POV-Ray : Newsgroups : povray.beta-test : Alpha channel with background color Server Time
26 Oct 2025 05:44:52 EDT (-0400)
  Alpha channel with background color (Message 1 to 10 of 25)
Subject: Alpha channel with background color
Date: 30 Dec 2011 00:45:06
Message: <web.4efd4f5eb0be2cb585de7b680@news.povray.org>
Why does Output_Alpha=on not work in 3.7 when a background{} is specified?
Subject: Re: Alpha channel with background color
Date: 30 Dec 2011 04:14:14
Message: <4efd80e6$1@news.povray.org>
Le 30/12/2011 06:42, Cousin Ricky nous fit lire :
Interesting question. Confirmed last night (I was thinking about asking
too!).
And it might be related to the kind of camera (I have tried alternative
type of camera (perspective, and other customs), including the same
scene, and for some +UA works, for other it does not. (these are camera
with a mask, like the omnimax one)
Date: 30 Dec 2011 11:32:49
Message: <4efde7b1@news.povray.org>
  I haven't tested it, but does your background have transparency in its
color map? Because I have this faint recollection that it was changed so
that if it has, it would end up in the final image as such (and consequently
if there's no transparency, no transparency would end up in the final
image).
Date: 30 Dec 2011 20:24:46
Message: <4efe645e@news.povray.org>
> image).
Effectively, if I remember correctly, the background now need a filter
or transmit value to allow alpha transparency.
Date: 30 Dec 2011 23:35:00
Message: <web.4efe8fdb3d3e0ec485de7b680@news.povray.org>
Thanks, that works.  I guess it hasn't made it into the documentation yet.
Date: 31 Dec 2011 02:56:36
Message: <4efec034$1@news.povray.org>
It seems not indeed, or not clear enough. In section 3.1.2.4.1 Output
File Type, the relevant paragraph reads (text put between * * by me):
[quote]
The alpha channel stores a transparency value for each pixel, just like
there is also stored a value for red green and blue light for each
pixel. In POV-Ray, when the alpha channel is turned on, *all areas of
the image where the background is partly or fully visible will be partly
or fully transparent*. Refractions of the background will also be
transparent, but not reflections. Also anti-aliasing is taken into account
[/quote]
In highlighted phrase filter and transmit should be mentioned explicitly.
Date: 31 Dec 2011 08:25:01
Message: <web.4eff0cd43d3e0ec485de7b680@news.povray.org>
Except that anti-aliasing doesn't appear to work properly.
Date: 31 Dec 2011 08:25:50
Message: <4eff0d5e$1@news.povray.org>
> [quote]
> [/quote]
> Thomas
After re-reading the section, I guess a little clarification wouldn't
hurt. The highlighted section you mentioned has been changed ... also
found the same "Note" here:
http://wiki.povray.org/content/Documentation:Reference_Section_5#Using_the_Alpha_Channel
and changed it there too! Thanks everyone.
Date: 31 Dec 2011 08:30:01
Message: <web.4eff0d8e3d3e0ec485de7b680@news.povray.org>
Yes, that would be helpful.  Thanks.
Date: 31 Dec 2011 09:03:07
Message: <4eff161b@news.povray.org>
look at the bottom of this section:
http://wiki.povray.org/content/Documentation:Reference_Section_1.3#Anti-Aliasing_Options
perhaps the problem you are seeing can be mitigated by specifying +AG1.0
which effectively gives neutral behavior ... 2.5 is the default. Haven't
tried this ... maybe for a shot ;-)
