POV-Ray : Newsgroups : povray.binaries.images : Concave shapes (43KB) Server Time
16 Mar 2026 21:05:56 EDT (-0400)
  Concave shapes (43KB) (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Concave shapes (43KB)
Date: 8 Oct 2000 18:30:52
Message: <39E0F57C.F4D1F1E0@hotmail.com>
John VanSickle wrote:
> Tor Olav Kristensen wrote:
> > Yesterday I did some more work on some CSG-macros of mine.
> > They will "round off" any concave shape made with intersections
> > of planes, like the upper left shape.
> Nota bene:  The shapes depicted are convex, not concave.
Ugghh...  -How did that happen ?!
I even looked up convex in the dictionary
to make sure that this wasn't only a
norwegian word before I wrote the post.
> > The lower right shape shows how the resulting shape looks
> > like if both the edges and corners are wounded off.
> > The rendering is slow, so now I'm working on the macro
> > so that it will render much faster.
> It's possible that making each face into a prism will help.
> This might be difficult, however.
Yes I think you're right. I like that idea.
Prisms would probably make it faster.
It would not be very difficult. The needed
data are already available within my macros.
But it will be some work determining how
data should be passed between the different
macros in an efficient way.
There's one problem with prisms though:
The "stones" could not be used in further
CSG operations. E.g. like I did in my image;
"Two spheres" posted to this news group 26.
April:
news://news.povray.org/3906D341.F1CD358C%40online.no
The two metal spheres are put inside the
"space" cut out by a convex shape "rounded off"
by some preliminary versions of these macros.
Tor Olav
mailto:tor### [at] hotmailcom
Date: 8 Oct 2000 18:38:17
Message: <39E0F73A.B0E029C8@hotmail.com>
Bob Hughes wrote:
> You're quite the wizard with this kind of thing Tor, manipulating CSG
> objects.  I just wanted to say that.
Thank you !  - I'm flattered :)
> Any chance this could merge with one of the rock making includes?  Then
> again, if this is slow and the rock makers are already slow it might be too
> much for the typical scene file.
I'll look into it. Where can I find these
rock making includes ?
> If the amount of roundedness can be adjusted it certainly could do well for
> worn edges of such shapes anyway.
The roundness can be adjusted by setting
a "rounding radius" for the corners and
the edges.
Tor Olav
Date: 8 Oct 2000 18:56:10
Message: <39E0FB6B.A7DFECE0@hotmail.com>
> looks good, how did you do it ? just CSG with planes, cylinders and spheres?
The starting (convex) shape is just
intersections of all the involved planes.
Then one macro takes info about these planes
and calculates where every possible triple
of non parallel planes meets at potential
corners (points).
Then another macro removes all the corners
that are "false" (I.e. those that have one
or more planes "below" themselves.)
Then some other macros receives the data
about the final "true" corners and
constructs the shapes (CSG with cylinders
and spheres) that are used to "subtract"
from the starting shape.
> I suppose parsing will also be quite slow when working with complicated shapes.
Yes, but not unbearable slow (as the pre-
liminary macros was).
> > When I'm finished with the macros I'll post the source code
> > if anyone is interested.
> Sure we are :-)
> I estimate it's quite a lot of work doing it, so thanks in advance...
Yes, there's a lot of info to manage within
the macro. But I've now manage to make them
much faster. But there's still some work
left to make them stop calculating the same
things over and over.
Maybe I can force myself to post some code
soon, even if I'm not satisfied with it yet.
Tor Olav
Subject: Re: truncated cubes.
Date: 8 Oct 2000 19:00:45
Message: <39E0FC7F.44BB1E09@hotmail.com>
"Greg M. Johnson" wrote:
> I want the coordinates for a truncated cube, in terms of triangles.
> Can anyone point me to a reference for this?
> In other words, I have seen the list of triangles needed for a cube/
> rectangular solid based on 2 corner points.  I want 2D projection of this
> solid to be, instead of a square, a symmetric 8-sided figure.
I'm not sure if I understand what you mean.
Can you try to explain more or post an
image of this shape (e.g. made by inter-
section of planes) ?
By truncated cube, do you mean that the
original corners are "cut" off ?
Tor Olav
Date: 8 Oct 2000 23:10:35
Message: <39e1372b@news.povray.org>
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:39E0F73A.B0E029C8@hotmail.com...
I'm having no luck finding the rock includes or macros, sorry.  One thing is
John Van Sickles and it seems Chris Huff may have something too (not sure),
and at the POV Objects Collection...  Steve Pidgeon was another person that
did one I know.
Date: 8 Oct 2000 23:21:54
Message: <39E1376B.51EDCFE6@faricy.net>
If you have a cube going from <-1,-1,-1> to <1,1,1> and you want to truncate
it so each of the original six faces becomes a regular octagon, then the
vertices would be at
(2^3+2^3+2^3=24 vertices)
Date: 9 Oct 2000 02:19:05
Message: <39E1622C.580FBDDA@pacbell.net>
> did one I know.
> Bob
If I'm not mistaken John has removed his rock include from his
website but he may have included it with his subdivision surface
suite - http://users.erols.com/vansickl/sss.htm which is in it's
own right a fun toy to play with.
Steve's site is at:
http://www.iro.umontreal.ca/~pigeon/pub/PovPage/RockGen/RockGen.html
See also:
http://www.rahul.net/endl/mallan/html/rocks.htm
http://www-personal.umich.edu/~mstock/pages/rocktools.html
Date: 9 Oct 2000 06:06:24
Message: <MPG.144ba8e7cb24f838989804@news.povray.org>
On Sun, 08 Oct 2000 23:14:04 -0700, Ken wrote...
I had a look at that URL, and it seems that the Surface Subdivision Suite
page has moved to /dev/null <grin>, as the URL you posted points to a new
page, which gives a 404...
John?
Bye for now,
     Jamie.
Date: 9 Oct 2000 08:21:28
Message: <39e1b848@news.povray.org>
Any chance of you posting the macro code itself...
Rarius
Date: 9 Oct 2000 08:33:04
Message: <39E1B9BD.60A199EA@my-dejanews.com>
Thanks, but what I meant is this:
Take  perfect cube.  set each edge on a grinding wheel such that the normal of
the two faces on this edge make a 45 degree angle with the normal of the
grinding wheel.  Do it for just a second or two.
