POV-Ray : Newsgroups : povray.beta-test : Segmentation Fault Server Time
16 Feb 2026 11:59:18 EST (-0500)
  Segmentation Fault (Message 1 to 10 of 11)
Subject: Segmentation Fault
Date: 10 Sep 2010 21:00:01
Message: <web.4c8ad42decb2972fd7f39bd00@news.povray.org>
When running the following code with:
povray +a0.03 +kff240
#include "metals.inc"
#include "stones.inc"
#include "math.inc"
light_source { <10, 50, -30> rgb 1 }
     location <0.0, 6.0, -15.0>
     up y
     right x*(image_width/image_height)
     look_at 0.0
#default {
     pigment { White }
     finish { ambient 0.1 diffuse 0.6 }
difference {
     plane { y, 0 }
     sphere { 0.0, 5.0 }
          pigment { White*0.625 }
          finish { ambient 0 diffuse 0.4 }
difference {
     intersection {
          torus { 5.0, 0.75 }
          cylinder { -0.5*y, 0.5*y, 6.0 }
     sphere { 0.0, 4.9375 }
#declare Frame_Rate = 24;
#declare Duration = 10;
#declare Frame_Count = Frame_Rate * Duration;
#macro index(seconds)
#local tick = (1 / Frame_Count) * Frame_Rate;
seconds*tick
union {
     union {
          difference {
               cylinder { -0.375*y, 0.375*y, 4.875 }
               cylinder { -0.4375*y, 0.4375*y, 4.625 }
          difference {
               cylinder { -0.375*y, 0.375*y, 4.5 }
               cylinder { -0.4375*y, 0.4375*y, 4.25 }
     difference {
          cylinder { -0.375*y, 0.375*y, 4.125 }
          cylinder { -0.4375*y, 0.4375*y, 3.875 }
          #if(clock <= index(5))
               rotate (3600*pow((clock-index(0)),2)/index(5))*x
          #else
               rotate (3600*(clock-index(5))/index(10))*x
A.D.B.
Subject: Re: Segmentation Fault
Date: 11 Sep 2010 12:26:41
Message: <4c8badc1$1@news.povray.org>
Le 11/09/2010 02:58, Anthony D. Baye nous fit lire :
Rendered, cannot reproduce the segfault.
Povray 3.7beta38+, on Ubuntu amd64
(additional personal data: +WT18, -H1025 -W1025 )
There is a discontinuity between image 120 & 121.
Images 1 & 121 looks alike.
Images 120 & 240 too.
Have you more details for your segfault ?
(povray version, operating system, ...)
Rendering frame 240 of 240
Parser Options
  Input file: seg.pov
  Remove bounds........On
  Split unions.........Off
  Library paths:
    /usr/local/share/povray-3.7
    /usr/local/share/povray-3.7/ini
    /usr/local/share/povray-3.7/include
==== [Parsing...] ==========================================================
Parser Statistics
Finite Objects:            4
Infinite Objects:          1
Light Sources:             1
Total:                     6
Parser Time
  Parse Time:       0 hours  0 minutes  0 seconds (0.014 seconds)
              using 1 thread(s) with 0.013 CPU-seconds total
  Bounding Time:    0 hours  0 minutes  0 seconds (0.000 seconds)
              using 1 thread(s) with 0.000 CPU-seconds total
Render Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Antialiasing.........On  (Method 1, Threshold 0.030, Depth 3, Jitter 1.00,
 Gamma 2.50)
==== [Rendering...] ========================================================
Render Statistics
Image Resolution 1025 x 1025
Pixels:          1118275   Samples:          298926   Smpls/Pxl: 0.27
Rays:            1417201   Saved:                 0   Max Level: 1/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder                  3788985         2330974     61.52
CSG Intersection               5836665         2300467     39.41
Plane                          2681769         1359732     50.70
Sphere                         3522038         1446511     41.07
Torus                           840269          534844     63.65
Torus Bound                     840269          596794     71.02
Bounding Box                  10727076         2667349     24.87
Roots tested:                596794   eliminated:                69323
Shadow Ray Tests:           1291314   Succeeded:                 26908
Shadow Cache Hits:            26746
Render Time:
  Photon Time:      No photons
  Radiosity Time:   No radiosity
  Trace Time:       0 hours  0 minutes  0 seconds (0.473 seconds)
              using 18 thread(s) with 5.196 CPU-seconds total
POV-Ray finished
Date: 11 Sep 2010 21:05:01
Message: <web.4c8c26ddbc88b8cd7f39bd00@news.povray.org>
Same version. Ubuntu Karmic, povray 3.7 beta 38, fujitsu lifebook w/ intel core2
duo 32-bit
segfaults after rendering the first frame, even with your extra arguments
gdb returns the following:
[New Thread 0xb495ab70 (LWP 3483)]
[New Thread 0xb2cb0b70 (LWP 3484)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0xb705eb70 (LWP 3456)]
0x08053f14 in ?? ()
hope this is helpful
A.D.B.
