POV-Ray : Newsgroups : povray.binaries.images : Variable radiosity parameters test (~220k) Server Time
23 Dec 2025 23:48:10 EST (-0500)
  Variable radiosity parameters test (~220k) (Message 1 to 10 of 16)
Subject: Variable radiosity parameters test (~220k)
Date: 1 Sep 2002 12:42:48
Message: <3D724384.B9BF687F@gmx.de>
I have made some tests with variable radiosity parameters.  See
news://news.povray.org/3d6f88fa%40news.povray.org
for the discussion on this subject.
Varying count seems much more useful than varying error_bound.  It's also
possible that changing error_bound depending on the position has some side
effects that are problematic.  In any case the overhead produced by a
function based count value is much lower since the function only has to be
evaluated for every radiosity sample taken while an error_bound function
has to be called for every Compute_Ambient() call.
The following pictures show a fairly simple example.  The first is
rendered with a fixed count of 60, the second with varying count.  The
last shows the simple function used for defining the count: red means low
count (<20), yellow 20-50, blue >50.
The render times were:
 126 seconds for fixed count
 138 seconds for variable
about 13000 radiosity samples (and function VM calls), error_bound was
0.4, pretrace_start 1, pretrace_end 1/image_width, recursion_limit 2.
I think the difference is noticeable, notice especially the artefacts on
the outside of the cubicle.  Anyway the parts with low count are looking
noticably worse too and the render time is longer.  Testing with a real
scene and a better optimized function for the count value would be
important of course.
Download 'var_rad_1.png' (70 KB) Download 'var_rad_2.png' (74 KB) Download 'var_rad_fn.png' (77 KB)
Preview of image 'var_rad_1.png'
Preview of image 'var_rad_2.png'
Preview of image 'var_rad_fn.png'
Subject: Re: Variable radiosity parameters test (~220k)
Date: 3 Sep 2002 09:40:28
Message: <3D74BBC8.97037B2@gmx.de>
No comments concerning this?
At least some 'looks useful' of 'i could not think of anything this would
be needed for' would be nice.
Date: 3 Sep 2002 09:46:07
Message: <3d74bd1f$1@news.povray.org>
Okay, okay, a comment. The variable version
does look better, but how difficult is it to set?
I mean, if you simply have to add "use_variable_count on",
that's nice, but if you'd got to build a function
describing the basic layout of the scene...
Don't know.
Tim Nikias
Email: Tim### [at] gmxde
Date: 3 Sep 2002 09:49:54
Message: <m9f9nu8l72vd1ugvaq1ie3ptb51aqeo2bn@4ax.com>
On Tue, 03 Sep 2002 15:40:24 +0200, Christoph Hormann <chr### [at] gmxde>
I'm an amoteur in radiosity so not started anything, sorry
Nice colors. :-)
ABX
Date: 3 Sep 2002 10:29:20
Message: <3d74c740@news.povray.org>
OK: Some day I should also start to care about radiosity parameters --
at least to the extent that I understand your post. ;-)
Date: 3 Sep 2002 10:31:25
Message: <3D74C7B8.D77FE9DF@gmx.de>
Well, if you have a suggestion how to define the count that is easier to
set up i would be pleased to hear.  As already explained defining it on
per object basis would not be very useful.
And it's not that difficult with functions after all, you can for example
use a df3 file to describe what parts of the scene you need high count
for.
Another idea i have been thinking about is adaptive count.  This would
mean when taking a sample the program shoots a minimum number of rays,
analyzes their results and decides whether to shoot more.
Date: 3 Sep 2002 10:43:10
Message: <3D74CA7E.E59ED0AA@gmx.de>
ABX wrote:
> Nice colors. :-)
I already feared to get replies like that now, but considering radiosity
was quite commonly used recently i assumed there would be more interest in
such extensions.
Date: 3 Sep 2002 12:24:11
Message: <3d74e22b@news.povray.org>
> for.
  That's inseresting...
  ...but that would be ideal for lazy raytracers like me. I always prefer
these things to be automatic (because if they depend on my knowledge of
inner working, I'm lost).
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 3 Sep 2002 12:45:27
Message: <3d74e727@news.povray.org>
3D74CA7E.E59ED0AA@gmx.de...
> such extensions.
I guess that the lack of answers is due to the fact that demo doesn't show
off the benefit of it as some artefacts disappear but other come up (like
the brighter spots in the middle of the walls or on the underside of the
door). And the render time is longer too, which is an undesired effect I
suppose.
Still any idea about controlling the radiosity quality is interesting and
may prove to be valuable, so keep on trying !!! And like Jaime says, the
more automatic the better...
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 3 Sep 2002 13:51:09
Message: <3D74F68D.386A557D@gmx.de>
But it would not have the same effect.  With the demonstrated technique i
intended to give the user a tool to do something about specific artefacts
by locally increasing the count value.  The adaptive method would (if it
works, i have not tried yet) increase quality in general while not
increasing render time too much.  Without doubt this would be useful, but
it would not be a replacement for the other technique.
