POV-Ray : Newsgroups : povray.binaries.images : Two spheres (59.7KB) Server Time
25 Mar 2026 04:00:39 EDT (-0400)
  Two spheres (59.7KB) (Message 11 to 18 of 18)
Subject: Re: Two spheres (59.7KB)
Date: 26 Apr 2000 21:32:14
Message: <3907980E.9D8EDA88@faricy.net>
Tor Olav Kristensen wrote:
> > A little softening of the shadows would help.
> I agree, but I'm not sure how to do that.
> I have tried to increase the ambient_light, but then I lost some
> contrast.
light_source { .... area_light <axis_1> <axis_2> size1 size2 [adaptive
[n]] [jitter [n]] }
The axes define the rectangular area the light_source occupies. The
"sizes" are actually resolutions, size1*size2 is the number of lights POV
must calculate for, more is better but slower.
jitter "jitters" the lights a bit for each pixel to eliminate banding, but
can sometimes give grainy results. A number after it is a multiplier used
on the default ammount of jittering.
adaptive makes POV use further subsampling based on contrast between
neighboring rays to further eliminate banding. Adaptive will not go beyond
<size1,size2> in resolution. Because adaptive can give innacurate results
by not filling in all areas, a number after it specifies the minimum
number of times the array is subsampled before adaptive sampling is used.
example: light_source { .... x*10 z*10 5 5 adaptive 1 }
this creates a 10x10 light along the x-z plane at whatever location, uses
a minimum of 9 rays per sample (3x3; the corners [adaptive 0] and then one
subdivision [adaptive 1]) and may use up to 25.
if you are still confused read the docs
David Fontaine     <dav### [at] faricynet>    ICQ 55354965
Please visit my website: http:/www.faricy.net/~davidf/
Date: 26 Apr 2000 21:37:42
Message: <39079898.EEAA6176@online.no>
Bob Hughes wrote:
> By "diffuse" lighting I'm sure that's meant to be 'area_light' put into the
> 'light_source' statement.  Gives it that fuzzy shadow look.
> The global ambient would indeed ruin this picture.  What I meant was
> the 'ambient' increase only in the red background object.  Of course,
> that would also mean lowering either the color values or 'diffuse' in order
> to keep the same color intensity for the part still in the light.
Thank you again.
I'll try your suggestions.
Tor Olav
mailto:tor### [at] hotmailcom
Date: 26 Apr 2000 21:43:01
Message: <39079A85.C88D4957@pacbell.net>
> I have tried to increase the ambient_light value but then I loose contrast
> in the picture and the hexagons and pentagons becomes difficult to see.
> Any suggestions?
Area lights can help soften shadows without adding too much extra brightness
to the scene.
Date: 26 Apr 2000 21:44:42
Message: <39079A3C.E884279A@online.no>
> [n]] [jitter [n]] }
Thank you for explaining!
Just a little bit confused, but I'll think that I will try out your and Bob
Hughes' suggestions with some (or many :) renderings.
Tor Olav
Date: 26 Apr 2000 21:51:42
Message: <39079BE1.32B9C94C@online.no>
> to the scene.
Thank you.
Bob Hughes and David Fontaine also suggested that I could use area lights.
So now I hope that it will not take 10 times longer to render the picture. :-)
(I think it took  4-5 hours to render the image.)
Tor Olav
Date: 26 Apr 2000 22:46:21
Message: <3907a9fd@news.povray.org>
"Tor Olav Kristensen" <tto### [at] onlineno> wrote in message
news:39079BE1.32B9C94C@online.no...
No, not ten times.  But it will seem like it.
Date: 27 Apr 2000 04:21:46
Message: <3907EBF3.50715450@sheayright.com>
> > to the scene.
> Thank you.
I wonder if placing red two disks where the shadows fall on the blossom(?)
and bringing up their ambient values could compensate for the dark shadows?
It'd be "cheating" but it might render faster than area lights.
Date: 27 Apr 2000 16:05:48
Message: <39089C58.23F3CF8C@online.no>
It's a bit difficult for me to do that because the surface that the shadows fall on
are not flat.
That surface is actually a mix of a lot of "CSG-ed" shapes (involving planes,
cylinders and spheres) placed by a macro I made.
But thank you for commenting.
Tor Olav
