Inspired by Rune's first glitter image, I decided to try a simple image with
water particles. Although he beat me to it, here is mine thrown into a
simple scene.
I wasn't brave enough to attempt to keep the water particles in the
fountain. The water actually goes right into the ground. :)
I tried using Divx;-) and I was surprised that it shrunk the animation down
to 56k and looked as good as this one! I posted the mpeg though so that
everyone can see it.
Download 'fountain.m1v.mpg' (251 KB)
> simple image with water particles. Although he beat me to
> it, here is mine thrown into a simple scene.
Nice!
It looks good in the scene context. Something I haven't had time to do
myself yet...
> in the fountain. The water actually goes right into the
> ground. :)
You can always use CSG to "clip" the water. Maybe that's what you did.
What is the water particles made of? I can't quite see it. Isosurfaces?
Does the simulation change if you change the frame-rate of the animation?
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 28)
/ Also visit http://www.povrayusers.org
> Nice!
Thanks!
No, I just left them inside the other objects. Although I should clip them
to speed things up.
Blobs. I find it does a pretty good job. The more particles there are, the
smoother water-like it gets. I think there are 700 particles in this
animation.
I'm not sure what you mean by this, but if I change the number of frames,
then it does get smoother and slower. Basically, every frame I rotate the
particles by 360*clock around the center. So the more frames, the more
often the particles get drawn.
> > Isosurfaces?
> there are, the smoother water-like it gets. I think there are
> 700 particles in this animation.
I use blobs too. The reason I was confused by your animation is that the
blobs seems to be cluttered together in groups. I wondered if those groups
were small iso-surfaces, but I understand they are groups of blob elements.
> > the animation?
> of frames, then it does get smoother and slower.
That's not what I meant, but never mind, my question was only relevant if
you #write data to files and read them in the next frame. (Some of those
kind of particle systems create more particles if you have more frames.) But
I guess your animation is based on the clock keyword alone, in which case my
question was irrelevant.
Rune
elements.
I see. They are a little cluttered together, but as I mention, the more
frames, the less they clutter.
But
my
Actually, I do read/write from files, but I do not create new particles,
it's just that some of them aren't visible. Once a particle exceeds a
certain time value, it gets reset and repeats. This allowed me to do cyclic
animation.
Aha, then the question is relevant after all.
> mention, the more frames, the less they clutter.
That's exactly what I was talking about when I asked if it looked
differently dependent on the frame-rate. :)
Rune