> Parser Options
>   Input file: seg.pov
>   Library paths:
> Parser Statistics
> Finite Objects:            4
> Infinite Objects:          1
> Light Sources:             1
> Total:                     6
> Parser Time
> Render Options
>   Quality:  9
>  Gamma 2.50)
> Render Statistics
> Render Time:
> POV-Ray finished
Date: 12 Sep 2010 05:10:54
Message: <4c8c991e$1@news.povray.org>
Le 12/09/2010 03:03, Anthony D. Baye nous fit lire :
> duo 32-bit
> 0x08053f14 in ?? ()
It might... it might be a 32 bit issue.
I recompiled for gdb, and ran from the debugger: no SIGSEGV on my 64
bits. (Lucid)
Maybe someone with a 32 bits system could help ?
Maybe a precision issue or a compiler issue ?
Notice that index(seconds) should be expanded as
"seconds*(1 / Duration)"
as tick= (1/FC)*FR
and FC = FR*Duration
ergo tick = (1/(FR*Duration)*FR = 1/Duration (as long as FR !=0)
pow(clock-index(0),2) might be clearer as pow(clock,2)
and it might also be interesting to use frame_number, initial_frame,
final_frame to automatically adjust the frame_rate
 ( http://www.povray.org/documentation/view/3.6.1/228/ )
from the command line
 ( http://www.povray.org/documentation/view/3.6.1/216/ )
+kff240 +kf10.0 +ki0.0 +kfi1
(clock going from 0 to 10, frames from 1 to 240, 20 frames per clock unit)
Date: 12 Sep 2010 13:02:45
Message: <4c8d07b5$1@news.povray.org>
Ran to completion on my opensuse-11.2 32bit system. Code exactly as
original poster. I'm running the current state of the perforce depot.
Date: 12 Sep 2010 13:05:05
Message: <4c8d0841$1@news.povray.org>
Ran without any problem under Windows XP 32 bits.
Date: 13 Sep 2010 15:30:00
Message: <web.4c8e7b78bc88b8cd7f39bd00@news.povray.org>
> > duo 32-bit
> > 0x08053f14 in ?? ()
> bits. (Lucid)
> as tick= (1/FC)*FR
I normally do use the built-ins for computation, but I couldn't find my
animation notes on what was what, so I made my own terms.
I haven't been using all the animation options...
A.D.B.
Date: 13 Sep 2010 15:45:00
Message: <web.4c8e7e87bc88b8cd7f39bd00@news.povray.org>
> > > duo 32-bit
> > > 0x08053f14 in ?? ()
> > bits. (Lucid)
> > as tick= (1/FC)*FR
> A.D.B.
Ran a simple test with full command line options, replacing the animation code
with rotate 360*clock*x and reducing the number of frames to 24.
Render still seg-faults after first frame.
Is there any way to do a full un-install of povray in linux?
I could try re-compiling from sources.
A.D.B.
Date: 13 Sep 2010 16:00:01
Message: <web.4c8e81cebc88b8cd7f39bd00@news.povray.org>
the problem disappeared when I turned of the display (-D).  There must be
something buggy in the display code or it's interaction with X.
A.D.B.
Date: 13 Sep 2010 16:07:40
Message: <4c8e848c$1@news.povray.org>
Le 13/09/2010 21:41, Anthony D. Baye nous fit lire :
it was just a reminder, I just know they exists... have always trouble
to find them all. Do not take that too seriously.
>> A.D.B.
Installation from sources does not need uninstall (it might just
overwrite the old files... and change the damned ownership of your
default in $HOME/.povray/3.7/... if you install with "sudo make install"
(and it will install them in ~root/.povray/3.7 if you install as true root)
Last idea, what is your image format for output, and what is the library
version ?
(hint: libpng ??? might have a binary issue between the 1.2 & 1.4, IIRC)
