POV-Ray : Newsgroups : povray.binaries.animations : 'twas a dark and stormy night... (WIP) Server Time
9 Jun 2026 07:07:23 EDT (-0400)
  'twas a dark and stormy night... (WIP) (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: 'twas a dark and stormy night... (WIP)
Date: 20 Jun 2007 14:25:01
Message: <web.467970be6a461fd8d6a97ce40@news.povray.org>
"Simon" <povray@*NOSPAM*SOWare.co.uk> wrote:
> As always, please give me feedback and opinions - The more you suggest, the
> better I can do next time
It looks good. It reminds me a lot of 80's adventure games, like Morteveille
Manor, and several Lucasarts games. Actually it reminds me of a specific
game the name of which escapes me. The lightning effect is very suggestive,
but I would give it a blue/white hue; there is much too much green IMO at
the moment when lightning strikes.
Date: 20 Jun 2007 14:41:11
Message: <467974c7$1@news.povray.org>
True. The lightning is mostly white so the green grass gives that effect - I
need to change that
The one it made me think of was Maniac Mansion by Sierra - Good ol' ScummVM
Ideally, I'd like to make the curtains blow but I'm a little unsure how I
can pull that off - it's obv not a matter of rotation, I need them to
"billow" - I'll see what I can come up with :)
Thanks for the input!
-S
"Grassblade" <nomail@nomail> wrote in message
news:web.467970be6a461fd8d6a97ce40@news.povray.org...
>> the
> Morteveille
> suggestive,
Date: 20 Jun 2007 17:33:58
Message: <46799d46$1@news.povray.org>
Simon wrote:
> Ironically, I was searching the 'net for rain/thunder sounds while I had a
> thunder storm going on outside but no decent quality microphone to record
> it.
I don't hear any sound in the video, so I'll assume that you didn't have
any luck.
You might try the Freesound project:
http://freesound.iua.upf.edu/index.php
All Creative Commons licensed sounds. It's a mixed bag, but sometimes
you'll find exactly what you need. :-)
William Tracy
|a|f|i|s|h|i|o|n|a|d|o|@|g|m|a|i|l|.|c|o|m|
|w|t|r|a|c|y|@|c|a|l|p|o|l|y|.|e|d|u|
You know you've been raytracing too long when you think it's a failing
of the universe that the large software companies like Corel or Fractal
Design do NOT export to POV primitives.
George Erhard
Date: 21 Jun 2007 12:51:38
Message: <467aac9a$1@news.povray.org>
Thanks very much for that - I'll see what I canf ind. Unfortunately my Mic
is supposed to be noise cancelling and actualyl does it pretty well (I
believe it ahs 2 mic's and inverts the output from one before mixnig them -
thus embient should be cancelled out but directional should not)
The upshot fo all that is: VERY VERY QUIET rain... For the record, I also
decide that since a thunder roll was a few seconds long and the video is
abuot 12 secs, it might eb a bit too much. Ofc, sound would help the
realism...
That said, I've already found some useful stuff on that link - thank you.
"William Tracy" <wtr### [at] calpolyedu> wrote in message
news:46799d46$1@news.povray.org...
>> a thunder storm going on outside but no decent quality microphone to
>> record it.
> any luck.
> William Tracy
> You know you've been raytracing too long when you think it's a failing of
> George Erhard
Date: 21 Jun 2007 19:48:12
Message: <467b0e3c$1@news.povray.org>
Simon nous apporta ses lumieres en ce 2007/06/21 12:50:
> realism...
When you try to record ambient sounds with a soise canselling mic, you can try
wraping your hands around it, leaving only the front showing. That way, your
hands will muffle the sound coming from the sides and the rear. If it work OK,
you can make a foam envelope or a casing with a directional opening.
All tyranny needs to gain a foothold is for people of good conscience to
remain silent.
Thomas Jefferson
Date: 22 Jun 2007 07:09:21
Message: <467bade1@news.povray.org>
467b0e3c$1@news.povray.org...
> try wraping your hands around it, leaving only the front showing. That
> way, your hands will muffle the sound coming from the sides and the rear.
> If it work OK, you can make a foam envelope or a casing with a directional
> opening.
Not really sure it works : a noise cancelling mike is usually a pair of
adjacent inverted phase cells, it takes close sources ( i.e. closer to the
'main' cell, so there is a difference) and cancels remote sources because
the sound tends to be equal on both cells.
I'm not sure either if you can muffle a thunder with your mere hands :-).
A simple solution is to purchase a simple microphone, there are a lot of
not expensive yet rather good electrets models.
I may have some thunders recorded somewhere. I'll have a look at my backups.
Marc
Date: 22 Jun 2007 13:30:43
Message: <467c0743$1@news.povray.org>
Thanks, I'd appreciate that!
"Marc" <jac### [at] wanadoofr> wrote in message
news:467bade1@news.povray.org...
>> can try wraping your hands around it, leaving only the front showing.
>> That way, your hands will muffle the sound coming from the sides and the
>> rear. If it work OK, you can make a foam envelope or a casing with a
> backups.
> Marc
Date: 22 Jun 2007 13:56:09
Message: <467c0d39$1@news.povray.org>
467c0743$1@news.povray.org...
 Unfortunately, I did not find them but I found some samples by google.
I fiddled a 12s loop that fits roughly with your avi file.
If I could decipher your mail adress I could send it to you :-)
Marc
Date: 22 Jun 2007 14:55:02
Message: <web.467c19e36a461fd8275d2c5d0@news.povray.org>
Oh yes, that was the one! I knew it was a building starting with a M but
Mortevielle Manor kept coming back at me.
Not a trivial thing to do AFAIK. Megapov comes with a pretty good cloth
simulation, but I'm not sure how you'd go about making billowing curtains.
>-S
You're most welcome.
Date: 22 Jun 2007 20:01:11
Message: <467c62c7@news.povray.org>
lol just remove the *NOSPAM*
I own the domain soware.co.uk so have set up an address for POVRay@
Thanks very much!
news:467c0d39$1@news.povray.org...
> Marc
