POV-Ray : Newsgroups : povray.binaries.animations : Non-linear movement Server Time
13 May 2026 22:39:12 EDT (-0400)
  Non-linear movement (Message 1 to 5 of 5)
Subject: Non-linear movement
Date: 11 Nov 2005 22:38:47
Message: <437563c5@news.povray.org>
Did some tweaking with a way to get non-linear movement.  I'd had one
before, but when I actually plotted the curve, it was embarassing how
little deviation from linearity there was.
Now I've got it set up, perhaps too strongly, with a cos()^n, n<1 function.
A buggy version of this code is release in my recent p.g. posting.
So the point is to see to what extent the movement in the raising of the
hand is like that of a real human, not that it's thematically releveant
that a guy would be doing that.
Download 'file04.mpg' (146 KB)
Subject: Re: Non-linear movement
Date: 12 Nov 2005 08:41:22
Message: <4375f102@news.povray.org>
"Greg M. Johnson" <p t e r a n d o n @
thecommononethatstartswithY.com> wrote in message
news:437563c5@news.povray.org
> one before, but when I actually plotted the curve, it was
> embarassing how little deviation from linearity there was.
> function. A buggy version of this code is release in my recent p.g.
> posting.
> of the hand is like that of a real human,
Doesn't look quite right to me.  Have you tried something like
cos(x)*e^(-kx) which would represent a standard mass/spring/damper system?
To a first approximation, that's how our muscles work.
Date: 12 Nov 2005 11:23:04
Message: <437616e8$1@news.povray.org>
I have this macro that I use in every animation:
#macro Transition(Start,End,Swerve,Phase)
   #local tP=min(1,max(0,Phase))*pi;
   #local aL=(1-cos(tP))/2;
   #local aS=(1-cos(tP*2))/2;
   ( (Start)+(End-Start)*aL + (Swerve)*aS )
This is quite good for most applications.  Start and End are
self-explanatory.  Swerve allows movement to the side at the mid-point
of the motion.  Phase controls the timine of the motion, so for
animations you should put a clock-based value in here.
Hope this helps,
John
Date: 15 Nov 2005 20:57:28
Message: <437a9206@news.povray.org>
I cannot post an empty message.
Download 'file063.mpg' (202 KB)
Date: 15 Nov 2005 21:10:44
Message: <575ln1pfc0sdv9roj89javd9ip523tqkiq@4ax.com>
His movements look kind of like a white rapper.  Maybe you could add
some music and agressive lyrics?  ;-)
Kyle
