POV-Ray : Newsgroups : povray.binaries.images : Dog Bone with Yellow Peas (44 KB) Server Time
22 Sep 2025 07:41:14 EDT (-0400)
  Dog Bone with Yellow Peas (44 KB) (Message 1 to 9 of 9)
Subject: Dog Bone with Yellow Peas (44 KB)
Date: 8 Jul 2000 22:04:10
Message: <3967DD13.6D0994C8@online.no>
I used my blob macros another way (than in my
"Two blobs" posting) to create this image.
This time there is only one blob and many
small spheres.
Tor Olav
mailto:tor### [at] hotmailcom
Subject: Re: Dog Bone with Yellow Peas (44 KB): The Image
Date: 8 Jul 2000 22:06:08
Message: <3967DD7D.F004527D@online.no>
Sorry. I forgot to enclose the image.
Here it is.
Tor Olav
Download 'blobtest20.jpg' (44 KB)
Preview of image 'blobtest20.jpg'
Date: 8 Jul 2000 22:16:07
Message: <3967e067@news.povray.org>
A dumbbell with no-slip grip might have been a better choice of words  :-)
Seeing objects follow the contours of a 'blob' is no less than amazing to me.
Have you done more exotic shapes?
Date: 8 Jul 2000 22:37:38
Message: <3967E4EA.5D8BED36@online.no>
I have never had problems with dumbbells
slipping out of my hands !  =)
I'm only using some macros (in plain POV)
to make a 3D-map of the accumulated "field
strengths" of the different components in
the blob.
Other macros then use this 3D-map to
select points in space with the "right"
"field strength".
These points can again be used for new
components in a blob or for placing other
objects.
No not yet.
I don't have much experience with blob
modelling. And I have to many other
projects to take care of, so I haven't
got enough time to experiment much
with these macros.
(But I have ideas of some shapes :-)
At this moment my macros can handle
any blobs made of sphere components.
They can have different radius and
strength, but they cannot be scaled.
(Maybe some day I'll improve them so
that they can  take scaled spheres and
cylinders too.)
Tor Olav
Date: 9 Jul 2000 00:38:50
Message: <3967F3E8.B9FD1B37@peak.edu.ee>
That looks just plain kinky :)
Margus Ramst
Date: 9 Jul 2000 11:46:12
Message: <chrishuff-6A36F8.10463109072000@news.povray.org>
In article <3967E4EA.5D8BED36@online.no>, Tor Olav Kristensen
> the blob.
> "field strength".
> objects.
Seems like using trace() in MegaPOV would be a much more efficient
solution...it would also work with cylinder components, and scaled
components.
Or if it is really the field strength you want, you could use
eval_pattern() with the blob pattern...though this would also require
MegaPOV.
Or you could use vtransform() to allow transformations to be applied to
the components in your macros. Again, this would require MegaPOV.
Date: 10 Jul 2000 21:54:22
Message: <396A7DDA.970C6F5A@online.no>
> > the blob.
> > "field strength".
> > objects.
> components.
As I understand from the documentation,
trace() can not provide the initial
points to "shoot" vectors from.
Nor can it provide the directions in
which to point the vectors so that
they point towards the blob surface.
(Or is there available a "field
direction" function in MegaPOV ?)
For complex blob shapes it will not be
enough to "shoot" several vectors from
a circle centre towards the circle
surface (nor from the surface towards
the centre).
But my macros can make use of trace()
to find the exact positions of the
blob surface once it knows all the
points to "shoot" from and in which
direction to "shoot" the vectors.
> MegaPOV.
I agree. This sounds like a faster way
to determine the "file strength" at a
point.
I haven't read anything about
vtransform() yet.
Is it a MegaPOV feature ?
Tor Olav
Date: 10 Jul 2000 21:57:09
Message: <396A7E89.158CFF59@online.no>
And what associations, exactly, do
you get when looking at this image ?
Tor Olav
Date: 12 Jul 2000 15:38:47
Message: <chrishuff-FE2CAE.14390912072000@news.povray.org>
In article <396A7DDA.970C6F5A@online.no>, Tor Olav Kristensen
> As I understand from the documentation, trace() can not provide the
> initial points to "shoot" vectors from.
It doesn't...how would it know where you want to look?
> Nor can it provide the directions in which to point the vectors so
> that they point towards the blob surface. (Or is there available a
> "field direction" function in MegaPOV ?)
There is not, though it wouldn't be too difficult to figure out with a
macro and eval_pattern().
> For complex blob shapes it will not be enough to "shoot" several
> vectors from a circle centre towards the circle surface (nor from the
> surface towards the centre).
> But my macros can make use of trace() to find the exact positions of
> the blob surface once it knows all the points to "shoot" from and in
> which direction to "shoot" the vectors.
One possible way of doing it would be to trace() in a 3D grid,
continuing on after each intersection on the same line. This wouldn't
provide a very even coverage, though...actually, it would probably give
something like the image you posted.
You might also trace in random directions from the center of each
component. This wouldn't work for every blob, but it should produce some
interesting results.
> I agree. This sounds like a faster way to determine the "file
> strength" at a point.
You mean "field strength"? :-)
It could also take a blob object which has already been defined, if you
are using the latest version of my MegaPOVPlus blob pattern patch(which
is available at my web site and probably will be in the next MegaPOV).
> I haven't read anything about vtransform() yet.
Yes. It just takes a transformation and a vector, and returns the
transformed vector. Sort of like vrotate(), but can also be used with
scale, translate, matrix, and complex combinations of these(and also
declared transforms).
