POV-Ray : Newsgroups : povray.binaries.animations : Muscles (702KB MPEG-1) Server Time
9 Jun 2026 09:54:23 EDT (-0400)
  Muscles (702KB MPEG-1) (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Muscles (702KB MPEG-1)
Date: 3 Jan 2006 18:36:22
Message: <43bb0a76$1@news.povray.org>
Freaky stuff, Zeger. I'm sure that couldn't be an easy thing to animate.
Reminds me the people Greg Johnson has created over the past few years but I
don't remember how he actually makes those guys.
You didn't mention any use of negative strength component parts so you might
want to give that a try if you haven't already done that. In my somewhat
limited experience with the POV blob I know it can get real tricky placing
blob components with good strength and threshold since, like you said, when
using a single blob for such things as this arm animation, it ultimately
tangles in on itself unless something is done to force spacing where needed.
Even moreso, with negative strength parts I think it would get extremely
complicated to fit the parts together for animation. Just a still image
could be more plausible, but animate that and it means many positions to
account for. However, if you do manage to work it out please post another
animation!
Date: 3 Jan 2006 18:55:20
Message: <43bb0ee8$1@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> wrote in message
news:43b9b0a7@news.povray.org...
> "Chris B" <c_b### [at] btconnectcomnospam> wrote in message
> news:43b9a06f@news.povray.org...
> I'm interested in the source, but if it's too much work, then it's ok :)
I've been meaning to publish it for a while, I just got sidetracked adding a
Santa model that I failed to complete by Christmas anyway.
Also the documentation isn't complete yet.
I've put a copy on the povray.binaries.scene-files newsgroup as 'POV-Person
V2 Alpha'.
> I'm trying to make my blobman fully customizable: you can choose the
> size of the head, the proportions of the body, and I would even like to
> make it
> so that you can make other creatures with it, don't know if that'll work
> though
My thinking is much the same. I've layered the macros so that the core
functions will work with any anatomical construct (although a human form is
the only one I've included so far).
I've kept the major body parts separate and extensively parameter
controlled, so that they can be shared between different characters (I also
have a separate 'scale' include file to for each character to enable each
body part to be scaled appropriately. For example, for the moment I've used
the same body parts for the male and female characters, but for the chest
I've used different parameters to control the anatomical construction and
for legs and arms I've just scaled the parts (all fairly crude still).
> Don't know why, I just don't like GUI's with a big G I'm afraid :(
I know the feeling. I used a modeller for the first few heads, but I'm
gradually replacing that with SDL so that it can be modified dynamically.
On the more recent models I've got mesh eyelids that open and close and lips
that are dynamically generated.
David's suggestion could be good. I think he's suggesting using an
isosurface where you can use functions to define shapes and use the methods
described in Mike Williams' isosurface tutorial to 'blob' them together.
I've used that for the top of the head of my Santa model (see pps2face.inc
in the xip file). It gets quite mathematical quite quickly though and he's
right when he says that isosurfaces increase the render time. On my to-do
list is to scan the isosurface I get for the head shape and build a mesh to
render, for two reasons. Firstly it'll render quicker. Second, the straight
edges of the meshes I plan to use for the eyelids and mouth will join more
easily with a mesh than with the totally smooth isosurface.
Chris B.
Date: 4 Jan 2006 03:32:11
Message: <43bb880b$1@news.povray.org>
"Bob Hughes" <omniverse@charter%net> wrote in message
news:43bb0a76$1@news.povray.org...
animate.
It was as easy to animate it as it was to make it, actually :)
You see, I made a muscle() macro that connects 2 points with a blob that
tries to keep the same, given volume.  Not entirely accurate, but it
more or less does the job :)
but I
with a lot of work, I suppose :)
might
Hmm, I might be able to force something with negative strength, don't
know if I can automate it though :-/
> In my somewhat
placing
when
ultimately
needed.
extremely
to
another
> animation!
Maybe if I put negative strength blobcomponents on one side of the
muscles, that prevent any other part of the body to "blob" onto that
muscle...  just thinking out loud here, I don't know if that even makes
sense :)
cu!
Date: 4 Jan 2006 06:59:21
Message: <43bbb899@news.povray.org>
Zeger Knaepen wrote:
> I'm not really sure I understand it completely :-/
> cu!
I thought about something like this (never tried, so maybe doesn't work
at all):
1. declare your blobs defining the single muscles
#declare blob_object_1 = blob{....}
#declare blob_object_2 = blob{....}
#declare blob_object_n = blob{....}
2. declare functions based on object-patterns using the formerly
declared blobs like this:
#declare bf_1 = function{pigment{object{blob_object_1 color rgb 0, color
rgb 1}}};
#declare bf_2 = function{pigment{object{blob_object_2 color rgb 0, color
rgb 1}}};
#declare bf_n = function{pigment{object{blob_object_n color rgb 0, color
rgb 1}}};
3. now skin them using somthing to "blob" functions together like in the
docs:
#declare blob_threshold = 0.001;
#declare skin = function {
(1+Blob_threshold)
  -pow(Blob_threshold, bf_1(x,y,z).gray)
and use this function inside an isosurface-container large enough
... dave
Date: 4 Jan 2006 13:01:28
Message: <43bc0d78$1@news.povray.org>
"David El Tom" <dav### [at] t-onlinede> wrote in message
news:43bbb899@news.povray.org...
