POV-Ray : Newsgroups : povray.binaries.animations : Clownfish Server Time
15 May 2026 12:34:50 EDT (-0400)
  Clownfish (Message 1 to 9 of 9)
Subject: Clownfish
Date: 2 Aug 2000 17:29:17
Message: <3988918A.9A12CEFC@aol.com>
Watch him wiggle. :)
I want to render this with photons eventually.
-Mike
Download 'clown2.mpg' (305 KB)
Subject: Re: Clownfish
Date: 2 Aug 2000 19:29:15
Message: <3988B05E.4BE3121F@pilot.msu.edu>
Amphiprion ocellaris.  Its a little thick but pretty good.  What did you
do him in.  I want to model my tank but I do not know what to do the
fish in.
> -Mike
>    clown2.mpg    Type: MPLAYER2 File (video/mpeg)
>              Encoding: base64
Date: 2 Aug 2000 19:39:34
Message: <3988B13E.A5CF1B74@aol.com>
Yup.  Could be amphiprion percula too, but I didn't get into enough detail to
make the distinction.  He is just a bit fat in the head.
> What did you
> fish in.
I did it in Animation Master.  The same thing could be accomplished in sPatch,
which has similiar modeling tools.
-Mike
Date: 2 Aug 2000 23:24:54
Message: <3988e606@news.povray.org>
"Mike" <Ama### [at] aolcom> wrote in message
news:3988918A.9A12CEFC@aol.com...
That's a great fish.  No scientific names from me, no fish knowledge either.
Not sure what photons could do, unless you meant for a surrounding water.
The lack of relative movement through water is the only thing I can say is
wrong about this animation.  Poor guy (gal?) looks pinned down like on a
butterfly display.  Unfinished I gather.
Date: 3 Aug 2000 00:15:54
Message: <3988f1fa@news.povray.org>
Looks more like a swish than a wiggle, but we'll let it pass this time. Nice
modelling. :)
Date: 3 Aug 2000 07:30:18
Message: <3989569E.2EC24689@my-dejanews.com>
So did you export 25 different meshes to pov, one for each frame, or did you
render it in A:M?
Date: 3 Aug 2000 09:55:33
Message: <398979DF.15B45A4@aol.com>
I exported 60 files in native .pov format in the form of bicubic
patches.  It uses about 1kb per patch, so this model came out to be
about 300kb per file.  Then I load the include files into a master scene
using:
#declare CURRENT_FRAME = clock;
#include concat("wiggle",str(CURRENT_FRAME,0,0) )
The include file was named wiggle.inc and numbered sequentially.  The
Final_Frame is the same as Final_Clock in the ini file.
-Mike
Date: 3 Aug 2000 09:57:47
Message: <39897930.FAE8A907@my-dejanews.com>
Ingenious. And the texturing: image maps, or some other ingenious method?
> using:
> -Mike
Date: 3 Aug 2000 16:02:58
Message: <3989CFF8.EC86F52@aol.com>
method?
They are image maps applied to the patches using uv mapping.  I had to
change a few things from uvpov to get it to work correctly.  It's pretty
much the same as uv mapping in MegaPOV but I replaced the two uv vectors
with four, allowing one to specify the four corners of a quadrilateral.
Just got this incorporated with the sources for MegaPOV today, so I'll
be tinkering with the photons.  :)
-Mike
