POV-Ray : Newsgroups : povray.beta-test : POV-Ray V3.7.0 R6 mesh_camera does not parse mesh2 Server Time
3 Mar 2026 13:36:55 EST (-0500)
  POV-Ray V3.7.0 R6 mesh_camera does not parse mesh2 (Message 1 to 7 of 7)
Subject: POV-Ray V3.7.0 R6 mesh_camera does not parse mesh2
Date: 14 Nov 2012 04:45:00
Message: <web.50a366fe37f297d5976af420@news.povray.org>
When trying to put a mesh2 into a mesh_camera instead of a regular mesh, POVray
aborts on the line containing vertex_vectors with "Parse Error: No triangles in
triangle mesh."
Putting a triangle into mesh2 seems to work.
Writing mesh42 instead of mesh2 causes a parsing error at this point already.
Using mesh2 objects for regular objects works fine, though.
Please tell me if you need additional information.
Subject: Re: POV-Ray V3.7.0 R6 mesh_camera does not parse mesh2
Date: 14 Nov 2012 06:37:54
Message: <50a38292$1@news.povray.org>
> mesh, POVray aborts on the line containing vertex_vectors with "Parse
> Error: No triangles in triangle mesh."
   Hmmm... I'm using it with mesh2 without any problems here. For
example, my latest AO baking demo uses a mesh2 converted by Poseray:
http://www.ignorancia.org/en/index.php?page=ao-baking
   Admittedly, I only tried with mesh2 objects converted by Poseray, but
with a lot of them, from very different origins. Your mesh2 is the
output of a conversion software, or custom made?
Jaime
Date: 15 Nov 2012 08:15:01
Message: <web.50a4e8d2ced0df555892c1fc0@news.povray.org>
> triangle mesh."
This kind of code causes the error:
    mesh_camera {
        1 3
        mesh2 {
This should work:
#declare cam_mesh = mesh2 {
    mesh_camera {
        1 3
        mesh {
            cam_mesh
Date: 22 Nov 2012 03:30:01
Message: <web.50ade1eaced0df555976af420@news.povray.org>
You are right, wrapping the mesh2 into a #declare does indeed solve the problem.
Thank you very much!
This should either be documented somewhere or fixed, I assume..
Date: 22 Nov 2012 03:36:18
Message: <50ade402$1@news.povray.org>
   Well, the syntax on the docs already suggests it has to be declared
before, as it requires a MESH_OBJECT_IDENTIFIER:
   mesh_camera {
     rays per pixel
     distribution type
     [max distance]
     mesh {
       [TRANSFORMATIONS]
     [mesh ...]
   [location]
   [direction]
   [smooth]
   But yes, it could be said explicitly somewhere on that section...
Jaime
Date: 22 Nov 2012 07:24:21
Message: <50ae1975$1@news.povray.org>
Added a clarification to the 1st paragraph:
http://wiki.povray.org/content/Reference:Camera#Mesh_projection
Date: 23 Nov 2012 04:55:01
Message: <web.50af474fced0df555976af420@news.povray.org>
Thank you!
