POV-Ray : Newsgroups : povray.binaries.animations : Tronc Commun 3 Server Time
21 Dec 2024 10:49:00 EST (-0500)
  Tronc Commun 3 (Message 1 to 9 of 9)
Subject: Tronc Commun 3
Date: 24 Jul 2017 16:50:01
Message: <web.59765d3bee292253f591106d0@news.povray.org>
I want to share my latest puzzle animation with you. Tronc Commun 3 is the last
puzzle in a series of three designed by Gregory Benedetti. What these puzzles
have in common is their shape when assembled, as well as the two parts that
comprise the puzzle's trunk, hence the name.
This last puzzle in the series is by far the most difficult. The reason is that
it requires several rotational moves, including some very tricky ones. There are
several reasons why they are tricky. First, most lack a fixed rotation point.
They are joint translations and rotations, where the constraints that guide the
translation can even vary depending on the angle. Second, not all rotations are
multiples of ninety degrees. Third, the margins are narrow. Some rotations work
only because the pieces have slightly bevelled edges. See the top part of the
attached image. Finally, there's one rotation where to parts have to rotate
together, but each along a different axis. See the bottom part of the attached
image.
So, all in all, quite some trigonometric calculations were required to script
this. A fun challenge, and I am happy with the end result, which can be found
here: https://youtu.be/PSfEEZ-DSvQ
I hope you like it too!
Cheers,
Erwin
Download 'tronccommun-rotations.png' (600 KB)
Preview of image 'tronccommun-rotations.png'
Subject: Re: Tronc Commun 3
Date: 24 Jul 2017 17:12:08
Message: <597662a8$1@news.povray.org>
Mind-boggling! :)
Regards
Date: 24 Jul 2017 19:55:00
Message: <web.597687b0c356a9f19c5d6c810@news.povray.org>
Intriguing, and awesome. I've seen some of your others before. I like this kind
of thing in real life but unfortunately I'm more likely to break them or give up
so I avoid getting any other than as gifts.
No doubt this kind needing pivoting moves is especially interesting, so I'm
amazed anyone can model and animate such things.
I like the way they appear mesmerizing. Having seen many of your animations, and
I'm sure not all, have you thought about using speed changes for the piece
moves? Mainly the taking away or going together, to accelerate or decelerate
them.
I'm thinking of the clockmod.inc or macro from Chris Colefax, which I often rely
on for that. In fact, maybe adding motion blur via UberPOV or MegaPOV could be
possible. Only thing about that is the change might not be what you've intended
for the look of your animations so only a suggested idea... unless you've
already considered it before.
Anyway, thanks for making those puzzles move on their own so I don't have to do
that.. either in POV-Ray or RL!
Date: 25 Jul 2017 03:55:09
Message: <5976f95d$1@news.povray.org>
On 24-7-2017 22:48, Eriban wrote:
:-O
Date: 25 Jul 2017 05:10:01
Message: <web.59770a3cc356a9f1883fb31c0@news.povray.org>
That is just jaw-droppingly amazing. I don't know what else to say! HOW you can
initially figure out the way it works, and THEN animate it is... beyond the
scope of mortal men. (Me, anyway!)
Just saw another of your puzzle animations here...
https://www.youtube.com/watch?v=CR52unlUZAg
That one looks even more complicated (if that's possible!) You mention there
that it's "an ingenious 18-piece burr puzzle of level 62.4.21..."  Those must be
STAR TREK coordinates for playing 3-dimensional chess :-O
Excellent work!
Date: 25 Jul 2017 05:30:00
Message: <web.59770ebbc356a9f19c5d6c810@news.povray.org>
Analytical mind to do that sort of thing is what I was thinking before, now I'm
sure that would only be the how-to process. There's the end result achievement
too, more than just analysis.
Assembly of a Droid is another, I thought looked simple until it gets going:
https://www.youtube.com/watch?v=kWX24K5p6w8
Date: 25 Jul 2017 05:36:09
Message: <59771109$1@news.povray.org>
After a while you lose the ability to praise them.
You are not alone.
The choice of music adds to the pace.
Regards
Date: 25 Jul 2017 15:40:01
Message: <web.59779d88c356a9f1f591106d0@news.povray.org>
Firstly, thanks all for the kind praise!
> them.
I have used part acceleration and deceleration before. In fact, it's even
enabled in this animation, although very subtle and hardly noticeable, and a few
move changes especially are still too abrupt. If I would have spent more time on
this animation, that would be the first thing to improve. But there's always a
balance between striving for perfection, or considering it good enough and
moving on to a next project. Maybe I should have spent a bit more time on it...
Condor's Peeper indeed requires more moves (62 to release the first piece, four
for the next, and 21 for the third... there's that mystery spoilt). Especially
when trying to assemble the puzzle unaided it's a much more difficult puzzle. On
the other hand, a computer can easily solve Condor's Peeper, but will be stuck
trying to solve Tronc Commun 3 because of the (complex) rotational moves that
are required.
Btw, Condor's Peeper is still relatively easy. Its cousin Super Nova
(https://youtu.be/l_Rt7A7E_6Q) is currently the 18-piece burr puzzle that holds
the world record with 166 moves to free the first part.
Date: 16 Jan 2018 21:50:00
Message: <web.5a5eb988c356a9f15cafe28e0@news.povray.org>
I just saw this recently, and immediately thought of you  :)
"This lock requires 250 steps to open it! - Schloss 250"
https://www.youtube.com/watch?v=GF1LALdhkn0
Seems like it's right up your alley - enjoy!
