POV-Ray : Newsgroups : povray.binaries.animations : Roller Coaster WIP 6 (MPEG1 Link: 4.7 MB) Server Time
9 Jun 2026 08:23:24 EDT (-0400)
  Roller Coaster WIP 6 (MPEG1 Link: 4.7 MB) (Message 11 to 16 of 16)
Subject: Re: Roller Coaster WIP 6 (MPEG1 Link: 4.7 MB)
Date: 2 May 2006 19:02:38
Message: <4457e50e$1@news.povray.org>
Tim Nikias wrote:
> I've once written a small script to create a mesh-tube running along a
> spline, and ran into similiar problems. What was suggested to me then by
> Rune and someone else who's name I've forgotten (sorry) to update the
> up-vector successively, instead of independantly for each frame (in my case,
> for every ring of the tube, in your case, it's the frames).
> I start with the initial direction I'm heading to, and an initial up vector.
> On the next frame, use the old up-vector, and double vcross it with the new
> direction to get the new up-vector.
>   #local Up = vnormalize(vcross(vcross(New_Direction,Last_Up),
> New_Direction));
> Since the new direction and the old up-vector aren't perpendicular, you'll
> create a new up-vector that is aligned along the plane defined by the old
> up-vector and new-direction... Quite simple, once you think it through.
> Additionally, since this only affects corkscrew or other loopings, you could
> create a parsing step that'll just do that when it's needed. Needs a little
> more though, but would be worthwhile in case you plan on distributing the
> render and making the animation independant of former frames.
> Regards,
> Tim
Hmm...If I understand you correctly, then what I'd be doing is starting
with an up vector of simply y, double cross it with the new direction
with each frame, and pass it to the next frame (Just like I pass the
current location and speed with each frame).  On every frame, I'll do
all my banking calculations based on that vector, rather than using y
every time.
Correct?
-DJ
Date: 3 May 2006 02:20:14
Message: <44584b9e@news.povray.org>
Ok no problem.  If things get a little more drawn out with your intended
landscape and 3DS objects my offer still stands.  That is if you can
split the animation down into sections?
Keep the animations coming
Dave
DJ Wiza wrote:
> David Brickell wrote:
>> If you require any rendering done I have a lot of CPU time I could
>> spare.  Also I get to see how you are working things ;)
>> Let me know.
>> Dave.
> Test renders are quick.  Because I'm using spheres/cylinders rather than
> sphere_sweeps, it only takes about 6 seconds per frame, and most of my
> test renders are just single frames to make sure something is being
> calculated correctly.
> -DJ
Date: 3 May 2006 03:42:01
Message: <44585ec9@news.povray.org>
> every time.
> Correct?
Yup.
Tim
aka "Tim Nikias"
Date: 3 May 2006 12:25:13
Message: <4458d969$1@news.povray.org>
> Dave
You can and you can't split the animation.
At every frame, it tries to read two variables from a text file.  These
two variables tell my script the current location and speed.  If it
can't find this file, it starts from the beginning.
So by creating this file yourself, you can make it start somewhere in
the middle.
-DJ
Date: 3 May 2006 13:31:21
Message: <4458e8e9$1@news.povray.org>
> the middle.
> -DJ
So you have to run the simulation up to the point in the track you wish
to render from so it has the correct location and speed.  That makes sense.
Patiently waiting for next render ;)
Dave.
Date: 3 May 2006 18:26:22
Message: <44592e0e$1@news.povray.org>
>> These two variables tell my script the current location and speed.  If
>> it can't find this file, it starts from the beginning.
>> the middle.
>> -DJ
> Dave.
Its going to be awhile.  I've gotten the banking to be smoother by using
a spline for up vectors, which fixed the kink in the track, but I
haven't implemented the double-crossing of the up vectors to make
vertical track work right, so really its just luck that the track
appears and banks correctly.  A track tie still appears wrong, showing
that it still isn't right, it just looks right in most cases.
I've also fixed the spine rail.  It no longer goes up and down, causing
track ties to appear in the bottom of the spine.  This was being caused
by rotating the vector y over the vector of the direction of travel, so
track that had a slope caused the spine to be closer to the bezier
defining the track.
In any case, I don't really think its enough change to warrant a new
upload.  I thought of making a 60 fps 10-sample motion blur render, but
that would take almost 4 days, and I'd rather have the CPU time devoted
to test renders of the support track, which I haven't even begun working on.
-DJ
