POV-Ray : Newsgroups : povray.binaries.animations : grass blowing in the wind Server Time
28 Mar 2026 19:40:29 EDT (-0400)
  grass blowing in the wind (Message 1 to 10 of 13)
Subject: grass blowing in the wind
Date: 15 Oct 2006 05:03:35
Message: <4531f967@news.povray.org>
Derived from the SCC WIP I posted in p.b.i a while ago, though obviously
this version uses a lot more than 256 bytes of code.
The animation is just a vturbulence function applied to the tops of the
grass blades (cones), with the turbulence moved over time.
Tek
http://evilsuperbrain.com
Download 'grassy.m1v.mpg' (658 KB)
Subject: Re: grass blowing in the wind
Date: 15 Oct 2006 05:08:41
Message: <4531fa99$1@news.povray.org>
Less compressed version here (about 1.6MB):
http://evilsuperbrain.com/gallery/wip/index.php?movie=grassy_hq
Tek
news:4531f967@news.povray.org...
> Tek
Date: 15 Oct 2006 11:49:59
Message: <453258a7@news.povray.org>
   Nice one! Although, that is a very *strong* wind.
    ~Steve~
> Tek
Date: 17 Oct 2006 10:40:01
Message: <web.4534eae6ab8d2f9647d3ae5e0@news.povray.org>
That's awesome!
Was the rendering time ok?
(Considering you said something about using cones.)
Should be neat flying past an animated field blowing in the wind like that.
Date: 17 Oct 2006 11:56:22
Message: <4534fd26$1@news.povray.org>
Rendering time wasn't great 'cause I need high anti-alias settings and the
scene takes a few seconds to parse, so it took about 7 hours for 200 frames.
Not ideal but certainly useable.
The problem with flying past is that the area is relatively small, what
looks like the crest of a hill is actually the limits of the grassy area
I've created, so when I rigged up a version that would move that area with
the camera (so we never get closer to the far edge as we fly through the
field) you can really badly see ground popping in at that distance. To hide
this effect I'd need many times more grass, which would make it render many
times slower... sigh...
Tek
"RusHHouR" <gee### [at] mailnu> wrote in message
news:web.4534eae6ab8d2f9647d3ae5e0@news.povray.org...
> That's awesome!
> that.
Date: 18 Oct 2006 14:55:01
Message: <web.453677b1ab8d2f9647d3ae5e0@news.povray.org>
> Tek
Ah, I see.. :/
How many grass cones/units are there then in this version?
Date: 18 Oct 2006 16:13:48
Message: <45368afc@news.povray.org>
news:web.453677b1ab8d2f9647d3ae5e0@news.povray.org...
it's a 128x128 grid, so 16,384.
Tek
Date: 18 Oct 2006 20:53:01
Message: <4536cc6d$1@news.povray.org>
Tek nous apporta ses lumieres en ce 17/10/2006 11:56:
Maybe you can hide that with some fog. Another avenue would be to make the
ground much larger and use some faked grass outside the area actualy covered by
your grass.
Impressionism: From a distance, shit looks like a garden.
Date: 19 Oct 2006 07:06:56
Message: <45375c50@news.povray.org>
I think fake grass would be the best option, otherwise I'd need fog so dense
you could only see a distance of 128 blades of grass, which in real world
terms would be maybe a couple of meters, now that's foggy! :)
Tek
"Alain" <ele### [at] netscapenet> wrote in message
news:4536cc6d$1@news.povray.org...
>> the scene takes a few seconds to parse, so it took about 7 hours for 200
>> frames. Not ideal but certainly useable.
>> with the camera (so we never get closer to the far edge as we fly through
>> the field) you can really badly see ground popping in at that distance.
>> To hide this effect I'd need many times more grass, which would make it
>> render many times slower... sigh...
> covered by your grass.
> Alain
Date: 19 Oct 2006 17:58:00
Message: <4537f4e8@news.povray.org>
What about spreading the grass out just a little with fake grass in between?
Or thin it out towards the edges, fading to dirt/gravel/whatever was you
leave the grassy area? Like a small grassy areas forgotten & idle in the
middle of suburbia? Or those creek areas we all used to play in as kids ;)
news:45375c50@news.povray.org...
>dense you could only see a distance of 128 blades of grass, which in real
>world terms would be maybe a couple of meters, now that's foggy! :)
> Tek
>>> through the field) you can really badly see ground popping in at that
>>> distance. To hide this effect I'd need many times more grass, which
>>> would make it render many times slower... sigh...
>> the ground much larger and use some faked grass outside the area actualy
>> Alain
