 2003 15:21:07
Message: <3EC7F990.B634CD37@tiscalinet.de>
High!
Gorgeous images, especially the Valles Marineris close-up... no vertical
exaggeration? But still some nitpicking - normally, Martian atmosphere is
never completely cloud-free, there are always some whispy haze clouds. Are you
sure that the Martian sky really blends from light pink via dark blue to
black?
I rember an orbital Viking shot showing no blueish gradient at all (attached
here)
Still another problem: I tried your link to the high-res Mars maps and
downloaded a small version (4 pixels/degree), but neither Irfan View nor the
GIMP can handle these IMG files - I only get error messages! What can I do?
See you in Khyberspace - http://home.arcor.de/yadgar/khyberspace/index-e.html
(those of you speaking German should take a look at
http://home.arcor.de/yadgar/khyberspace/raytra-d.html !)
Afghanistan Chronicle: http://home.arcor.de/yadgar/index-e.htm
Yadgar
Now playing: Johann Sebastian Bach, Brandenburg Concerto #2 F major, 2nd
movement (Andante), London Philharmonic Orchestra, conductor: Otto Klemperer
Download 'martian atmosphere.jpg' (159 KB)
Preview of image 'martian atmosphere.jpg'