> > cu!
work
> at all):
this step is a problem: object-patterns are binary, either a point is
inside the object or it's on the outside, which makes them not suitable
for isosurfaces :-/
cu!
Date: 4 Jan 2006 13:28:11
Message: <43bc13bb$1@news.povray.org>
> this step is a problem: object-patterns are binary, either a point is inside the
object or it's on the outside, which makes them not suitable for isosurfaces :-/
> cu!
ah, ok I'see the point
  ... have to think about if it's possible to transform a blob which
elements have a spherical pattern into a single pigment.
This, I think, could solve the binary problem. Have to go into docs
again ...
... dave ...
Date: 4 Jan 2006 15:44:28
Message: <43bc33ac$1@news.povray.org>
news:43bc13bb$1@news.povray.org...
is inside the object or it's on the outside, which makes them not
> > cu!
> again ...
MegaPOV used to have a blob-pattern, but for some reason the latest
version doesn't have it anymore :(
cu!
Date: 4 Jan 2006 21:31:24
Message: <43bc84fc$1@news.povray.org>
> Second problem: I can't do it with 1 blob,  because limbs
> would blob together if they get too close to each other.
 > But if I do it in different blob-objects, the seams are
 > visible :-/ Anyone has an idea how to solve this? :-/
To model muscles, you are probably going to have to model bags of goo
that push against each other, and completely abandon blobs altogether.
John
Date: 5 Jan 2006 04:09:22
Message: <43bce242@news.povray.org>
> MegaPOV used to have a blob-pattern, but for some reason the latest version doesn't
have it anymore :(
> cu!
at least I found a way to fake a blob pattern via usage of functions:
<<<<SNIPPET-START>>>>
//"prove of principle" - blob pattern-function
// number of blob components
#declare blob_component_count = 3;
// arrays holding strength, radius and position for each component
#declare blob_strength = array[blob_component_count];
#declare blob_radii = array[blob_component_count];
#declare blob_positions = array[blob_component_count];
// fill these arrays with something
#declare blob_strength[0]=1.0;
#declare blob_strength[1]=1.2;
#declare blob_strength[2]=-.5;
#declare blob_radii[0]   =1.3;
#declare blob_radii[1]   =1.3;
#declare blob_radii[2]   =1.0;
#declare blob_positions[0] = <-.8,0,0>;
#declare blob_positions[1] = <.8,0,0>;
#declare blob_positions[2] = <.0,.3,0>;
#declare counter = 0;
#declare blob_fcn =
function
#while (counter < blob_component_count)
   #local x_pos = blob_positions[counter].x;
   #local y_pos = blob_positions[counter].y;
   #local z_pos = blob_positions[counter].z;
   #local radius_squared = pow(blob_radii[counter],2);
   #if (counter > 0)
   #end //if
   (blob_strength[counter] *
pow((1.0-min(1,((pow((x-x_pos),2)+pow((y-y_pos),2)+pow((z-z_pos),2))/radius_squared))),2))
   #declare counter= counter +1;
#end // while
plane
   z,0
   pigment
     function{min(1,max(0,blob_fcn(x,y,z)))}
     color_map
       [0 rgb 0]
       [0.2 rgb <1,0,0>]
       [0.4 rgb <0,1,0>]
       [0.6 rgb <0,0,1>]
       [0.8 rgb <0,1,1>]
       [1 rgb 1]
     ramp_wave
<<<<SNIPPET-END>>>>
... dave
Download 'blob_fcn.png' (26 KB)
Preview of image 'blob_fcn.png'
Date: 10 Jan 2006 14:25:01
Message: <web.43c409a8ba1490cb40d56c170@news.povray.org>
First of all, I have a complicated transform that takes anything associated
with a particular limb from Position(time_zero construction) to
Position(function of various movement parameters, including of course IK,
etc.).
Then as far as construction goes, consider the character shown at:
http://news.povray.org/povray.binaries.animations/thread/%3C437563c5%40news.povray.org%3E/
Except for two eyeball-spheres, twenty individual blob-teeth and a
blob-tongue, and a blob-hairdo,   the entire figure is one blob.  The hands
have blob components of strength like 200 or something-- ugly looking
cylinders.
Then for construction of the arm, take for example say the bicep-bone.
First of all, I have cylinders that do not go all the way to the joints,
and then spheres at the joints.  This prevents the spiking which would
otherwise occur. I believe it also reduces the merging together of
bicep-muscle with fore-arm bone.
Then I represent a muscle with one or more elongated spheres.  Any
muscle-bulging that then occurs with arm-bending is an unintended benefit.
 Also consider super-low and super-high strength components in your
experimentation.
I've also not shied away from obtaining a pliable shape via an overkill
number of blob components.  Most of my faces are made with a stack of
fourty to seventy flattened spheres. If I then rotate only the bottom 1/3
of them, I've thereby created a moving jaw.
But John v.S. ultimately had the answer.  Stay away from blobs.  (I'd say
even stay away from povray.)  As a winner of an IRTC anim contest once
said, using povray for character animation must be a complete waste of
time.
Greg
http://pterandon.blogspot.com/
