POV-Ray : Newsgroups : povray.beta-test : Possible bug with debug file output Server Time
3 Mar 2026 20:53:23 EST (-0500)
  Possible bug with debug file output (Message 1 to 8 of 8)
Subject: Possible bug with debug file output
Date: 5 May 2010 13:25:01
Message: <web.4be1a8b66eee2a9fa3fcf12a0@news.povray.org>
I just put 3.7.37a on a computer that had always been running 3.6. I just
started outputting the debug information to a file (to confirm what values were
used per frame since I am making MANY frames and wanted to know what values
cause bad looking frames).
In 3.6 each "block" of debug information was written into the debug.txt (the
filename I am outputting to) sequentially, with each frame appending to the
content already there. So I was able to look through the debug values for the 10
sample frames I rendered (only 10 at the time) and everything was listed. I even
added extra debug text to help separate the frame output because of this
feature. The entire file was overwritten if I restarted another sample run
(which is preferred for my needs).
I just installed 3.7.37a earlier today and ran the same .pov file with the same
options. Now the debug.txt file is created but the information is contained with
each frame. So if I let it finish the entire sample, I will only have the values
for frame 10 not the other 9 (which is needed).
So my question is this:
Is this an EXPECTED feature change or is this a bug I should put into Flyspray?
I did searches but did not find anything that seemed to relate to this, but I
might have missed it.
Subject: Re: Possible bug with debug file output
Date: 5 May 2010 16:51:43
Message: <4be1da5f$1@news.povray.org>
Am 05.05.2010 19:19, schrieb fillibar:
Let's put it this way: If I was in your place, I'd consider it undesired
behavior at any rate; so do feel encouraged to enter it into Flyspray as
a "possible bug". If it turns out to be an intended feature, the entry
can still be re-categorized as a change request.
Date: 5 May 2010 19:55:00
Message: <web.4be2045be36e08eee767940e0@news.povray.org>
I suspect it is intentional (and is the result of enforcing that #fopen w/
"write" re-create the file at all times, as the old behavior probably also led
to unwanted results in different situations).
The options are to either implement a fourth type of file access for #fopen
that's essentially "write on first frame, append on all later frames", or to do
it manually in your scene.
Date: 5 May 2010 20:17:06
Message: <4be20a82$1@news.povray.org>
Am 06.05.2010 01:50, schrieb MDenham:
Maybe I misunderstood; I thought this was about #debug output being
redirected to a file.
Of course, if it is about #fopen, then using "#fopen ... append" instead
of "#fopen ... write" should do the trick (except for the first frame,
which should use "write" instead to erase the old contents).
Date: 5 May 2010 21:10:00
Message: <web.4be2163fe36e08ee4a3345d60@news.povray.org>
No, it is about directing #debug output to a file, the "Debug_File=" command
used in a .ini. I will open a bug about it since my feeling is that if you are
wanting debug information you probably would want it for the entire duration of
a render not just a single frame (if you are making more than one). In the
meantime I will also take a look at #fopen as an alternative.
Date: 5 May 2010 22:10:00
Message: <web.4be224dde36e08ee5eea6c5d0@news.povray.org>
My fault, I misunderstood what you were doing (mostly because I forgot
Debug_File exists :-/).
Still, I suspect that someone probably made a similar change in the source to
what I'd mentioned, and instead of "create on first frame, append on all later
frames" (ideal) or "append on all frames" (acceptable, probably) it's doing
"create on all frames", giving the results you're seeing.
Date: 6 May 2010 21:00:01
Message: <web.4be36594e36e08ee4a3345d60@news.povray.org>
do
That is the area I wonder about... Is it a feature because someone wanted it
"create on all frames" at one point, or is it a bug because it is supposed to do
one of the others. For my usage, it is a bug, so I am entering it now. Hopefully
that will either resolve the feature or bug question. If it is a feature, I just
need to find a workaround (rendering 1 frame at a time is really not an option).
Date: 6 May 2010 21:15:01
Message: <web.4be3690de36e08ee4a3345d60@news.povray.org>
In case anyone actually is interested in this, it has been submitted into
Flyspray as:
FS#109 - Debug_File No Longer Appends Frame by Frame Debug Data
