POV-Ray : Newsgroups : povray.binaries.animations : Chimney felling with the BulletPhysics Playground Server Time
19 May 2024 02:20:07 EDT (-0400)
  Chimney felling with the BulletPhysics Playground (Message 1 to 10 of 16)
Subject: Chimney felling with the BulletPhysics Playground
Date: 10 Jun 2013 19:15:05
Message: <web.51b65ca77a0440a944b5561b0@news.povray.org>
My first proper animation from tinkering with BPP, adapted from the demo tower
script. Textured using the pre/post_sdl properties, and the master pov scene
just needed an override camera and some simple embellishment.
210 frames, simulation in about 5 minutes, rendering in about 15 minutes.
The ball is 50x heavier than a brick :)
Bill
Download 'tower1.mp4.mpg' (3716 KB)
Subject: Re: Chimney felling with the BulletPhysics Playground
Date: 11 Jun 2013 03:35:37
Message: <51b6d349$1@news.povray.org>
Impressive.
What I wonder at is what happens to the left side of the bricks stack?
When the ball hits, it should crumble fractionally earlier than the
right side, maybe bringing the stack down towards the left. Also, you do
not see the bricks having been displaced there while the stack crumbles.
Perhaps a trick of the eyes however. Would be worthwhile to see this in
slow motion (and with semi-transparent bricks).
Date: 11 Jun 2013 04:12:57
Message: <51b6dc09$1@news.povray.org>
On 11/06/2013 8:35 AM, Thomas de Groot wrote:
> Impressive.
Save the file, open it in Windows Media Player. Then Right click >
Enhancements > Play speed settings.
You will see what happen better in slow motion.
Nice one Bill. You have a history of destroying things. IIRC. ;-)
Regards
Date: 11 Jun 2013 05:56:55
Message: <51b6f467@news.povray.org>
> Bill
Looks cool. I recall doing this with building blocks & dominoes when I
was a kid. Great fun.
Does BPP write 210 sets of positions/transforms which are then rendered
by frame in povray? Or, is BPP set up to simulate/render per frame?
Suppose I am wondering if one can one peak ahead by rendering select
frames after a total simulation completes. Also, whether it is possible
to look at a what happens to a few items of the whole simulation in
isolation by rendering just those items.
Lastly, we are now of course in anticipation of a movie staring the
"Archimedean Solids".
Bill P.
Date: 11 Jun 2013 06:35:01
Message: <web.51b6fd352f4fb5c5b7d07940@news.povray.org>
It looks reasonable to my eyes. More bricks are knocked out on the right side,
so it falls slightly that way and into the gap left by the ball.
I want to try some slow motion and camera movement next, so I might be able to
oblige. Not sure about transparency though, it might end up looking too busy to
see what's going on. I could use some radiosity to illuminate the shadowed
areas, that might make it a little clearer.
Bill
Date: 11 Jun 2013 06:40:01
Message: <web.51b6fdae2f4fb5c5b7d07940@news.povray.org>
You have a good memory. Perhaps I should try revisiting the knots in BPP!
Bill
Date: 11 Jun 2013 06:50:01
Message: <web.51b7008a2f4fb5c5b7d07940@news.povray.org>
It writes a set of .inc files containing the geometry transformed using matrix {
}. You can optionally specify POV-Ray SDL in the lua code to surround the matrix
transform. Also exported is a .pov file which does an #include based on the
clock variable, and an .ini file to set up the animation loop.
You can, by simply #including the frame you want to see and turning off the
animation. This is how I set up the camera and environment in the master .pov
file before rendering the whole animation.
I'm not sure. Perhaps if you used the in-line SDL feature to #declare all the
geometry items into an array, then the #include would insert nothing into the
scene and you could pick out any subset of items you wanted. I should try this,
it sounds like it might be quite powerful.
Haha, good idea!
> Bill P.
The other Bill P
Date: 11 Jun 2013 07:33:38
Message: <51b70b12@news.povray.org>
Aaah... I see that the ball makes a glancing strike instead of a head on
one.
I am satisfied now ;-)
Date: 11 Jun 2013 07:35:42
Message: <51b70b8e$1@news.povray.org>
> Yeah... I am getting even more puzzled... my eyes tell me there is much
> less destruction on the left...
I don't see the problem, it looks natural to me.
Maybe a view from the top or at right angles to the path of the ball?
Regards
Date: 11 Jun 2013 07:38:20
Message: <51b70c2c$1@news.povray.org>
It was pretty spectacular. Easy to remember. :-)
Go on, go on, go on. As Mrs Doyle from Fr. Ted would say.
Regards
